SOLD Race-setup Crystalyte 5304 and Lyen 18-fet
Got something to sell? Have extra parts that need a good home? Have something that others would need to complete their kits? Post it up here and see if anyone else is searching for what you are selling. Guest may post replies to topics already here. All topics here will expire after 90 days of inactivity.
Postby Farfle » Tue Dec 06, 2011 7:30 pm
DOH! could i get a mod to move this to the "Used" section?
Hello all, Making way for some bigger badder stuff, so I'm selling the Motor/speed control I ran with this years race bike, Its a 5304 and 18x4110 lyen modded with everything in the book, plus a few that aren't. asking 900 edit, 800$ shipped for the whole setup.
THE GOOD: Milled and hardened custom axle, hi-temp 10Awg phase wires, genuine hall sensors with high-temp wire, CNC machined sidecovers 12ga radial laced spokes and a wide 20" DX32 rim, perfect for a Pirelli ML75. also has NSK sealed bearings. The controller is a Lyen 18x4110 which has 10Awg beefed up traces and 10AWG high-temp wire aswell. It has an UN-modded shunt, and will Regen at 10 amps down to 15 mph. Rock-solid reliable running at 98v 140a peak 80a cont. It will come with the custom rotor, but can use a standard ISO 6-bolt rotor as well.
THE BAD: This motor and controller WAS on the bike that I got hit by a car on, but it suffered no damage. It also has PP75s which I would call a con, but have surprisingly not melted at 360A phase. this motor was one where the disk brake holes were drilled off-center, I re-drilled and tapped them to the correct location.
For those who care, on the track we saw 13.5% regen. And it did accelerate faster than an Astro powered bike, and a Turnigy outrunner powered bike :P .
heres a video of it in action:
The race bike:
24s5p 50c nano tech
Badass custom mofo outrunner 205x177mm 26kv
Peak power in : 318A at 91v
Peak power out: 24 Hp and 151ft/lb
Build to last...
"It will be assaulted by the elements, It will be ravaged by time and it will be destroyed by the user. BUT, if you Stick to the little rules: K.I.S.S., Overbuild everything, and test, review, revise, repeat. It will last"
Team Farfle blog!! http://www.farfleselectrics.blogspot.com
Farfle
Re: Race-setup Crystalyte 5304 and Lyen 18-fet
Postby dogman » Wed Dec 07, 2011 7:47 am
Be a done deal if I had the $$. Just the kind of easy upgrade I'd like for next spring.
No health, no work = no money.
THE LIPO RULES. NEVER ABOVE 4.3V NEVER BELOW 2.7V DON'T PUNCTURE
Ideal charging /discharging range for Lipo, 3.65v minimum 4.1v maximum
See battery technology section, FAQ thread at the top of the page for lipo noob info.
dogman
Postby grindz145 » Wed Dec 07, 2011 2:57 pm
Geez, I missed your build thread. What tires are you using on that? WANT!
http://www.endless-sphere.com/forums/viewtopic.php?f=18&t=19548 - Ebike Nerd Podcast
Thanks to Justin @ ebikes.ca! Go there, buy stuff. Support the Revolution :D
grindz145
Postby Farfle » Wed Dec 07, 2011 4:21 pm
They are Kenda Kraze 20x3s, I have mine for sale if you want em. Trading up to a larger wheelsize next year and cant use it.
The race bike:
24s5p 50c nano tech
Build to last...
Farfle
Postby grindz145 » Thu Dec 08, 2011 4:01 pm
Wow. I didn't realize they were only 20s yeah...
grindz145
Postby sangesf » Thu Dec 08, 2011 6:26 pm
Couple of questions...
1.) Can the "axle" be included?
2.) How well will it run on a 48v 30a controller?
sangesf
Postby Farfle » Thu Dec 08, 2011 6:34 pm
The axle is included, and installed on the motor, and this motor would run fine on a 48v 30A controller, but you would be better off with a 9C for that amount of power, be a lot lighter and a lot cheaper.
The race bike:
24s5p 50c nano tech
Build to last...
Farfle
Postby liveforphysics » Thu Dec 08, 2011 9:21 pm
I can vouch that this motor rips hard, and was a proven reliable setup on the track.
I can also vouch for Farfle being a great guy.
For ebike parts, don't be a douche, buy from http://www.ebikes.ca or http://www.MethTek.com
Justin saved the forum at great personal expense! The man is a legend and a hero!
liveforphysics
Postby Farfle » Thu Dec 08, 2011 9:40 pm
Thanks for the good words man.
The race bike:
24s5p 50c nano tech
Build to last...
Farfle
Postby Jay64 » Fri Dec 09, 2011 11:58 am
Damn, I might have to look around for some money. This motor was BADASS at the track. So you are selling the motor, controller, rim, and rotor for this price?
