SOLD 48v 20ah 18650 lifepo4 V-Power pack
Got something to sell? Have extra parts that need a good home? Have something that others would need to complete their kits? Post it up here and see if anyone else is searching for what you are selling. Guest may post replies to topics already here. All topics here will expire after 90 days of inactivity.
Postby Rifle » Wed Jul 13, 2011 8:06 pm
This was my first battery pack. It was involved in a crash about 9 months ago. It made it through basically fine. Worked the same, but a few nicks and cuts in the duct tape. Probably has 125 cycles on it. there's 15-16 useable AH in it. I used the insurance money to get a Ping and now almost never use this, so I want to sell this and use the money to expand my Lipo collection. If anyone wants it for $300 free shipping, it's yours. Otherwise make an offer and it'll go to the best offer I get after a few days or so.
2807 9c front hub. 48v 20ah Ping. 12s2p Lipo.
Rifle
Re: 48v 20ah 18650 lifepo4 V-Power pack
Postby gestalt » Wed Jul 13, 2011 9:42 pm
Pics, demensions, and what do you mean about usable ah? Also what is the max and constant discharge capabilities? Hope I can use this to get me a commuter bike going while I re-evaluate my monster motor build.
- be seeing you
gestalt
Postby BLUESTREAK » Wed Jul 13, 2011 10:12 pm
What he means is that V-POWER sells 20ah packs that only have about 15ah capacity in them. :mrgreen:
BLUESTREAK
Postby Kin » Thu Jul 14, 2011 7:02 am
So, this is different from the Vpack you sold in march right? I got confused a bit I can't remember what that was about.
New to endless-sphere? Notice a lot of signatures recommending Ebike.ca? That's because it's the best place for a quality and manageable, (but still 'real'), first build. Justin is a solid supporter of electric bike development, and a good source of equipment.
My hat off a thousand times to the green people that effectively run this forum. The ES Mods are superb.
Kin
Postby ptd » Thu Jul 14, 2011 10:47 am
bms? charger? pics and dimensions, or a link to the site that sells them? thanks
woohoo, knightmb is gone, now where's his ill gotten gains ?
ptd
Postby veloman » Thu Jul 14, 2011 3:36 pm
BLUESTREAK wrote:What he means is that V-POWER sells 20ah packs that only have about 15ah capacity in them. :mrgreen:
Which is about in line with the rule of 80% for most lithium based batteries.
Mush! Mush you electrons! Push harder!
Main ride: Old School Specialized Stumpjumper FSR, Clyte HT3540, 63v lifepo4, 12fet Infineon set to 26amps. And a bunch of others... viewtopic.php?f=6&t=34236&p=497325#p497325.
veloman
Postby oatnet » Thu Jul 14, 2011 5:17 pm
Veloman is right, if the BMS uses a voltage cutoff that correlates with an 80% DOD, the 20ah pack should yield 16ah, a little less if the supercells (collection of paralleled cells, like "superset") are out of balance. Bluestreak, are you saying the BMS cuts off at 15ah, or you have done 100%DOD and only gotten 15ah?
The folks who started after LiFePO4 came out are spoiled - in the old days (NiMh/NiCd) we were happy when cells yielded half of the manufacturer's rating at 100% DOD :oops: :shock: :lol: because most of manufacturers were lying though their teeth .
-JD
Member 117 of 16,xxx
179v VW Camper © 164v Vectrix E-Moto © 72v Norco A-line/x5403 © 60v Specialized Enduro Comp/BMC © 72v x5tracycle © 48v TF IO/BMC © 36v Kepler Friction Drive © Spot-Welding a123 © Pelican Front Packs © Vectrix Battery Replacement © MORE !!
Image大鸡巴 Motors
Knowledge is acquired through experience, everything else is just information - Albert Einstein
"Cheater?" I'm not competing, I'm Commuting!
oatnet
Postby Rifle » Thu Jul 14, 2011 7:03 pm
The dimensions are approximately 10.5" x 7.25" x 5.5". It has a functioning BMS. By useable AH I meant the amount you can discharge before the BMS hits its LVC. I've attached a picture. The gash on the corner is the worst of the damage. It doesn't appear the gash reached to the cells. It appears there's a layer of something paper like still intact.
