borko444   100 W
Re: Votol EM-100 & EM-150 controllers
Post by borko444 » Sep 15 2019 3:28pm
:bigthumb: :bigthumb: :bigthumb:
Rs.Anton   1 mW
Post by Rs.Anton » Sep 17 2019 7:57am
Does votol have built in 12v line witch i can use for high brake enable?
borko444   100 W
Post by borko444 » Sep 17 2019 8:55am
!!!!The controller does not have 12 volts!!!.
You need to buy and use a 48V - 96V to 12V converter,
Like the one from the link
https://www.ebay.de/itm/DC-48V-96V-To-1 ... 0012.m1985
s-l1600 (1).jpg (69.32 KiB) Viewed 1531 times
Lalusonny   100 µW
100 µW
Post by Lalusonny » Sep 18 2019 10:45am
Lalusonny   100 µW
100 µW
Post by Lalusonny » Sep 18 2019 10:50am
Please Help Me No Response
No Reponses
borko444   100 W
Re: Votol em-100 controller
Post by borko444 » Sep 18 2019 11:28am
larsb wrote:
Nov 02 2018 4:20am
The controller needs connection to B+ (full battery voltage) to the correct wire to turn on. see pic.
or rotate the start key to the start position.
orphenw   1 µW
Post by orphenw » Sep 18 2019 11:53am
Hello, if for someone it is useful, I share my data of my controller, which came from the factory. :bolt:
The motor is 4000W QSmotor
72v 60A battery
and EM-100 controller
Maximum speed 85km / h :!:
borko444   100 W
Post by borko444 » Sep 18 2019 12:59pm
larsb   1 MW
Post by larsb » Sep 18 2019 2:16pm
Lalusonny wrote:
Sep 18 2019 10:50am
i am no expert on serial communication so i can only guess:
Are you sure controller is ON? (Not always remembered)
Is ch340 driver updated and have you tested that it works with other serial communication than the controller?
I have only used PL2303 adapter which is the adapter supplied by QS motor. It’s not that expensive so i’d try an adapter like this if you cannot get the ch340 that you have to work.
Good luck.
Ride on!
orphenw   1 µW
Post by orphenw » Sep 18 2019 5:06pm
larsb wrote:
Sep 18 2019 2:16pm
Lalusonny wrote:
Sep 18 2019 10:50am
Good luck.
I used a Cp2102 (typical for Arduinos) connect TX and RX respectively, the negative one took it directly from the negative of the controller because the negative of the connector did not work for me ... as the diagram is shown
borko444   100 W
Post by borko444 » Sep 18 2019 5:25pm
larsb wrote:
Sep 18 2019 2:16pm
You have only used PL2303 adapter which is the adapter supplied by QS motor und Votol EM ****.
Anything other than the recommended (PL2303) and windows 7-10, you will need to solve for yourself by using the well-known trial / error method.
In the standard case, he will definitely find help here
borko444   100 W
Post by borko444 » Sep 21 2019 8:49am
I want some more help.
How the motor responds to the specified parameters for undervoltage(V) 61V and soft 64V
What exactly happens at 61 Volts and at 64 Volts soft
larsb   1 MW
Post by larsb » Sep 21 2019 10:53am
borko444 wrote:
Sep 10 2019 9:49am
Normally regeneration is connected to the brakes. It is high-level and has a green cable at the 8th output of the plug.
I do not know where it is activated and how it is set up.
do you have no regeneration function? It comes with the brake applied.
These are the settings of my engine. I don't know if the snapshot parameter below is enabled for you
I wonder if it's possible to change the settings so low brake/side stand instead activates regen.
I don't think it needs to be high brake to activate it, i guess the logic can be changed if PB4 is changed from "side_sustain" (side stand?) to "low_brake".
Ride on!
borko444   100 W
Post by borko444 » Sep 21 2019 11:05am
Having looked at the last page you may be right but you should try
larsb   1 MW
Post by larsb » Sep 21 2019 11:31am
I tried it. doesn't work, can't be sure if it's my controller and program as it is older than yours. I checked the files and wiring diagrams you had gotten - they all connect 12V to brake switch to high_brake/purple wire so i will try this.
Ride on!
borko444   100 W
Post by borko444 » Sep 21 2019 11:49am
My regeneration works with the brake switch. It is connected to pin 8. for me it's green
larsb   1 MW
Post by larsb » Sep 21 2019 3:29pm
should be possible to get regen to work with low brake - if only the program makers had handled program versions and revisions in a clear way.
Now there are several program variants that have different parts of the code unfunctional. I think playing too much with ports settings might brick the controller.
According to the manual it should work to just select "low brake" for the regen signal but nooooo.. not in my controller - it sets the low brake signal constantly which stops the function.
Solution: I gave up on low brake for regen and connected 12V DC-DC to high brake through the rear brake switch, set regen to 100% and tested, instant lock-up of the wheel no matter what speed i was driving. :wink:
Lowered to 20%, will try it tomorrow to see how high the regen current is.
Ride on!
drunkencat129   100 W
Post by drunkencat129 » Sep 22 2019 2:53pm
where can i order an em200 or em300 im going nuts trying to get my hands on one also planning to run 24s of nissan leaf cells so far built a bike with an em300 snd its a dam rocket ship id like to get one for my self also there not software locked are thay ?
drunkencat129   100 W
Post by drunkencat129 » Sep 22 2019 3:00pm
larsb wrote:
Apr 08 2019 10:45am
EM300p controller is available from QS:
I won't buy one anytime soon, could still be interesting for the higher power people :D
cant find any em300 listed where u get price and how do i order
larsb   1 MW
Post by larsb » Sep 22 2019 3:03pm
Ride on!
borko444   100 W
Post by borko444 » Sep 22 2019 3:57pm
larsb wrote:
Sep 21 2019 3:29pm
Solution: I set regen to 100% and tested, instant lock-up of the wheel no matter what speed i was driving. :wink:
Where in the program is set regen current?
larsb   1 MW
Post by larsb » Sep 22 2019 4:44pm
It’s called EBS in the program.
Ride on!
borko444   100 W
Post by borko444 » Sep 22 2019 4:48pm
:bigthumb:
pokladok1   1 µW
Post by pokladok1 » Sep 24 2019 7:31am
Hi everyone!
Can anyone share a link to download the software to try it? all links in this thread are dead :(
borko444   100 W
Post by borko444 » Sep 24 2019 7:38am
bitte
votol softdriver.rar
(5.05 MiB) Downloaded 110 times
