nicobie wrote:Be careful. The newer controllers from Kenny have the same connector as the CA uses BUT it will not work with Justin's CA. It works only with the weak sauce meter from Clyte.
PowerPedro wrote:The Board serial number is EB218-A-2.
Trackman417 wrote:Ugh that's so annoying! I like the Infineon based controller I got from ebikes.ca but I don't like the fact that it doesn't have a three speed switch. This controller would be perfect! You know about an mods that will make this controller work with the CA?
Trackman417 wrote:Since its CA compatible you can just set LVC on the CA and it will limit current accordingly.
Problem solved
NeilP wrote:Trackman417 wrote:Since its CA compatible you can just set LVC on the CA and it will limit current accordingly.
Problem solved
No you can't..not to bring the LVC lower..the CA could make the LVC higher..say 72 volt..but van't make it lower..you would set the CA LVC at maybe 40 volts..but the controller LVC of 56 is still there
Return to Items for Sale - Used
Users browsing this forum: altermontrealiste and 2 guests
