NeilP wrote:No idea..but i can show you my first blown fuse in over 2700 miles
viewtopic.php?f=7&t=33321
ryan wrote:Any one have a better answer for this? I just got a comically huge Maxi 80A fuse and inline holder. I don't have enough room for this monster and am hoping someone else has figured out a smaller alternative.
advancedelectricbikes wrote:Class T fuses are probably the smallest form factor for overcurrent protection. However, they are very fast-acting. Consequently, if you have branch or feeder loads with overcurrent protection other than Class T downstream (in series) with a Class T fuse, a downstream fault will open the Class T fuse and leave the downstream overcurrent protection closed. A short circuit and overcurrent coordination study should be done to spot potential conflicts.
liveforphysics wrote:advancedelectricbikes wrote:Class T fuses are probably the smallest form factor for overcurrent protection. However, they are very fast-acting. Consequently, if you have branch or feeder loads with overcurrent protection other than Class T downstream (in series) with a Class T fuse, a downstream fault will open the Class T fuse and leave the downstream overcurrent protection closed. A short circuit and overcurrent coordination study should be done to spot potential conflicts.
Just as an FYI, the 400amp 160v classT took 6 seconds of 4,000amps to blow.
They are not over-current protection at all. They are cabling/battery fire protection.
Return to E-Vehicles General Discussion
Users browsing this forum: No registered users and 3 guests
