looking for ideal base for electric car conversion
izeman
10 GW
10 GW
Re: looking for ideal base for electric car conversion
Post by izeman » Nov 15, 2017 1:51 pm
fun. fun of building it, and fun of driving it. no need for it. just like my ebike, my quadcopter and my 3d printer. tinkering as a hobby :)
www.recumbents.com
Post by www.recumbents.com » Nov 15, 2017 2:59 pm
Junkyard is a good idea. Many cars are junked because they have expensive to fix engines/transmissions/transaxles and these would make good candidates. Maybe an older Jaguar, Maserati, or Citroen 4 door...
John in CR
Post by John in CR » Nov 27, 2017 6:34 pm
My buddy has 4 Haflinger's in various stages of completion. I've finally convinced him that it's the perfect electric conversion candidate, which we'll do this dry season
Quite light- just over 600kg stock
Low power- 25-30hp ICE engines depending on the year. A pair of my HubMonsters should fit the bill nicely.
Low speed- This 4x4 isn't for going fast.
Flat roof- Perfect for solar panels.
Short range- At his farm anything more than 10 miles use in a day would be unusual, so we're talking a relatively small battery pack that would never need to plug in due to more than 2 meters of flat roof for solar panels.
I think this is the version he has:
izeman
10 GW
10 GW
Post by izeman » Nov 28, 2017 2:18 am
at least an austrian car :) nice to see them again.
already did the other thing around. we planted an american 4.2l 6-zyl with automatic transmission into a pinzgauer ;)
Drunkskunk
Post by Drunkskunk » Dec 04, 2017 7:39 pm
Bet that was fun! Was it the Jeep's 4.2?
Monster Bike:https://endless-sphere.com/forums/viewto ... =6&t=38667
izeman
10 GW
10 GW
Post by izeman » Dec 05, 2017 4:43 am
could be. been some time that he did it. it was transplanted into a pinzgauer 6x6. lot of other modifications as well: all 6 disc-brakes and power steering etc ... quite a nice rallye truck.
blisspacket
Post by blisspacket » Jan 21, 2018 9:07 am
I did the search here, found no entries on MB 250e.
It's the Benz all-electric hatchback. Used off-lease for less than $25k.
AND it desperately needs a conversion: equipped only with a slow charger, single phase.
Surely some wizard here could come up with a rapid-charge conversion that would make this a viable alternative??
blisspacket
Post by blisspacket » Jan 21, 2018 6:07 pm
I'd forgotten: The Benz 250e is closely allied with Tesla, and thus probably carries a battery bank of 18650-type batteries. These don't inspire confidence in me, there's just too many of them, too many connections, too mind boggling....
Ribiero
100 µW
100 µW
Post by Ribiero » Jan 21, 2018 6:10 pm
Hi Izeman. May I suggest an Opel Calibra. Much larger than a CRX and way more numerous. .26 cd,1200kg. Parts I would think are cheap and easily available. As there was a 4wd version, there must be space for a diff at the rear of a regular fwd to make rwd. Probably use a shortened prop and diff from an eclass. Airbags,Abs,side impact beams,tc.. Not exclusive but stylish. Good luck.
markz
Post by markz » Jan 21, 2018 9:22 pm
I've been pondering doing an ev for quite some time. I think a great vehicle base would be the 4 door Geo Tracker or Suzuki Sidekick. It weighs in at 2200 lbs curb weight, has 1.6L 4cyl topping out at 95HP or so and can be had for dirt cheap. You can buy a newer one for dirt cheap, and gut it out. I am thinking hybrid, so keeping everything, and somehow figuring out how to implement electric into the drive train.
LockH
Post by LockH » Jan 21, 2018 9:55 pm
Watts it called? "highway speeds and a 200km range"... Sorry, for many "urban", 21st-Century folks it's a "foreign concept".
Where "high speed" travels (on land, using a wheeled vehicle) involves "beating the competition" ie options like the horseless carriage ("car"), pubic transportation (sp?) vehicles... etc.
... so in "EV-terms" one might ask "Hard to pedal?"... and lots of empty seats? ... plenty of (empty) cargo spaces?
... and might conclude that any "large" and "heavy" vehicle (that you can't assist by pedaling from starts, up hills/against gravity/etc.) is probably not the "best" in "saving money" terms. Alternatively, one can spend LOTS of money and forego stuff like vacations...etc. ... and etc.
:wink:
https://endless-sphere.com/forums/viewt ... =3&t=57408
https://endless-sphere.com/forums/viewt ... 15&t=60564
