Ebikekit REAR motor + Double wall rim + phase wire upgrade
Got something to sell? Have extra parts that need a good home? Have something that others would need to complete their kits? Post it up here and see if anyone else is searching for what you are selling. Guest may post replies to topics already here. All topics here will expire after 90 days of inactivity.
Karl
Post by Karl » Sep 27, 2011 1:27 pm
Hi,
I have a ebikekit Direct drive rear wheel motor that I think is defective... I cannot get it to spin properly
as said in one of my builds I thought I burned it but many think not...
The motor is 5 minutes old... with less than 2000ft done on it... I just think I didnt place the inside spacers right... but not sure...
I upgraded the phase wires with copper wires 12g.
asking 150$ plus shipping
ambroseliao
Re: Ebikekit REAR motor + Double wall rim + phase wire upgra
Post by ambroseliao » Sep 28, 2011 1:26 pm
Exactly what does it do when you press the throttle? Have you contacted e-Bikekit directly for assistance? Did it work before the phase wire upgrade?
http://www.ebikes.ca/ is the best!
TidalForce M-750X, Tidalforce S-750 with Crystalyte HS3540, 1x TF iO-X Cruiser. E+ 1000W hybrid bike. ebikes.ca DrainBrain & Cycle Analyst meters. GoPro HD Hero2 camera. Bosch Fat Packs, 37V 10Ah LiPO pack. Turnigy Multistar batteries
My blog: http://ebikerider.blogspot.com
Remember LiFEPo4 HVC is 3.65V and LVC is 2.7V
itchynackers
Post by itchynackers » Sep 28, 2011 7:29 pm
If it binds while spinning it on the bike, then it may be that you need a spacer between your gear cluster and the motor (as I did). Any reputable bike shop should have one for a couple bucks. Otherwise you may have the wrong phase/hall combo.
9c 9x7f w/ 12awg phases
9c 8x8r w/ 10awg phases, temp sensor, vented
9c 6x10r w/ 10awg phases, temp sensor, liquid cooled, 3rd Place Pikes Peak 2012!
"Don't argue with the galactically stupid...they drag you down to their level and beat you with experience"
dnmun
Post by dnmun » Sep 28, 2011 9:28 pm
i doubt if you overloaded and burned up a 9C from E-Bikekit.com but if you can fill us in on what the problem acted like, maybe we can help you get it working.
Karl
Post by Karl » Sep 29, 2011 7:11 am
heres some pictures
I rebuilt it and it does not spin freely
dogman dan
Post by dogman dan » Sep 29, 2011 2:37 pm
Shorted phase wires? Does it turn but go kind of chunk chunk chunk, resisting at each magnet? Maybe you nicked the wire insulation stuffing it?
dnmun
Post by dnmun » Sep 29, 2011 5:36 pm
too bad there is no info. you swapped out the stock phase wires for larger 12G? did you check continuity on the hall sensor wires after you pushed the new wires inside? if we knew more we could help you. have you measured resistance between each of the wires and the axle itself? is there 5V on the red wire on the halls and is there continuity of the ground from the hall sensor back to the controller? that motor was not hot from looking at the picture so it did not burn up.
itchynackers
Post by itchynackers » Sep 29, 2011 5:41 pm
It doesn't look like it got hot at all. Check the continuity/resistance of each hall wire from outside the axle, to the green board. Also check the continuity/resistance of the phases from outside the axle to where they attach to the windings. It should shed some light on things.
nicobie
Post by nicobie » Sep 29, 2011 7:14 pm
$50 and I'll pay the shipping?
May your tote always stay tight and your edge eversharp :wink:
my eTownie build thread: https://endless-sphere.com/forums/viewto ... =6&t=23701
Karl
Post by Karl » Sep 30, 2011 7:59 am
the motor is functioning but I feed a inner resistance inside the motor
but it does not spin freely by hand...
SamTexas
1 GW
1 GW
Post by SamTexas » Sep 30, 2011 8:26 am
Karl wrote:the motor is functioning but I feed a inner resistance inside the motor
Hard to tell how much resistance you're talking about. But all DD hubs have some internal resistance. I tested the resistance of my 9c 2807 by running the least amount of power through it to keep it spinning: With the wheel of the ground, it took 5W.
Karl
Post by Karl » Sep 30, 2011 10:17 am
the 1st time I installed the motor I could give it a spin (by hand) and it would easily do 1/2 turns
now I give it a spin and its like if I was applying the brakes it stops a 1/4 of a turn later
ambroseliao
Post by ambroseliao » Oct 01, 2011 7:37 am
Your saying that the motor spun normally before you did what you did with it. If you "upgraded" a new working motor and now it doesn't work, I wouldn't call it "defective". I would call it damaged.
dnmun
Post by dnmun » Oct 01, 2011 2:00 pm
it is hard to evaluate. could be that the normal resistance of the direct drive motor from the stator attraction to the magnets is now increased by some friction inside, either bearings not seated properly on the axle or even the new wire rubbing against the inside of the hub.
thewmatusmoloki
Post by thewmatusmoloki » Oct 01, 2011 2:23 pm
These pieces of plastic/wood should be pushed in flush with the stator, they could be touching the cover.
SAM_1250a (Custom).jpg (48.4 KiB) Viewed 1356 times
Dillenger Ebike mechanic
SamTexas
1 GW
1 GW
Post by SamTexas » Oct 01, 2011 2:35 pm
thewmatusmoloki wrote:These pieces of plastic/wood should be pushed in flush with the stator, they could be touching the cover.
Wow, could that be it? Very good observation!
Karl
Post by Karl » Oct 01, 2011 4:17 pm
the plastic things pulled out after the run... they cannot be pushed down anymore... I dont know how
SamTexas
1 GW
1 GW
Post by SamTexas » Oct 01, 2011 4:40 pm
Have you tried a hair dryer?
dnmun
Post by dnmun » Oct 01, 2011 9:53 pm
cut them off with dikes then. man that is the problem. i noticed that too, but did not put two and two together. good catch moloki. they are hitting the ribs on the inside of the cover. that's what makes them sing.
Karl
Post by Karl » Oct 02, 2011 8:12 am
ill try that
thx
999zip999
Post by 999zip999 » Oct 03, 2011 11:30 am
Let us know if this is the only problem.