Kin wrote:So, this is different from the Vpack you sold in march right? I got confused a bit I can't remember what that was about.
Yes, this is a completely different pack. That one was partially disassembled. This one is good to go.
Rifle
Postby BLUESTREAK » Thu Jul 14, 2011 9:12 pm
Mine doe's the same thing, you can run till BMS low voltage kicks in. and according to the cycle anlyst it has used about 15ah. (this pack I still have) the other 48volt 20ah pack used to give me about 19ah before cutoff,it finally killed a cell and AMBERWOLF has it now and he fixed it. :) :)
BLUESTREAK
Postby amberwolf » Thu Jul 14, 2011 9:15 pm
But it's only about 11Ah or so to LVC, as it still has other bad cells in it that arent' dead enough to remove. :)
House Fire Updates Thread
http://endless-sphere.com/w
DayGlo Avenger, MkII
amberwolf
Postby oatnet » Fri Jul 15, 2011 12:34 am
amberwolf wrote:But it's only about 11Ah or so to LVC, as it still has other bad cells in it that arent' dead enough to remove. :)
Perhaps the BMS that allowed 95% DOD (19/20ah) contributed to that state of affairs. :D
JD
Image大鸡巴 Motors
oatnet
Postby BLUESTREAK » Fri Jul 15, 2011 6:20 am
That was a pretty good battery for over year and it may have been in a bind on my 500lb. MERIDIAN TRIKE with my x5305 and 48volt 40amp. controller. BTW the V_POWER battery that I still have is 1-1/2in. shorter than the one I sent to AMBERWOLF and at the time we had a big discussion here on ES with a rep. from V-POWER and all he ever would say is blame it on the BMS it's protecting the battery and we asked what was it being protected from but he would not ever give an answer. so there you are!. good day all. :D :D
BLUESTREAK
Postby Evoforce » Sun Jul 17, 2011 6:51 am
Oatnet is right. The battery is rated at 20 ah and the bms protects it at 80% usage and cuts it off at roughly 16 ah to not overdischarge into the protected 20% region. I have the same battery and it works exceptionally well. I have put many many miles on mine with big crystalyte motor and 45 amp controler. I paid under 300 dollars for mine new, but had to pay shipping charges from china to receive it.
"Energy is all consuming and it is never ending. It just changes form as it morphs through time and space... " Evoforce
        Several 5403 motors,  no time to build projects! Phoenix Racer(5303) crystalyte suspension mtn bike LiFepo4 72/20.  (409) crystalyte 48 volt hardtail.  In process... Phoenix Cruiser(5304)  LiFePo4 48/20.  First electric bike a 2009 XB 502-700 style, 36/20 sla scooter bike.  All charged by solar!
Evoforce
Postby Rifle » Sun Jul 17, 2011 7:57 pm
Notice I forgot to answer the max and continuous discharge rate. It's rated 1C continuous discharge and 2C peak.
Rifle
Postby Evoforce » Mon Jul 18, 2011 1:26 am
Does it come with a charger and if so what amp is it?
Evoforce
Postby Rifle » Mon Jul 18, 2011 8:31 am
Charger not included
Rifle
Postby Rifle » Fri Jul 22, 2011 12:19 am
Ok, I found an extra connector so I can swap out the connector on one of my chargers and include it.
Also, price drop to $250 free shipping.
OBO.
Rifle
Postby ptd » Fri Jul 22, 2011 8:58 am
pm sent
ptd
Postby ptd » Sat Jul 23, 2011 3:01 pm
c'mon rifle, don't leave me hangin :?
ptd
Postby Rifle » Sat Jul 23, 2011 3:08 pm
ptd wrote:c'mon rifle, don't leave me hangin :?
Don't worry, I'm on it.
Rifle
Return to Items for Sale - Used
Who is online
Users browsing this forum: No registered users and 3 guests
