Persanity wrote:.... One idea I have been toying with is replacing the floor in non uni-body vehicles with a uni-body type floor made with stamped structural components based on uni-body structural details taken from the worlds safest uni-body car, no idea what vehicle that'd be just yet, with high crash test rating.....Hillhater wrote:Sorry but, by definition a "unibody" design depends on the totality of the body structure for its strength...door pillars, window surrounds, roof panel etc, etc. You CANNOT just take the floor pan design from a unibody and use it under a set of body panels.
..BIG Fail !
I suggest you focus on your drivetrain package .
Not to argue....
Based on the definition of a uni-body design I could do exactly that.
Do you think a S10 truck cab isn't designed exactly like a uni-body? Except without stamped frame rail in the floor of course.
If you made a new stamping of a S10 floor designed to have the uni-body body frame rails built into it, braced the inner body and roof, then took the original floor out and replaced it with the new uni-body floor the cab would be just as ridged as a uni-body car. Car and truck bodies aren't made in one piece, uni-body or not.
Persanity wrote:.... Lower overall vehicle weight is achieved by getting rid of the full frame on non uni-body designs, like the mini-trucks do with custom "dune buggy" tubular frames. Using stamped parts to replace vehicle stamped parts is better then having a tubular frame because you can rapid prototype in a computer with stamped parts......
Hillhater wrote:Are you aware of the tooling and manufacturing set up costs to produce "stamped parts" ?.
..you would require huge volumes of any one design for this approach to become economical...even assuming you could produce an effective design without expensive prototypes and testing with minimal redesign/re tooling costs.
You seem to have a pre occupation with rigid chassis, rigid axle, heavy vehicles. .. IE:- commercial Trucks & Vans ! ..why ??
If you really.... "want to make it available to the average Joe for as cheap as possible".... you need to familiarise yourself with the type of vehicles "average Joe" drives ...and...... focus on your drivetrain package . !
Yes, I am aware of the massive costs involved. I have developed a new stamping process/type of stamping machine for rapid prototyping of full sized car parts. I have a small non-computer controlled prototype of a much larger computer controlled machine I desperately need to get patented. One more reason I am in involved in a start-up accelerator program.
All my conversions would most certainly not have rigid axles. They would be 4 wheel constant variable axles with motorized differential, like the rear wheels of a Toyota Highlander only AWD.
