I'm interested in finding out where I can purchase a 60 or
a 72 volt 12 inch hub motor e-kit to fit a T12 electric Trikke.
I need more power to climb hills and want 24 MPH on the flats.
All help will be appreciated.
Ed J
Ed J wrote:I need more power to climb hills and want 24 MPH on the flats.
Lock wrote:Hi Ed.
If I may re-state your situation:Ed J wrote:I need more power to climb hills and want 24 MPH on the flats.
24mph on the flats is a "no brainer" BUT what speeds are we talking about on the "hills" (what angle of slope and for how long and at what speed and at what weight, rider(s) +bike +cargo)
Beyond POWER to "giddy-up-and-go" EVerwhere, ya need to acknowledge needed ENERGY-storage (the amount of stored onboard energy - usually expressed as "Wh" - to get you and yours the whole distance between plug ins, in style and fully entertaining at the same time...)
Lock
amberwolf wrote:Golden motor makes some motors including a Magic Pie that basically have the rim on the motor's outer circumference.
parabellum wrote:I would take last one!It is little heavy, will probably not fit your dropout but who cares, you can climb a vertical wall after all.
Ed J wrote:If these people don't carry the associated throttle assembly,
where would I get the motorcycle type twist throttle? And
also the battery that I will obviously need to power it.
parabellum wrote:Ed J wrote:If these people don't carry the associated throttle assembly,
To power this beast you will need suitable controller first. Who sells controllers, sells throttles. Lyen for example.
For battery I would choose RC LiPo for those power levels or A123 at least, if you do not want to carry trailer with 200lbs of batteries in it. It looks like this motor can swallow over 10KW for extended periods (if 5KW is written on it). I do not think your trike can handle such a beast and then again not as front wheel.
Ed J wrote:parabellum wrote:Ed J wrote:If these people don't carry the associated throttle assembly,
Hi Parabellum,
I only like to ride for about 20 minutes at a time,
but sometimes as long as 45 minutes. What
battery would you recommend for this?
Ed J
Ed J wrote:What about this one?
http://www.china-electric-scooters.com/ ... 53536.html
The 12inch hub motor is our new designed hub motor,different from previous 12inch motor. We developed the wheel and inside parts,make it better working and higher quality. And now it is very popular in Ansi and Europ market.
This kind of hub motor is specially designed for big Electric scooter with high torque and high speed. The max rated power we designed can be 1.5kw--- 5kw,which will make your scooter run a max speed about 100km/h.
Main Specification for this motor as bellows,
Item: 12inch Brushless Hub Motor
Model NO.: HS121500-5000
Motor Type:Brushless Hub Motor
Rated Voltage: 48V/60V/72V
Rated Power: 1500W-5000W(For your choice)
No-Load speed:600rpm-1300rpm
Max efficiency:85%
Max torque:200N.M
Wheel: 12inch Aluminum wheel
Climbing ability: ≥25o
Gross Weight:17.5KG
Brake Type:DISC Brake.
Ed
Return to E-Vehicles General Discussion
Users browsing this forum: No registered users and 4 guests
