Need freewheel hub spacer
Looking for something? Need a special part, but can't find it online anywhere? Post what you need, maybe others will have it to sell. Guest may post replies to topics already here. All topics here will expire after 60 days of inactivity.
Postby richirich1113 » Thu Jan 19, 2012 6:05 pm
If i screw on my freewheel on my 3525 hub motor it tightens up right up against the hub , not allowing it to spin. I am looking for the spacer that would bring it out just enough to freewheel.
If anyone knows where to find one it would be much appreciated.
Thanks
KHS full suspension - 26x 2.5 Maxxis Hookworms
Avid Elixer 5 Hydraulic 203mm disks front/back
18 FET Lyen controller / HS 3540
21s - 10ah lithium ion polymer
richirich1113
Re: Need freewheel hub spacer
Postby hillzofvalp » Thu Jan 19, 2012 6:07 pm
Bike shop has them
hillzofvalp
Postby richirich1113 » Thu Jan 19, 2012 6:14 pm
Ilive in a small town with one bike shop and they dont have one and seemed to not even know what i was talking about even when i showed them the hub and freewheel and explained what i needed. A normal bike hub is already offset for this, a hub motor i guess is not.
richirich1113
Postby full-throttle » Thu Jan 19, 2012 7:01 pm
Ask them for a bottom bracket spacer, every external bottom bracket comes with 3 of them.
You could also use the spacers off a worn out cassette.
full-throttle
Postby richirich1113 » Thu Jan 19, 2012 7:07 pm
Thanks for the info, i will check that out
richirich1113
Return to Items Wanted
Who is online
Users browsing this forum: Alastor and 1 guest
