as some of you already know, i've been working on electrifying my Electra rat fink to use as my daily commutter..it has worked quite good but i wanted battery setup lower and rear suspension.
so i started to build myself a complete frame from scratch.
here are the first build pics...weld are getting better as this is my second welding project.
the frame material used to be a bed frame...
motor used is a golden motor 36v.
built the support for the pivot point of the swingarm,,right now it's not welded in place, it is butted inside and i can put it in place or take it out to build the swigarm and check the fit
battery rack almost complete.
