Update: no drive for me. Tons of rain, not such a big deal except that my motorcycle decided to quit running while on the way to the site. Whoops.
dnmun wrote:i think you can drive the entire I5 now too on the fast chargers. i am 30 blocks off I5 here in portland and you can charge here for free on your way south. you can walk around the neighborhood and log on to my wifi or go to the sushi take out up the street.
dnmun wrote:P Town> they are changing the name from 'portland town' to prius town''. seems about 10% already. 4 on my short block.
i am a real believer in the plug in hybrid transition phase which should last a long time. only seen one plug in prius on the highway though.
veloman wrote:why can't you charge past 80%? That seems like a huge drawback on a car that already has its biggest issue of range.
Toshi wrote:veloman wrote:why can't you charge past 80%? That seems like a huge drawback on a car that already has its biggest issue of range.
You can. 80% maximizes longevity of the battery, though.
In extreme cold situations, the Land Cruiser’s auxiliary Positive Temperature Coefficient (PTC) heater warms air instantly by passing it over an electrically heated ceramic element.
LeftieBiker wrote:BTW, Nissan is now offering leases that consist of $1999 down, $245 a month (all USD) and a 36 month lease length. That's a good deal for someone in a mild climate who doesn't need more than 60 miles or so real world range.
LeftieBiker wrote:If they have completely replaced the resistive heating with a heat pump, that's going to be a real problem. Heat pumps can't extract usable amounts of heat from the atmosphere below about 45 degrees Fahrenheit.
Jeremy Harris wrote:LeftieBiker wrote:If they have completely replaced the resistive heating with a heat pump, that's going to be a real problem. Heat pumps can't extract usable amounts of heat from the atmosphere below about 45 degrees Fahrenheit.
Yes they can, no problem at all. Ask any Canadian or Scandinavian! I've been looking at heat pumps for my new house build, and although I've decided against an air source heat pump (as used in the Leaf) I did check the specs and prices for them. All the units I looked at worked down to -18 deg C or lower (that's around 0 deg F I think). The COP get's down to unity at that point, but pretty much anywhere above that (as long as you can efficiently deice the heat exchanger when its humid) you can get a COP of better than 1. Typically COP for an air source heat pump will be around 2 to 3 in normal use, maybe 4 at its best.
LeftieBiker wrote:Jeremy Harris wrote:LeftieBiker wrote:If they have completely replaced the resistive heating with a heat pump, that's going to be a real problem. Heat pumps can't extract usable amounts of heat from the atmosphere below about 45 degrees Fahrenheit.
Did you read specifically that the heat is coming from the air at those temps? Because home heat pumps do provide heat in that range, but at the colder end it comes from built-in resistive heating elements, not the air. Maybe my knowledge is out of date, but I find it hard to believe that they can scavenge enough heat from the air at those temps...
Return to E-Vehicles General Discussion
Users browsing this forum: No registered users and 4 guests
