markz
100 TW
I'm replacing my gearset. I started another thread on which component line to use.
When you are riding the MXUS 3kw (or similar) what gears are you running front and rear?
Looking at the 48, ##, 26 vs 44, ##, 22 vs 42, ##, 22. I am thinking I dont need a high tooth on biggest gear, so a 44 or 42 then replace the 22 with a 20 for hill climbing to help the motor out. My theory is when cruising at speed no need to pedal, but stop and go the motor would need help with wh/distance.
What are people using for the rear gears?
I used a random freewheel on mine, I think it was 16T, but I was lazy and never pedaled.
