THE WORLD BIGGEST HUB MOTOR
Postby Doctorbass » Fri Dec 10, 2010 1:40 am
Incredibly... it is THIS mining truck that use the hub motor!!!
4 of those are using the power of a 3240hp generator 2.5 MW of ELECTRIC power!!.. making around 800kW each!!! :shock: :shock: :shock: :shock: :shock:
Doc
________________
-Fastest speed record from now: 113 km/h measured on GPS
-Fastest ebike 106km/h on flat and managed to enter in the 19.875 sec on the 1/4 mile drag racing !
-0-70km/h in 5sec X5 5303 on 24"
TORQUE SETUP:
-Team Konion Member
113kmh Giant___http://www.evalbum.com/3406
Mongoose____http://www.evalbum.com/1947
E-trike_______ http://www.evalbum.com/3776
I speak FRENCH and english
Doctorbass
Re: THE WORLD BIGGEST HUB MOTOR
Postby neptronix » Fri Dec 10, 2010 2:01 am
I think one of those would work on a penny farthing. :lol:
ES facebook group: http://facebook.com/#!/home.php?sk=group_125035107565566&ap=1
The all-arounder: 8T MAC motor on a Trek 4500.
The girlfriend bike: 350W front MAC on a 700c Trek.
The Bus: ??? on a 'da bomb' cargo bike frame
Pro-tips for noobs: Avoid BMS Battery like the plague | Charge RC Lipos to 4.15v, stop discharging at 3.5-3.6v | Use torque plates/arms! | Rear mounted hubs are always best
neptronix
Postby dingoEsride » Fri Dec 10, 2010 4:11 am
try calling that a frock motor
ride like the wind
dingoEsride
Postby DAND214 » Fri Dec 10, 2010 11:55 am
It sure would need a BIG bike to put it on! :mrgreen:
Dan
It sure would be nice to know where we are all located, ON THIS WORLD.
Fill in your profile. It doesn't hurt.
I know some worry about being found.
I wish someone would find me.
DAND214
Postby Hillhater » Fri Dec 10, 2010 8:22 pm
This is a 3000 hp Ac "hub" motor as used on the big dump trucks, with a 32:1 reduction gbox attached.
They also use electric "retard' braking as even the multi rotor, 20 caliper mechanical brakes wont hold the 500t unit when rolling downhill !!
Hillhater
1.21 GW
1.21 GW
Postby Lock » Fri Dec 10, 2010 9:48 pm
So, how fast DOES it go?
:mrgreen:
If you like this message feel free to donate BeerCoins (BTC) to:
1LxAXWmbjY6SeMf8r9HHhSKt6pWyPvWg6L
Toronto Electric Riders Association:
http://www.ebikeriders.com/
Canada, eh?
Lock
Postby amberwolf » Fri Dec 10, 2010 10:21 pm
dingotookmybaby wrote:try calling that a frock motor
Well, it certainly is pretty frockin' big. ;)
Lock wrote:So, how fast DOES it go?
:mrgreen:
At that size, I don't think it matters anymore--it's still terminal velocity. :P
House Fire Updates Thread
http://endless-sphere.com/w
DayGlo Avenger, MkII
amberwolf
Postby dogman » Sat Dec 11, 2010 6:41 am
Yeah, just goes to show how unpractical and unreliable a hub motor is. Especially if you want real power. I think those things go about 20 mph unloaded, and maybe 10 loaded. Any faster and they have to rebuild the road into the pit too often. I often think of those when people scoff that hybrid systems couldn't possibly work for anything but a teeny tiny car. The other hybrid is a railroad locomotive.
THE LIPO RULES. NEVER ABOVE 4.3V NEVER BELOW 2.7V DON'T PUNCTURE
Ideal charging /discharging range for Lipo, 3.65v minimum 4.1v maximum
See battery technology section, FAQ thread at the top of the page for lipo noob info.
dogman
Postby Tom Tom » Sat Dec 11, 2010 10:13 am
Group Buy? Shipping might be a slight biyotch thou :D
Tom Tom
Postby oldpiper » Sat Dec 11, 2010 11:25 am
Remember, if you want to go all EV (no generator on board), you might need to fill the whole dump bed with batteries (Quick, Martha, buy stock in companies that make duck tape and/or BIG shrinkwrap!). :twisted:
Cameron
Schwinn StingRay OCC XL, front AmpedBikes DD hubmotor, 37V, 10 Ah Lipo
"If it jams-force it. If it breaks, it needed replacing anyway."
"Just because you're paranoid doesn't mean they aren't out to get you."
oldpiper
Postby fechter » Sat Dec 11, 2010 11:42 am
Those things have some really big braking resistors.
