DIY Aptera knockoff?
Re: DIY Aptera knockoff?
Postby Pure » Sun Dec 11, 2011 2:32 am
That's actually pretty damn close to what I'm thinking. I would reconfig that frame just a little. Remove some of the side reinforcement tubing and add a roll over bar. Leaning and suspension would also be nice.
Mongoose DH
X5304
60V20Ah LiFePO4
I'm polymerized tree sap and you're an inorganic adhesive, so whatever verbal projectile you launch in my direction is reflected off of me, returns to its original trajectory and adheres to you. So there!
Pure
Postby jmygann » Sun Dec 11, 2011 3:23 am
48 V Semi-recumbent
jmygann
Postby TylerDurden » Sun Dec 11, 2011 9:21 am
This is getting close to my ideal; needs EV propulsion.
http://www.tiltingvehicle.com/
Have a Nice Day,
TD
___________________________________________________________
FYI: Adding pictures?
Bored?... take a crack at the unanswered posts
Please post your Watts-at-speed in the survey.
TylerDurden
Postby mistercrash » Sun Dec 11, 2011 10:29 am
Ever since I first saw the Lit C1, I have been waiting for news of it's release. The CEO wants this to happen in 2012 with a price tag of around $16000. I'm crossing my fingers that they will succeed.
http://litmotors.com/home/
Is it ready yet?
mistercrash
Postby jmygann » Sun Dec 11, 2011 12:09 pm
To ...http://www.miltonsandtoys.com/
What is the lightest front sus. for 2 passenger ?
Jim
The lightest frontend is found on a drag buggy in the form of a straight or drop tube front end.Not very practical for a sand buggy .The next lightest is a single a-arm front end.Stewarts buggy shop in waynoka Oklahoma builds that kind of front end so does Prowlers.The next is double a-arm with Marvin Shaw shocks on it.The double a-arm will handle more abuse than the others.The front ends on the red and yellow buggys on my web site is still the most the most dependable and handles more abuse than any other plus it only weighs a few pounds more than the double a-arm.Hope that answers your question.
(MILTON)
Barry Hutton
48 V Semi-recumbent
jmygann
Postby jmygann » Sun Dec 11, 2011 1:19 pm
48 V Semi-recumbent
jmygann
Postby Pure » Sun Dec 11, 2011 4:12 pm
Would be sweet with smaller tubing, singe a-arm, and smaller shocks. I would use small(ish) moto-cross shock offa the bay 80-120 U$ all day long.
http://www.ebay.com/itm/98-99-HONDA-CR- ... 500wt_1180
Mongoose DH
X5304
60V20Ah LiFePO4
Pure
Postby AussieJester » Sun Dec 11, 2011 4:51 pm
The fellas in the USA could always hit up one of those
Aircraft grave yards, pick up an old cessna body, lop the tail and wings, lose the prop, dump it, pop a frock motor in each wheel and then you'd be a rockin' your own DIY Aptera :P
AussieJester
Postby Hillhater » Sun Dec 11, 2011 6:21 pm
Pure wrote: Basically you guys are over thinking this. Instead of shooting for a "licensed" motorcycle class vehicle, you should be looking at just an extended velomobile. ..........
I thought the thread was about replicating an " Aptera" type vehicle ! ?
I dont think the Aptera had any pretensions of being anything less than a EV " car replacement" for regular practical use.
You wont be able to do that with any superlight, un licienced, unregulated, vehicle.
A velo is great for a different role, but not really equivalent to the Aptera.
This is why i said someone should define the basic requirements, or this thread will simply be a dumping space for every daydream in our heads.
Hillhater
1.21 GW
1.21 GW
Postby mistercrash » Sun Dec 11, 2011 6:42 pm
The original OP had this list. It's a good place to start I guess.
Enclosed / all weather
Two seats
Low stepover/threshold
Cargo capacity = > 2 paper grocery bags
Standard wheels/tires
Trailer hitch
I think it should have room for 4 people. Enough cargo for a weeks worth of groceries for a family of 4. A concept simple enough for anyone who is mechanically inclined to fix themselves with some basic tools.
