Andre´s STRAIGHTLINER RISING SUN
Rovi
1 W
1 W
Re: Andre´s STRAIGHTLINER RISING SUN
Post by Rovi » Aug 18, 2016 8:08 am
If BLACK RAP-THOR frame failed ...
Nippon Style_klein.jpg (169.26 KiB) Viewed 104 times
Rovi
1 W
1 W
Post by Rovi » Aug 23, 2016 3:44 am
Now I finished the updated box for second row of battery pack (together now 173VDC, 10Ah)
Box 041.JPG (115.38 KiB) Viewed 312 times
Box 038.JPG (161.06 KiB) Viewed 312 times
Box 036.JPG (148.63 KiB) Viewed 312 times
Rovi
1 W
1 W
Post by Rovi » Sep 01, 2016 4:54 am
On test run at airport with 175,1VDC and up to 400A I killed the small Cromotor V2 within 4 seconds on 37,x mph/59,8 kph (around 60m) and also the KHB14401.
So the story ends for this bike and I continue with another project.
Rovi
1 W
1 W
Post by Rovi » Sep 02, 2016 6:09 am
Rovii
Post by Rovii » Nov 16, 2017 3:19 am
Maybe I will install a dual disc brake to Straightliner Rising Sun by using old Cromotor V2 rim (1,85" x 21") ...
Current tests 04 025.JPG (176.63 KiB) Viewed 150 times
Current tests 04 008.JPG (173.23 KiB) Viewed 150 times
- Fastest speed record 200,49 kph on flat after 740m (175V, 400A)
- Fastest 1/4 mile @ 157,12 kph on flat and 14.468 sec (146V, 600A)
14/34kW QS-Motor 273 80H 7T winding (560A and 1740 turns @ 144V) @ 169kg GSXR 1000 K2
Wolfeman
Post by Wolfeman » Nov 16, 2017 10:22 am
Time for more power. Bigger motor and controller. Looking forward to seeing how it goes. Thanks for posting.
Trek 4300 w/ H3580 Crystalyte at 2300W
https://endless-sphere.com/forums/viewt ... =3&t=82738
Rovii
Post by Rovii » Nov 17, 2017 11:25 pm
If the motor will survive, iI should run there, together with KLS 8080I
14401.https://endless-sphere.com/forums/viewt ... 12&t=82155
Less current but also less weight than motorcycle!
