'Triangle power'
Mongo1
'Triangle power'
Post by Mongo1 » Jul 18, 2017 6:04 pm
Thought I'd post this for anyone interested. I build stuff all the time and wanted to build an ebike that was light weight, reliable, mid-drive mechanicals, original and fun. This is the conventional of the two drives I was designing (the other a bit more exotic but not practical).
Using (UPDATED):
-Nishiki hardtail
-Turnigy 6374 motor (168 KV) (10x primary redux X 3.5x secondary to crank) = a bit faster than pedaling speed :D
-Graupner 60 amp/36 volt esc(burnt out by accident) replaced with Phoenix HV80 Edge (note: Graupner esc has superb startup from standstill).
-Cycle Analyst V3
-PAS enabled using AUX potentiometer as manual control (GrinTech=Brilliant :) Being able to override PAS with throttle is awesome!!!
-Using DROK DP505A voltage regulator to supply low voltage for lights, etc.
-Using 4 car jump start battery packs in back pack (48 volts, limit at 60 amps)
-Increased voltage to 48V (speed is now 40+ mph, pcm not at highest possible msec :)
-total weight (with batteries) = 45 Lbs.
'Triangle power'
Triangle power cycle.jpg (144.02 KiB) Viewed 705 times
Triangle power mini PAS.jpg (102.37 KiB) Viewed 828 times
ebikealltheway
Re: 'Triangle power'
Post by ebikealltheway » Nov 07, 2017 10:55 pm
How hard was it fabricating all those custom looking mid mounts?
eCue
Post by eCue » Nov 25, 2017 12:06 am
Thats a seriously beastly RC motor and a good hack !
Solar charge station on wheels join the Revolution
Buk___
Post by Buk___ » Nov 25, 2017 12:49 am
Nice build.
As an aside, any chance of a close-up of your front light setup.
At first I thought that attaching it there wasn't good -- unsuspended weight, unmitigated road shocks etc. -- but the more I think about it, the fact that the light/beam doesn't bounce up and down probably makes a huge amount of sense. I'd like to see how you did it?
Mongo1
Post by Mongo1 » Dec 01, 2017 1:01 pm
It's simple, really. Just two sheets of 0.20 in of 6060 Aluminum bolted together with 4 bolts at a distance that allow it to fit on insulated down tube and seat tube . Makes this setup very light weight while being very rigid.
Mongo1
Post by Mongo1 » Dec 01, 2017 1:06 pm
Thanks!! This motor, geared properly, is more capable than people would think :) Also, I made and bolted an impellor at the end to assist with cooling (no issues with heat so far).
Mongo1
Post by Mongo1 » Dec 01, 2017 1:09 pm
Nice build.
Thanks!! Will provide close up of the light asap. That location worked out really well, for me.
Mongo1
Post by Mongo1 » Dec 06, 2017 12:38 pm
Nice build.
Here are a couple of images. I don't do much off-roading right now so haven't had a problem of light bouncing around (if needed I can always mount it on handlebar).
light small 2.jpg (94.62 KiB) Viewed 531 times
light small front.jpg (58.41 KiB) Viewed 531 times
eCue
Post by eCue » Dec 06, 2017 5:58 pm
Im not at the stage in my ebiking development to be doing this *yet* but would be cool to see a photo of how the Fan is attached for future building.
Buk___
Post by Buk___ » Dec 06, 2017 6:33 pm
Thanks! Looks like a neat way to get the light where you want it.
Mongo1
Post by Mongo1 » Dec 07, 2017 11:53 am
The impellor is drilled out to fit over the shaft and attached with the 4 bolts provided to the back of the motor.
Turnigy 6374 motor.jpg (41.84 KiB) Viewed 496 times