This one is 100kW:
When I used to be in the mining business, I remember driving in a pickup truck around those things thinking they wouldn't even notice if they ran over me.
fechter
Postby Gordo » Sat Dec 11, 2010 1:00 pm
http://tinyurl.com/22vbbc6
http://www.google.ca/images?hl=en&q=let ... 64&bih=603
Hubmotor Letourneau's have been around since 1958. I ran a bush mill in the Mackenzie area when this thing was busy smashing down the jack pine in 1963. IIRC it was paid $1000/hour, but only while actually moving forward. A tally man rode in the machine and clocked the forward motion.
X-treme 3KW Scooter...OFF ROAD ONLY....Giant 1KW 48V 24" Hubmotor....E-Apex 1KW 48V 26" Hubmotor, built 2012-05-26
Thanks Justin, for saving ES. May Grin Tech grow and prosper.
Gordo
Postby TylerDurden » Sat Dec 11, 2010 1:16 pm
Gordo wrote:Hubmotor Letourneau's have been around since 1958.
Must have one for DeathRace 2011.
Have a Nice Day,
TD
___________________________________________________________
FYI: Adding pictures?
Bored?... take a crack at the unanswered posts
Please post your Watts-at-speed in the survey.
TylerDurden
Postby Hillhater » Sun Dec 12, 2010 6:45 pm
dogman wrote:..... I often think of those when people scoff that hybrid systems couldn't possibly work for anything but a teeny tiny car. The other hybrid is a railroad locomotive.
Technically these are not "hybrids" since they cannot operate on solely the ICE or just the electric drive by its self .
They are ICE powered (diesel ) , with an "Electric transmission" drive instead of a conventional clutch /gearbox / axle system.
Hillhater
1.21 GW
1.21 GW
Postby spinningmagnets » Sun Dec 12, 2010 6:53 pm
I have a LOT of hours on a fairly conventional 25-ton, but for two weeks I operated a 100-ton. It was scary, because the construction industry has a couple of day-dreamers on every crew...here's a famous pic from the industry, easy to find. ENORMOUS blind-spot for the driver as you can imagine...
spinningmagnets
Postby Hillhater » Sun Dec 12, 2010 7:03 pm
Doctorbass wrote:Incredibly... it is THIS mining truck that use the hub motor!!!
Doc
I just noticed that you showed the Cat 797....
Ironically, that is the ONLY mining dump truck that DOES NOT use electricaly transmission or wheel motors !! :shock:
It uses a conventional mechanical transmission set up. !...a computer controlled, seven speed planetary transmission with an integral lock-up torque converter.
The Komatsu 960e would be a typical electric wheel motor driven truck..
Hillhater
1.21 GW
1.21 GW
Postby Gordo » Sun Dec 12, 2010 7:07 pm
Doc
Doc;
You screwed up in the Fronglais. There is no e-moto in the HUB.
Powertrain
The Caterpillar 797 series trucks employ mechanical drive powertrains in contrast to the diesel-electric powertrains of similar haul trucks offered by competitors.[4] During initial development in 1997, a diesel-electric powertrain was considered for the 797, but this powertrain configuration was not developed because Caterpillar considered a mechanical drive powertrain more appropriate for market conditions at that time.[8]
EDIT;
The 797 is a 400 short ton truck, not 100T It is just over 100T EMPTY.
Gordo
Postby fechter » Sun Dec 12, 2010 8:05 pm
This one might be in line for the biggest hub motor:
MT6300AC
Payload Capacity 363 t (400 ton)
Gross Weight 598,640 kg (1,320,000 lb)
Engine(s) Detroit Diesel/MTU 20V4000
Arrangement: V-20
Power: 3,750 horsepower (2,800 kW)
Transmission(s) AC Electric
The large fan behind the operator cab is for the braking resistors.
fechter
Postby Doctorbass » Sun Dec 12, 2010 9:38 pm
Gordo, I was wrong.. as sometimes.. I posted too fast without re-reading my post :lol:
Fechter.. You mentionned it's an AC motor!.. Welll I would be curious to see the controller of that hub motor!!!.. and the dozens of IGBTs :shock:
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby grindz145 » Sun Dec 12, 2010 10:07 pm
8)
neptronix wrote:I think one of those would work on a penny farthing. :lol:
Hell yeah! haha
http://www.endless-sphere.com/forums/viewtopic.php?f=18&t=19548 - Ebike Nerd Podcast
Thanks to Justin @ ebikes.ca! Go there, buy stuff. Support the Revolution :D
grindz145
Postby katou » Sun Dec 12, 2010 11:01 pm
Yes Fechter, 2800 kw, but my question, is that overvolted?
