Hi Parabellum, Won't pumping higher voltage into a 36 volt motor - burn it out faster?
I want a bigger frame for the higher speeds,
BUT, I would like the litter one go faster as well.
The frames weigh about the same: 36 LBS,
the litter T78 deluxe frame is made of steel,
while the larger T12's frame is made of aluminum.
________________________________________________________
There is a manual aspect of propulsion that you add by
"rocking" side to side while you're kicking like rollerblading.
Thus, the larger frame will be better at speed in these two ways.
This aspect of helping it to - keep the speed - has
a certain conservation to the battery as well.
Therefore, I would like to maximize my "speed to weight ratio".
Modifying a T12 with a 60 volt e-kit seems to be the best answer.
Where do I find this mini beast motor and all the associated parts?
I need some "serious" help on the hills.
I would like to top out at 24-30 MPH
and get about 20 miles of travel.
Ed J
PS. a new controller and better battery
sounds like the answer for the smaller one.
