ProDigit wrote:I'm sorry, I don't know under what category they would fall, in Europe they are seen as scooters, in USA scooters are defined as 2 wheeled devices without seat.
Lebowski wrote:what do you mean, Americans are 2 years behind ? I would rather call it ahead![]()
http://www.zeromotorcycles.com/
They could use a proper controller though
[/quote]
ProDigit wrote:With 5 or 6 models, they're not a small company!
Where are the americans? 2 years behind!
http://www.emco-elektroroller.de/de-nl/ ... novum.html
I'll be damned if all of those models aren't Chinese catalog items as found on alibaba.com. "Company" my ass--they're just another importer of crap.
crossbreak wrote:ok, this is austrian but it's still far ahead, if you don't look to close on curves
Toshi wrote:ProDigit wrote:With 5 or 6 models, they're not a small company!
ProDigit wrote:Toshi wrote:I'll be damned if all of those models aren't Chinese catalog items as found on alibaba.com. "Company" my ass--they're just another importer of crap.
It's very unusual for Holland or Germany to get their stuff made in China.
If they do, they have it from a closed circuit, nothing you can find on Alibaba.
You can also look at the price, comes with disc brakes, abs I presume, motorcycle wheels, not those thin bike wheels you see Xtreme putting in their budget series, and to me it looks like they've worked the body around the batteries, not dumped a battery pack in an empty cavity in the floorboard (like with Chinese).
It's definitely not Chinese designed, if that's what you're asking.
But then again, I'm not so familiar with the $3500+ bikes.
ProDigit wrote:the motor they're using is more expensive, a 96V engine, but it's much more efficient according to the website, as well as according to the specs.
So far most e-bikes in USA are utilizing the 48V engines for their entry bikes, though I don't know much about the more expensive ones sold in USA.
liveforphysics wrote:You know the voltage makes no difference in performance or efficiency or heating or anything like that right? You could have a drive train running 24v absolutely dominate in every way a drivetrain running 150v.
Did you read what Luke wrote?ProDigit wrote:perhaps the voltage does differ somewhat. Higher voltages means less heat resistance, granted that heat is probably only a fraction of the byproduct of a motor.
Miles wrote:liveforphysics wrote:You know the voltage makes no difference in performance or efficiency or heating or anything like that right? You could have a drive train running 24v absolutely dominate in every way a drivetrain running 150v.Did you read what Luke wrote?ProDigit wrote:perhaps the voltage does differ somewhat. Higher voltages means less heat resistance, granted that heat is probably only a fraction of the byproduct of a motor.
I'm sick of this BS marketing about a 48V motor being better than a 36V one etc.
Miles wrote:I suggest you learn the most basic motor theory before you start pontificating on here... A motor is not a simple resistive load.
ProDigit wrote:Another thing, higher voltages result in lower amps flowing through the coils, which means they can reduce the copper wire's size.
they'll maintain nearly the same electromagnetic field (resulting in the same torq), while developing a smaller, and lighter motor.
Apparently not.ProDigit wrote:I've graduated from electro mechanics in school, which gives me enough background knowledge to judge the basics of these topics.
amberwolf wrote:ProDigit wrote:Another thing, higher voltages result in lower amps flowing through the coils, which means they can reduce the copper wire's size.
No, becuase to get the same power output at the same speeds, they still need the same total copper in there.
It would need a different drivetrain, gearing the motor down from a high speed, to reduce the motor size and still get the same power and speed out of it at the wheel.
flathill wrote:What happens when you have zero resistance superconductors?
P=v^2/r
power goes to infinity as r goes to zero?
No
voltage doesnt exist only flow
We measure abstract pressure
It is all about apparent resistance
Very Low voltage and high current doesnt work well with silicon due to poor current sharing
Otherwise we would have mainstream homopolar motors
You can use magnetic amplifiers though
http://en.wikipedia.org/wiki/Magnetic_amplifier
Return to E-Vehicles General Discussion
Users browsing this forum: No registered users and 3 guests