Is it ready yet?
mistercrash
Postby Harold in CR » Sun Dec 11, 2011 6:54 pm
This is what I thought, also. :roll: :roll:
I would try to get involved with the original idea, and, let those that want to custom design stuff, go to their own thread. Getting the first one up and going, would show that big $$$ is not neede4d, and, a CAR is not going to be easy to get past the Govt bunch.
Thanks to Justin, the forum is open source and NON-commercialized.
http://www.costaricacraftwood.com
Harold in CR
Postby HAL9000v2.0 » Sun Dec 11, 2011 7:35 pm
Here is a quick sketch of what I have in mind...
3m long 1,8m wide 1m high 2 seats, all wheel drive...
(34.81 KiB) Downloaded 3 times
drw0001.pdf
(684.57 KiB) Downloaded 86 times
HAL9000v2.0
Postby jmygann » Sun Dec 11, 2011 11:59 pm
What do you see as a budget for this "knockoff". It is a tadpole trike for 2 - side by side.. "" Aptera" type vehicle "
48 V Semi-recumbent
jmygann
Postby TylerDurden » Mon Dec 12, 2011 12:12 am
I was envisioning a truss foundation, packs up the tunnel. (for a non-leaner)
Have a Nice Day,
TD
TylerDurden
Postby jmygann » Mon Dec 12, 2011 2:10 am
48 V Semi-recumbent
jmygann
Postby Hillhater » Mon Dec 12, 2011 2:21 am
jmygann wrote:What do you see as a budget for this "knockoff". It is a tadpole trike for 2 - side by side.. "" Aptera" type vehicle "
you cannot attempt to estimate a budget until you have a fairly detailed specification including speed, range, payload expectations etc.
If you start with a budget, you will end up with a vehicle that meets your budget , ..not to your requirements.
... Project basics 101 !
Hillhater
1.21 GW
1.21 GW
Postby TylerDurden » Mon Dec 12, 2011 9:05 am
I would also suggest that designing/building be approached in a scaleable manner that reasonably allows the most people to build and/or collaborate, while letting nutters go over the top.
Off-the-shelf components and standard materials for basic building - nutters can use unobtainium and Ferrari/CISRO motors.
Have a Nice Day,
TD
TylerDurden
Postby Thud » Mon Dec 12, 2011 9:23 am
Aptera=
superior aerodymanics
composit construction
cool to a fault (if your into that kind of thing)
everything else is standard 3-wheeled Ev construction.
the longer I look at the RQ riley designs the more reasonable they look. :wink:
get some......
Thud
Postby Harold in CR » Mon Dec 12, 2011 9:37 am
If anyone is seriously interested in starting this project, here are some specs to begin the figures and start up budget. I have been away from the States, and, have no access to supplies, but, I know places in S Florida I used to deal with.
Dimensions:
53" high x 91.0" wide x 173" long
111" wheelbase
80.5" front track.
Other specs:
0.15 Coefficient of drag
5" ground clearance
1500 lbs curb wt.
Electric motor torque: 60FtLb torque
110v 15A charge time: 8 hrs.
Battery output: 10-13 KWh battery pack.
Battery voltage: 336V DC Nominal Traction Voltage
Transmission: Gear box 10:1 ratio
Battery Type: Lithium Iron Phosphate
Chassis:
Front Suspension: Independent unequal length A-arm
Rear Suspension: Swing Arm
Steering: Manual Steering, tilt steering column
Brakes: Manual Brakes, dual circuit brake hydraulics, mechanical brake proportioning, 3-wheel disc
Wheels: 14-inch High Strength Stamped Steel wheels
Performance:
Range: Up to 100 miles per charge
To make this a "Near" clone, I was thinking to research tail light shapes, head light covers, windshield shapes, and such, to buy after market to get the design formed up.
Who wants to be the first to put definite buying or funding plans on the table ?? If this is done 1-off, there is no "Company" to hold liable and buyer sponsor gets the first one as a "prototype. I doubt if this will end up selling millions, but, it's the only way for those with REAL interest to actually have a clone of sorts.
