martinmertik
- Joined
- Sep 26, 2013
- Messages
- 90
Hi ES members!
My name is Martin and I'm from Slovenia and this is my e-bike.
Parts:
Frame: Commencal Furious 2008
Brakes: Juicy disc brakes
Front/rear suspension: rockshox/fox
Tires: front 22" and rear 18" Sava MC2 tires
Motor: QS205 4T
Freewheel: 18tooth
Controller: subvoton 72150 UNLOCKED
Battery: 220cell 22s10p Samsung 25r capable of 200A continuous
BMS: 30s 320A set to 22s BMS
Display: Cycle analyst V3
Throttle: Domino Twist throttle
Charger: Not sure yet
So what I've done so far:
All previously mentioned parts were already ordered and I will recieve them till the end of this month.
Dropouts were already 150mm wide so I only needed to modify the holes so that the motor fits in just fine.
Controller is unlocked so it means that DC current can reach 200A and phase current 350A. When battery fully charged (4.18V a cell) the voltage will be 92V so the power should be crazy considering that the bike will weight only 40KG.
Controller doesn't come with Cycle analyst connector so I will have to modify my controller also. I can't wait to start putting my bike together. Reply if you want me to update you with pictures during the process of the build.
Parts:
Motor: QS205 4T
Freewheel: 18tooth
