recumpence wrote:You are thinking series. If you run them in series, the voltage would need to quadruple. If you parrallel them, the ohm rating would be divided by 4.
Matt
etard wrote: That motor seems nice, at least the reviews are all very super positive!!!!!!! It makes me wonder, if the site doesn't have people inhouse writing all those 5 star reviews.
etard wrote:If you run the warrior roller, it only gives you 20 mph no load. What does that translate to in real world speed?
How are you doing your throttle?
recumpence wrote:Becareful increasing voltage on RC outrunners. Most of them do not tolerate it.![]()
Anyway, you can always run a larger roller.![]()
Matt
etard wrote:I would suggest plugging your values into SwBluto's ebike calculator. I put my current information in, I figured out that to get the speed I want I am gonna have to go 48 volt. Gearing alone wont cut it, it just makes the motor less efficient. Right now I have a 295 kv Exceed-rc Monster Power 110, Astro flight servo tester, CC HV-110, EV Warrior roller, and a 24 volt 13ah nimh battery. I need to figure out the BEC, and get more battery, and get the belts n pulleys
etard wrote:Any ideas on how to bond or attach the tire to the rollerI was thinking about scuffing up the SRAM and just finding an epoxy that doesn't eat tires.
Users browsing this forum: Megalowmax, tonyontopofabighill and 7 guests
