so i can calculate what will match my desired riding speed?
i ask because i read this
Your efficiency will depend on whether your motor is suited to the task at hand. A motor that is too powerful waste a lot of energy spinning its own magnets/electromagnets past each other. A motor that is under-powered will waste energy if, when you run it at full throttle, it is still not able to reach its range of ideal operating speeds (at least ~50% of the speed that the motor turns with the wheel off the ground). Ideally you'll have a motor that will be running at about 80% of its maximum no-load (wheel off ground) speed most of the time.
also i am not good at math thank you