Johnson64.Com "The stone age didn't end because we ran out of stones."
EV Bikes:
'13 Zero S 11.4kwh.
GS500, ME0913, Sevcon Size 6 Controller, 90v40ah Lipo, GSXR suspension..
'87 Hurricane 600, ME0709, 48v/50a SLA, Kelly KD72400, Magura Throttle, High Current Cycle Analyst.
http://www.evalbum.com/2275
Raleigh beach cruiser: 9C rear hub, stock controller, 48v10ah lithium, Cycle Analyst.
Phat Chopper: 9C front hub, stock controller, 48v12ah a123s, Cycle Analyst.
Jay64
1 GW
1 GW
Postby Farfle » Fri Dec 09, 2011 12:19 pm
Yup, motor, controller, rim and tire all matching wiring and connectors. Hell, ill thow in the tires if it will sweeten the deal enough, have some time this month to crank out a frame and need the cash.
The race bike:
24s5p 50c nano tech
Build to last...
Farfle
Postby Farfle » Fri Dec 09, 2011 12:29 pm
Oops, rotor is in there too. And yes, it is a 290mm rotor
The race bike:
24s5p 50c nano tech
Build to last...
Farfle
Postby Farfle » Sun Dec 11, 2011 8:30 pm
Buy me! still for sale, will include two kenda kraze 20x3 tires!
The race bike:
24s5p 50c nano tech
Build to last...
Farfle
Postby Farfle » Mon Dec 12, 2011 1:18 pm
mmk, getting really short on cash, and need to start next years frame, so im dropping the price to $800 shipped, with the tires.
The race bike:
24s5p 50c nano tech
Build to last...
Farfle
Re: Race-setup Crystalyte 5304 and Lyen 18-fet, price lowere
Postby dogman » Tue Dec 13, 2011 7:21 am
Stop torturing me! Somebody buy this!
dogman
Postby IanJThor » Wed Dec 14, 2011 5:56 pm
I want it and I've been looking for a 5304! I'm doing a custom build dirtsurfer similar to what sonic-wind did a couple years back. Thi is still available right? Where are you shipping from?
IanJThor
Postby Farfle » Wed Dec 14, 2011 6:10 pm
Yup, still available, and it would be shipped out of Bend Oregon.
The race bike:
24s5p 50c nano tech
Build to last...
Farfle
Postby IanJThor » Wed Dec 14, 2011 6:16 pm
I want to buy this, I'm checking this on my phone so I'll keep it short. Apparently my last post did not go through beckie I left work! I've been looking for a 5304! Contact me at ianjthor@gmail.com
Thank you!
Ian.
IanJThor
Postby IanJThor » Wed Dec 14, 2011 6:19 pm
Oops, I see it there now. Sorry about that. if your in the states would you mind giving me a call? 9496339244
Ian
IanJThor
Postby damcard » Thu Dec 15, 2011 10:51 am
Farfle,
If you still have this, do you have any more swingarms that this can go in? -Damcard
damcard
Postby Kirk » Fri Dec 16, 2011 8:00 pm
Damn I wish I could swing this but Christmas has me tapped. After the first of the year, if she is still around we can talk turkey.
BUMP for the cause.
Stable:
05 Catrike Road (Yellow), 20" 48V 1000W GM hub motor,12s24Ah Lipo batt.
12 Catrike Expedition (Candy Purple), 18s32Ah Lipo batt. Lyen 18 FET low RDS controller, C'Lyte HS3540 hub motor, CA-SA, Mueller Bros. Windwrap XT fairing, Terra Cycle Cargo Monster extension. Still evolving, should be interesting by next Spring.
2011 Roll Over America tour, 50 Velomobiles, 5000 Km, 24 days, Portland, OR-Washington DC, July 28th-August 24th 2011, damn I was tired after that.
Kirk
Postby damcard » Fri Dec 16, 2011 9:53 pm
So, is it still available? -Damcard
damcard
Postby Farfle » Fri Dec 16, 2011 10:30 pm
Yes, is still available sorry
The race bike:
24s5p 50c nano tech
Build to last...
Farfle
Postby damcard » Sat Dec 17, 2011 11:12 pm
Will buy this off you if you can build another swing arm with it too (for the additional $ of course). Or, do you have any left? If so, pm me and I'll paypal you right away. PS, any news on the other swing arm you are building for me? -Damcard
damcard
Postby damcard » Sat Dec 17, 2011 11:13 pm
Or invoice me like before. Pm me still so I get the message to send it. -Damcard
damcard
Next
Return to Items for Sale - Used
Who is online
Users browsing this forum: Michall2008 and 6 guests
