Step Down EV battery voltage for lights, alarms, etc
Pegasus195
Post by Pegasus195 » Nov 15, 2017 11:03 am
So I've been looking for ways to power my headlight for my ebike DIRECTLY from the battery, with a device through it probably. These days, I power my ebike with 1 18650 cell, and needs to recharge it seperately. I want to have an output from my battery (48v) step down to 5v for some low voltage uses such as phone charger, alarm, lights, horn, etc. I found a step down board called lm2596, but It's limited to 50v, while a fully charged 48v battery can go up to 54.8v, and I'm afraid of damaging it. Maybe some ebike controllers do have a 5v output for these, but I'm using some chinese bldc controller, that seemed lack of this feature. Maybe any other solutions you all have? Hope I can find a way...
DARE TO EXPLORE EV
My Projects:
350W Prototype ebike
1500W Custom Full-Aluminum Motorycle-killer(ongoing)
500W electric scooter (ongoing)
2.2KW electric vehicle (ongoing)
Custom electric skateboard (ongoing)
Recommend me some ideas, I got 6 unused (yet) ebike hub motors, and 2 unused(yet) Motorcyle/scooter hub motors
kdog
Re: Step Down EV battery voltage for lights, alarms, etc
Post by kdog » Nov 16, 2017 5:57 am
Try an AC-DC smps ( wall wart) of suitable voltage and amps on the out put. plug AC side into main battery, if it doesn't work battery voltage might not be high enough. I run my lights directly off my ebike battery... Works great.
captain387
Post by captain387 » Nov 16, 2017 6:29 am
Some wall warts will work, and I have done this in the past.
If you are looking to go with the LM2596 for size try searching for LM2596HV aka High Voltage.
This will take the upper limit to 57v
04 Norco Atomik - Cycle Analyst - Hs3540 - 40amp Infineon Controller - 12s2p 5.8 Ah Turnigy Lipo
95 GT Timberline FS - Converted back to pedal only.
wturber
Post by wturber » Nov 24, 2017 10:41 pm
I use one of these - which puts out 12v.
https://www.amazon.com/gp/product/B0151 ... UTF8&psc=1
I further down-convert to 5v for USB based devices using a car accessory plug to USB adapter.
This version goes directly to 5v if you have no use for 12v.
https://www.amazon.com/uxcell-Converter ... 60+v+to+5v
Note that the electronics are potted in epoxy. So these are pretty waterproof.
"Commuter - DC Booster"
7 x 36v 4.3ah 10s 2P battery packs - Wangdd22 1500W 30A DC Boost Converter delivers 54v and about 1175 watts peak
https://endless-sphere.com/forums/viewt ... =2&t=90369
Pegasus195
Post by Pegasus195 » Nov 25, 2017 7:59 pm
Thanks all, those information are very helpful
DARE TO EXPLORE EV
My Projects:
