mcstar wrote:Here's some math to make it concrete...
At 25mpg if you drive 10K miles => you burn 400Gallons @ $3.80 == $1520
At 27mpg if you drive 10K miles => you burn 370Gal @ 3.80 == $1470
Savings == $50 if you're consistent
At 25mpg if you drive 20K miles => you burn 800Gallons @ $3.80 == $3040
At 27mpg if you drive 20K miles => you burn 740.7Gal @ 3.80 == $2814
Savings == $225 if you're consistent
oldpiper wrote:
Instead of electrolyzing water, he is pumping a bucketload of energy into it, raising the temperature "to 1500 C" (certainly possible here), producing superheated steam at the surface of the water. The escaping steam carries dissolved ions in it, and at 1500 C (or actually quite a few degrees lower), metal atoms in particular emit visible light: sodium: yellow, potassium and calcium: red, etc. So it's easy to get a yellow-orange "flame" which is not a flame at all. If he really had found a way to electrolyze, then burn salt water, then putting his hand into the microwaves would catch it on fire quickly. After all, what is blood? Salt water with some other junk (cells, proteins, cholesterol) floating in it. (By the way, when hydrogen burns, it produces a very faint bluish flame, not yellow-orange.)
Return to E-Vehicles General Discussion
Users browsing this forum: No registered users and 3 guests
