Electric go kart power train design
Transistor
Post by Transistor » Nov 28, 2017 4:20 am
I'm to design the power train of a electric go kart for a competition. I'm having problems with numbers.(considering vehicle dynamics like air drag, rolling restiance)
Competition rules and restrictions on power tarin :
Max motor rating :2500w
Max battery ratings: 48v 35ah
Max system current:60a
What I'm trying to achieve :
Speed of 40-60kmph(I know 60kmph is probably far fetched with even 2500w motor)
Total runtime of 75minutes
Acceleration of 0.8-1m/s^2
Assumptions:
Kart weight: 180kg (if lead acid batteries)
Rolling resistance: 0. 01
Coeff of drag:0. 88 (not sure about this no)
frontal area of kart:1. 19m^2 (not sure about this either)
Radius of wheels: 0. 14m
*feel free to recommend appropriate numbers for coeff of drag and frontal area
Help me arrive at the required motor and battery spec. I arrived at the following numbers:
8Nm for 0.83m/s^2 acceleration
862.6rpm for 45kmph max speed
I'll show how I came to these numbers after I learn how to upload pics here. This is my first post here
Because future is electric
Hillhater
Re: Electric go kart power train design
Post by Hillhater » Nov 28, 2017 6:51 am
Which is most critical...
Speed
Distance covered
Or run time ??
But either way, use lithium batteries as you will get much more energy (Wh) out of them than lead acid of the same Ah and voltage rating..
Transistor
Post by Transistor » Nov 28, 2017 8:07 am
Run time. 75minutes on a go kart track of 1. 2km. That's my first priority. Then is speed, above 40kmph.
fechter
Post by fechter » Nov 28, 2017 9:46 am
The top speed will be limited by the input power and the aerodynamic drag. The Grin motor simulator will give you some idea what changing parameters does to performance:
http://www.ebikes.ca/tools/simulator.html
For sure avoid using lead-acid batteries. Lithium batteries of the same capacity will deliver about twice the run time and be 1/3 the weight.
I think the critical part will be motor choice and getting the gearing optimized. The rest is constrained by the rules. Better aerodynamics will be important too.
Hillhater
Post by Hillhater » Nov 28, 2017 4:36 pm
Be sure to configure the kart as a "Enduro", or lay back seat design to minimise drag.
lay down kart
And get a bearing hub for one rear wheel to cut out the cornering drag from the solid axle (single wheel drive)
