fechter wrote:I wonder if you could stick a strong magnet to one of those automotive fuses to make a magnetic blow out?
DrkAngel wrote:I would guess, that is why the DC voltage is de-rated.
Voltage ratings are factored, partially, by the possible arc length.
Reducing the rated voltage, should reduce, possible DC arcing, to comparable with the higher AC rated voltage.
gensem wrote:Maybe this ll be a good option.
http://www.discountfuse.com/A3T100_p/a3t100.htm
By the specs they would take a little while to blow, what you guys think?
DrkAngel wrote:Couple possibilities.
Bussmann ACK-200 Fuse. 200 Amp, 72 VDC, Dual Element.
ryan wrote:Try an iPhone.
bigmoose wrote:We ought to see what fuses the big Sevcons use that are rated up around 115 V. Might pick up some cost effective ideas.
Doctorbass wrote:The problem remain... fiding a fuse OVER 80VDC , that is cheap, small enough and accessible!
Doc
Doctorbass wrote:The problem remain... fiding a fuse OVER 80VDC , that is cheap, small enough and accessible!Doc
Return to E-Vehicles General Discussion
Users browsing this forum: No registered users and 3 guests
