Early scooter, gas or electric?
motomech
Post by motomech » Nov 12, 2017 5:50 pm
Dated 1916.
Motomech
'03 Rocky Mountain Edge 2WD 260 Q100H frt and Ezee V1 rear 2 Elifebike 20A & 25A 9-FET controllers 12S/20Ah Multistar Lipo rear 5Ah Turnigy frt Luna Cyclops Extra lite Alex 24DM rims, 2.4 Holly Rollers run ghetto tubeless. 25 mph. Mean Well HLG-320H-48A
https://endless-sphere.com/forums/viewt ... =3&t=83430
'07 GT Idive 4 4.0, Q100C 201 12S LiPoly elifebike 9-FET 17A controller. 20 MPH.
https://endless-sphere.com/forums/viewt ... 8#p1237928
motomech
1916 scooter
Post by motomech » Nov 12, 2017 5:52 pm
I think it's electric.
Photo dated 1916.
Motomech
mark5
Re: 1916 scooter
Post by mark5 » Nov 12, 2017 6:05 pm
Very cool. Wikipedia says the Autoped scooter had a 4-stroke 155cc or 191cc engine but an electric motor was available.
https://en.m.wikipedia.org/wiki/Autoped
http://mashable.com/2015/06/15/1916-suffragette-scooter/#ylzMww41gZqK wrote:1916
Suffragette on a scooter
Lady Florence Norman on her Autoped.
by Chris Wild
Yes, she is a suffragette, and yes, that is her scooter. English socialite and activist Florence Priscilla, Lady Norman, CBE was given this Autoped as a birthday present by her husband, Sir Henry Norman. She used it to travel to her office in central London.
Florence was following in her mother's footsteps in her active support for women's suffrage. Her CBE (Commander of the British Empire) came when she ran a hospital in France during World War I.
Kick scooters — a flat board on wheels with a long handle at the front, propelled by foot — have been made for at least 100 years as toys for children. Florence's Autoped was one of the first examples of motorised kick scooters. Like a child's scooter, it had no seat.
Manufactured in New York and Germany by Krupps, the U.S. postal service tested the Autoped as a means of fast transport for its special delivery service. The foldable scooter was also reportedly used as a quick getaway machine by New York gangs, racing down narrow alleys beyond the reach of police cars.
Other manufacturers followed: ABC Motorcycles produced the Skootamota, which had a top speed of 15 mph (24 km/h), and The Gloster Aircraft Company introduced the Reynolds Runabout in 1919, followed by the Unibus in 1920. The Unibus was promoted as the "car on two wheels."
Some of these early scooter designs were unstable, uncomfortable to ride and difficult to handle. The decades leading up to World War II saw the gradual introduction of a range of refinements, including efficient lights and brakes, gears, suspension, enclosed bodies and leg shields.
During the 1930s, scooters were introduced to a new market as the ideal mode of transport at large, sprawling military bases. Ironically, the era of the scooter truly began after the war — a direct result of fuel rationing.
1918 Eveready Autoped Scooter
http://www.oldbike.eu/museum/engines/19 ... d-scooter/
amberwolf
Re: Early scooter, gas or electric?
Post by amberwolf » Nov 12, 2017 9:41 pm
markz
Post by markz » Nov 12, 2017 11:52 pm
Its an in the wheel motor, I've seen them before online.
The box in the middle of the platform I read is the battery for the lights.
The giveaway for gas scooter is the soda can nearest the camera, with the silver tube, must be a gas line to the gas tank on the other side.
mark5
Post by mark5 » Nov 12, 2017 11:56 pm
There's 4 dry cell batteries in the box in front of her feet. And an ignition coil.
http://amhistory.si.edu/onthemove/collection/object_307.html wrote: Autoped motor scooter
From the Smithsonian Collection
This lightweight scooter was built in 1918 by the Autoped Company of America, Long Island City, New York. It bears the number D3201 on the left side of the engine.
The 4-cycle engine, mounted on the left side of the front wheel, has an air-cooled integral-head cylinder bolted to a circular crankcase. In front of the cylinder is a breather tube that protrudes from the top of the crankcase; the carburetor and muffler are behind the cylinder. The Breeze carburetor has a screw-adjusted air intake, and its needle valve is operated by a small knob bearing numbers for convenience in adjustment. A shutter serves as a throttle control. On the side of the intake manifold is a small priming cup. The intake valve is automatic and the exhaust valve is cam operated.
The engine is geared to the wheel by means of a disk clutch. The flywheel, on the right side of the front wheel, contains a 6-volt lighting generator that originally furnished current for lighting and ignition, but the system later was altered by the addition of an ignition coil and four dry-cell batteries. The ignition switch is mounted on the right side of the frame, and the gasoline tank is above the front fender.
All control of the vehicle is through the steering column. Turning the column steers the machine in the conventional manner; pushing it forward engages the clutch; and pulling it back operates the internal, expanding brake on the front wheel. Turning the left grip operates the throttle, and turning the right grip operates the compression release through a wire controlling the opening and closing of the intake valve. A hand Klaxon is mounted on the left grip. The steering column can be folded down and secured to the rear fender for compactness in storage.
A headlamp is mounted at the right of the front wheel, and a tail lamp, on the rear fender. The operator stands on rubber pads on the frame of the vehicle. A two-pronged stand, attached to the underside of the frame, is operated by means of a pedal that extends through the floor.
A utility box, mounted toward the front of the machine, now contains the batteries that were added to the electrical system; an ignition coil is mounted just in front of the utility box.
The 15-by-2 1/4-inch pneumatic tires, made expressly for this vehicle by the Empire Rubber and Tire Company, Trenton, New Jersey, bear the inscription "Auto Ped Tire, Empire red, non-skid."
