OW I have made the "Top Hat" sprocket adapter which is not only super light (a feathery 2.1 ounces) BUT also allows you to use a disc brake if you so choose! All the advantages of the standard version #1 sprocket hub adapter PLUS super light weight and the ability to retain use of the disc brake system if so equipped.(depending on components used may require the
use of custom spacers below and other "tweaks" since space will be at a premium between the disc and sprocket....may limit sprocket size choices in some cases....again all this is dependent on the frame and components used)...
All pieces are made from the same great aerospace grade 7075 T651 aluminum we make our sprockets from....I have been researching Titanium nuts and bolts but will at first make these adapters available for use with your own nuts and bolts.
The first and only geared belt drive bicycle assist engine on the market.
voicecoils wrote:MitchJi,
The tophat looked appealing at first, however the 9 whole bolt pattern is not compatible with the 6 hole pattern of #219 kart sprockets.
*** Disc brakes (Not recommended):
1. Disk brakes are expensive to maintenance and, because of how they work, put a lot of stress on the spokes w/o motorizing. Braking stress combined with engine torque, puts stress on spokes going and coming.
2. Some disc brakes sit within bike frame, only requiring a washer or nut to space lower strap out, for clearance. Some find the need to grind or file an 1/8" sliver (crescent) from lower strap for brake clearance, others protrude so far beyond the frame of the bike that installation becomes tedious, if not impossible. If possible, we recommend you steer clear of disc brakes.
To check to see if the disk brake would obstruct clearance of Lower Mount Strap - a yardstick is helpful (or something similar).
Place yard stick on top of axle - pivot toward seat then back toward rear of wheel - does any part of the disk brake protrude so far beyond bike frame that it would interfere with the lower strap?
recumpence wrote:Anyway, the only issue I am struggling with on my mountain bike build (have not started it yet) is rear disc brake with a sprocket big enough to achieve the drive ratio I am looking for.
I may have to mod my Avid cailper and make a "Sproder" (rear sprocket/brake rotor). Either that, or put a small custom rotor on the drive jackshaft. Neither option seems apealing to me, though.
So, how much clearance do you have between the tire and seat post at full suspenison travel?
Matt
As for the disc brake comment. I think the excuses for not using one are lame. If you're using a bike with a wide enough tire (large enough contact patch) and want to do any powerful or sustained braking there's no equivalent alternative to hydraulic disc brakes. Look at cars and motorcycles! Hydraulic rim brakes and mechanical disc brakes are both decent and a step above v-brakes/side-pull/canti cable actuated brakes. Instead of him suggesting against them, a better solution to marry the two should be found.
recumpence wrote:I'm sorry, but once you use disc brakes, you never go back. I have no clue why he is against them.
Matt
dontsendbubbamail wrote:You might be able to use this spreadsheet to CNC a gear of the size you desire. I found the xls on the web some time ago. Your description sounded like the gear will be going between the disk and the spokes and not between the disk and the dropout. Did I get that correct?
Anywho, if you get in a pinch I think I could draw up a nice .DXF of a sprocket.
rguy56 wrote:voicoils,
ok, for cars and bikes it's true, but if you could find a way to replicate airbrakes...
recumpence wrote:The primary problem with a jackshaft brake would be the added drag. Lets say you have a 3 to 1 ratio i nthe final chain drive, now the rotor and jackshaft would spin at 3 times the wheel speed. That is good in one sence because you can use a far smaller rotor (maybe a 3 inch rotor) with good braking. But, the drag while pedalling would be a neusance. The jackshaft bearings alone would cause enough drag to feel while pedalling. That is the reason I never made a jsackshaft disc brake on my recumbent.
It is a possibility, though.
Hmm, maybe I should have some 10 or 11 inch rotors custom made?![]()
Matt
Ben wrote:36V or 72V? You'd have to go 72 wouldn't you?![]()
I think the 5304s are about 1km/h per (nominal) volt in a 26", so probably around 33 or 65km/h in a 24".
recumpence wrote:.
voicecoils wrote: A Buell type "inverted disc" could be fun too but then you just start getting a bit crazy.
PaulM wrote:voicecoils wrote: A Buell type "inverted disc" could be fun too but then you just start getting a bit crazy.
Now you're talking!! Brake disc on the inside, sprocket teeth on the outside!! Buell mounts it to the rim though, that would be one huge brake disc, and sprocket!! Not too mention vulnerable to damage. If one of those 5 spoke (or whatever) carbon wheels was used, this assembly could be mounted to the spokes.
Users browsing this forum: Bing [Bot] and 11 guests
