Mark_A_W wrote:Do they clear your knees?
I found they had to be low, because they are 130mm wide.
On that bike I think I would put one above the downtube, and one below it.
MitchJi wrote:VC: Sorry to clog your thread. You asked about Neu so I thought it might be good to get information on all of the potential Neu issues.
Its not to scale and I'm sure it would be tight but it looks like Matt's drive might fit between your swing arms (below the top arm and above the lower arm). With the two inch wide version the aluminum tube would probably fit between the swing arms (left of the right arm and right of the left arm). This might gain you an inch or two in terms of the length of the drive unit.
deecanio wrote:if they work then for sure leave them there!!! tight fit is good, you dont want the packs jumping about so dont worry about that and look at the space you have left in the triangle for the ESC and excess wiring, nice.
Ben wrote:So are you going to make a universal triangle box to fit the red bike and this, or separate ones?
Also, how much power are you planning for on this bike?
Mt Zefal Makes a cool litttle product called the "gizmo clamp" Which allow one to
mount a water bottle where there are no braze ons. I will be using these slick
little devices to mount the battery case to the frame rather than hose clamps...
MitchJi wrote:Also I don't understand why mounting your motor on the swingarm as shown will interfere with suspension travel. I looks like the motor, rear sprocket, swingarm and wheel will all move together.
voicecoils wrote:Yes they'll all move together but the concern is, will it smash into the seat tube at full compression? The bike has 8-8.5" travel remember. If I run the rear shock as stiff as possible, I should fine on the road (and it would help with peddling efficiency too) but it would be nice to run the shock nice and plush if I want to take it off road.
Those clamp links look interesting. I've been doing a bit of searching for "two piece collars" and there are some interesting things out there, designed for industrial purposes for clamping onto axles etc.
example: 1 1/8" two piece collar
Hi VC, You might want to consider locating it where it would be if there was a fender and you put it parallel to the fender and slid it toward the back far enough that it can't hit the seat tube. I know I'm repeating myself but you could mount a strong structural fender on the bike for mounting the drive unit. Good find on the "two piece collar"
OW I have made the "Top Hat" sprocket adapter which is not only super light (a feathery 2.1 ounces) BUT also allows you to use a disc brake if you so choose! All the advantages of the standard version #1 sprocket hub adapter PLUS super light weight and the ability to retain use of the disc brake system if so equipped.(depending on components used may require the
use of custom spacers below and other "tweaks" since space will be at a premium between the disc and sprocket....may limit sprocket size choices in some cases....again all this is dependent on the frame and components used)...
All pieces are made from the same great aerospace grade 7075 T651 aluminum we make our sprockets from....I have been researching Titanium nuts and bolts but will at first make these adapters available for use with your own nuts and bolts.
The first and only geared belt drive bicycle assist engine on the market.
voicecoils wrote:MitchJi,
The tophat looked appealing at first, however the 9 whole bolt pattern is not compatible with the 6 hole pattern of #219 kart sprockets.
*** Disc brakes (Not recommended):
1. Disk brakes are expensive to maintenance and, because of how they work, put a lot of stress on the spokes w/o motorizing. Braking stress combined with engine torque, puts stress on spokes going and coming.
2. Some disc brakes sit within bike frame, only requiring a washer or nut to space lower strap out, for clearance. Some find the need to grind or file an 1/8" sliver (crescent) from lower strap for brake clearance, others protrude so far beyond the frame of the bike that installation becomes tedious, if not impossible. If possible, we recommend you steer clear of disc brakes.
To check to see if the disk brake would obstruct clearance of Lower Mount Strap - a yardstick is helpful (or something similar).
Place yard stick on top of axle - pivot toward seat then back toward rear of wheel - does any part of the disk brake protrude so far beyond bike frame that it would interfere with the lower strap?
recumpence wrote:Anyway, the only issue I am struggling with on my mountain bike build (have not started it yet) is rear disc brake with a sprocket big enough to achieve the drive ratio I am looking for.
I may have to mod my Avid cailper and make a "Sproder" (rear sprocket/brake rotor). Either that, or put a small custom rotor on the drive jackshaft. Neither option seems apealing to me, though.
So, how much clearance do you have between the tire and seat post at full suspenison travel?
Matt
As for the disc brake comment. I think the excuses for not using one are lame. If you're using a bike with a wide enough tire (large enough contact patch) and want to do any powerful or sustained braking there's no equivalent alternative to hydraulic disc brakes. Look at cars and motorcycles! Hydraulic rim brakes and mechanical disc brakes are both decent and a step above v-brakes/side-pull/canti cable actuated brakes. Instead of him suggesting against them, a better solution to marry the two should be found.
recumpence wrote:I'm sorry, but once you use disc brakes, you never go back. I have no clue why he is against them.
Matt
Users browsing this forum: Google [Bot] and 5 guests