Seriously though, I wonder how they deal with the need for sudden spikes of power? Does the diesel just rev up and that's it?
Seems like you'd end up carrying a lot of unnecessary ICE weight, or have pretty terrible acceleration.
What's the 0-100 time on one of those? (unloaded of course)
Katou
katou
Postby spinningmagnets » Mon Dec 13, 2010 1:02 am
Adding conventional 4WD shafts to all the wheels would cause other engineering problems. Trust me, they tried both, and they found some reason they like these (series hybrid?) for the bigger trucks.
spinningmagnets
Postby Hillhater » Mon Dec 13, 2010 1:19 am
Most of those big load trucks are only 2 wheel drive.
The main advantage of the electric transmission is reduced maintenance ( more operating time = $$$) particularly clutches and brakes , which would not last a day without the Retard braking.
Hillhater
1.21 GW
1.21 GW
Postby fechter » Mon Dec 13, 2010 9:24 am
Here's the official datasheet for the MT6300AC:
http://www.bucyrus.com/media/59167/mt6300ac.pdf
"Electric Drive System
Alternator Brushless direct drive
Controls Microprocessor-controlled IGBT
Traction motors W63 triple reduction
Gear ratio 32:1 to 42:1
Speed (maximum) 64 km/h (40 mph)
• The MT6300AC features an all-new AC drive system that can significantly
reduce friction brake wear. This new drive system allows the truck
to transition from full propel to full retard in less than a second, and
the dynamic retarding can fully stop the truck.
Dynamic retarding Max power rating 4,474 kW (6000 hp)
The inverter probably looks similar to this:
I bet that 4.5MW braking resistor is pretty big.
fechter
Postby Hillhater » Tue Dec 14, 2010 5:22 pm
Siemens make many of the drive systems for these trucks.
a few quotes from their site ...
Note the comments about the "Full electric" , Zero emissions, trolley drive system.
Amusing video also ..http://www.youtube.com/watch?v=NY7lBw28 ... re=related
Electricity, not Diesel. A 3,000 hp diesel engine generates the current. So why doesn’t it just propel the truck too? "The reason is simple. It’s just not worth putting the engine and gears of a car onto the slopes of a mine. A gearbox powerful enough to handle the workload required of these trucks would be enormous, and would also need a lot of maintenance," says Köllner, explaining the drawbacks of purely mechanical propulsion.
Not only do the trucks dispense with gearboxes. Thanks to their electric drive systems, they also do without clutches and brake disks in normal operation. Electrical resistors are used to brake the vehicles, and speed can be stepless­ly adjusted via three-phase current frequency. "Such trucks are essentially driven like a car with an automatic gearbox," says Köllner, who is an engineer and has actually driven one of the behemoths.
For over 30 years now, Siemens has been using three-phase current drives for mining vehicles. "The rotating electric field can be transformed directly into mechanical rotation," says Köllner. Some manufacturers, on the other hand, still prefer DC drive systems. In such motors, however, the current has to be constantly interrupted and re-engaged to generate a rotational movement. This limits the revolutions per minute that a motor of this type can attain. And it requires more parts that need to be maintained regularly. "Our alternating current motors can deliver up to seven percent more performance from the same amount of energy, and downtimes for maintenance and repair work are rare," says Köllner. "Generally, just one technology check a year is all that’s needed."
Giant Trucks, Zero Emissions. AC drives also form the basis for a develop­ment from Siemens that can significantly speed up the transport of mining products: trolley trucks. Such vehicles function like streetcars—sporting antler-like pantographs that can be raised and lowered at the press of a button. This means that the driver can link the truck to overhead conductors (catenaries), which are generally installed on steep slopes. "This is where conventional trucks, despite their 3,000 plus hp, can only advance at a snail’s pace," says Köllner. The catenaries can provide the drive systems with almost 6,000 hp. This means that the truck’s speed can almost double, and the mine operators can reduce the number of expensive mechanical giants they need to have on site.
The environment benefits from trolley technology too. There are no local emissions, since the diesel engine switches itself off automatically when contact is made with the overhead line. What’s more, the braking energy that is released when a truck rolls downhill is fed back into the network via a second pair of conductors. Thanks to all these benefits, the technology quickly pays for itself, says Köllner. "After no more than three years, a mine operator can recover the costs of buying the trolley trucks and the costs associated with the installation of the overhead lines."
Hillhater
1.21 GW
1.21 GW
Next
Return to E-Vehicles General Discussion
Who is online
Users browsing this forum: No registered users and 7 guests
