PX-41 from Russia.
Farit
Russia
CAM00998.jpgLet me introduce my project PX-41.
From drawing to implement.
Video: http://www.youtube.com/watch?v=MBVOwallZS8
Very nicely done! I'm curious, what thickness steel did you use for the "box" type frame? I've seen a number of this type of frame, rather than tubes down the middle. Seems to resemble sport motorcycles and allow for plenty of battery space.
The thickness of sides of frame is 2 mm, the main part is 3 мм.
Swing arm - metal profile 40-20-2 mm, mount 6 mm.
Dropouts - 8 mm.
Total bike weight (with battery) is 47.5 kg.
Drunkskunk said:
Very Impressive.
What motor are you using?
I use Crystalyte 4080 with LiFePo4 48v 15 AH battery and native Crystalyte controller 48v 60A.
Speed is not so big 45-48 km/h, but acceleration is very well :D !
http://youtu.be/X88XXOdC4oA
http://youtu.be/M8zKRg1bMPE
http://youtu.be/iRKxKBFpyl4
agniusm said:
2mm side panels 3mm stuff and 2mm rectangular tube for the swing arm :shock: . That thing is a tank, bet it weighs some:)
Frame weight with swing arm is 13.2 kg.
That's not bad. Thinking of doing sheet frame from SS but i think 0.8mm will be plenty
Down and up the hill. Elevation changes about 100 m, standard battery 48V 15Ah, Crystalyte 4080 motor (high speed). Throttle to maximum current of 50A. The total weight of 122 kg.
http://www.youtube.com/watch?v=gZ9pBnGeQsA