Need more interest before I can put more thoughts into this. Talk is cheap. I would have to live IN the shop or someones garage to be able to do my part. Hot dogs and beans would carry me a long ways.
I have been toying with selling my farm and going my separate way with my ideas. Just would like to be a part of something like this project.
Harold in CR
Postby jmygann » Mon Dec 12, 2011 11:17 am
Reverse trikes have been designed and built for years ... some are electric. We are not trying to re-invent the wheel. I feel a frame builder interested in the project is needed more than someone playing with CAD on their computer.
http://switchvehicles.com/ .... " Our mission is to build safe, simple, durable electric vehicles that every American can afford to own."
"Toyota, Chevy and Nissan have helped increase demand for electric cars, but their prices are too high for the average American. There’s a gap between what the big car makers are selling and what most Americans can afford. Enter Switch Vehicles. We fill this gap with a locally-built, reliable electric vehicle for daily transportation.
Initially, the Switch will be available as a kit that is shipped to the owner for do-it-yourself assembly."
http://www.youtube.com/watch?v=U2bwcHod ... page#t=55s
[youtube]U2bwcHodp5w&feature=player_profilepage#t=55s[/youtube]
48 V Semi-recumbent
jmygann
Postby TylerDurden » Mon Dec 12, 2011 12:18 pm
jmygann wrote:Reverse trikes have been designed and built for years ... some are electric.
That must be why we see so many. :roll:
jmygann wrote:We are not trying to re-invent the wheel. I feel a frame builder interested in the project is needed more than someone playing with CAD on their computer.
Tell that to Greyb.org.
A new common platform is required, like the VW pan from the kitcar era; but this era needs an open-source hybrid/EV platform. With a simple design, framebuilders worldwide can supply the base.
BTW... The Aptera was a four season vehicle, not an electric dune buggy.
Have a Nice Day,
TD
TylerDurden
Postby patrickza » Mon Dec 12, 2011 1:51 pm
I quite like the switch, it ticks my boxes, but mainly because I'll need a central driving position as I currently live in a right hand drive country but would switch to left and most likely back and forth in my future. Also 3 seats is enough I think.
How many kwh's of lithium do you think the front battery box would hold?
Greyb.org, Cromotor, Headway 83.2v 20AH, Lyen 18 fet: viewtopic.php?f=3&t=45514
Kona Kahuna, x5305, Headway 76.8v 10AH, Crystalyte 72v48A: viewtopic.php?f=3&t=10256
Bladez Scoot, 450W motor putting out 3kW, Headway 38.4v 10AH, Lyen special controller: viewtopic.php?f=35&t=25872
patrickza
Postby Hillhater » Mon Dec 12, 2011 5:06 pm
The Switch appears to be a very nicely engineered package , but....
.. It would need an enclosed bodywork to meet "everyday" practicality and reasonable aero efficiency to improve power usage .
Maybe that is an oportunity to "personalise" the vehicles, but i suspect many builders would want the option of shop made bodywork. Have Switch planned that option ?
Also, unless the chassis are available at a sensible price ( shipping may be expensive also ?) , its design using many compound curved tubes would make it an impractical self build project for the average home garage builder,
A simpler chassis design / construction would be needed to make it workable for most amateur builders.
Hillhater
1.21 GW
1.21 GW
Postby jmygann » Mon Dec 12, 2011 6:17 pm
Speed - 30 mph
Range 50 miles
2 passengers (preferable side by side)- 360 lbs
tadpole style
Rolling frame only , 2000 watt motor to be supplied
Curb Weight ... 280 lbs without batteries
48 V Semi-recumbent
jmygann
Postby TylerDurden » Mon Dec 12, 2011 6:27 pm
jmygann wrote:Speed - 30 mph
Range 50 miles
tadpole style
That's a golfcart with a missing wheel.
Have a Nice Day,
TD
TylerDurden
PreviousNext
Return to E-Vehicles General Discussion
Who is online
Users browsing this forum: No registered users and 2 guests
