Dual-diameter 6mm & 12mm motor shaft?
Postby erth64net » Thu Dec 18, 2008 11:51 am
I've got a Scorpion 4025-16, which is designed for a 6mm shaft (slight press-fit when installed).
The dilemma is; the freewheel/clutch-bearing that I'm eyeing needs to slide onto a 12mm shaft, so...I'm seeking a 125mm long shaft, where the first 90mm is 6mm in diameter and the final 35mm of length is 12mm in diameter.
I have a small 4x5 metal lathe, but have never tried turning shafts, especially ones needing a "slight" press-fit; does anyone have any idea what the success rate is for such an attempt (I've got, maybe, 50 hours experience using a lathe), and/or if there's a machinist/shop/store out there who has more skills and better equipment for such a task?
My bikes:
    Recchetta: Recumbent Electric Bacchetta Giro 700
    eWalker: Electric Sidewalker Scooter
erth64net
Re: Dual-diameter 6mm & 12mm motor shaft?
Postby Miles » Thu Dec 18, 2008 12:03 pm
Gregg,
Wouldn't it be easier just to sleeve the original shaft?
What kind of clutch-bearing is it?
Miles
Postby buzzfirst » Thu Dec 18, 2008 11:14 pm
Hello, If you have centers for the headstock and tailstock it should be doable to turn a shaft that length on your 4x machine. Center drill each end of a piece of stock, mount the stock between centers, and turn the 12mm part then turn the 6mm part. When turning between centers you can remove and remount the part without losing your center. You could get the 6mm part close (but big) and test fit it, put it back on the lathe and take another small amount either with a tool bit, file, or emery paper, repeat until done. Do you have an outside micrometer or at least a caliper for outside measurement? Option 2... If you only have a 3 jaw chuck mount a piece of oversize stock, turn the entire needed length to 12mm then turn the 6mm end on the tailstock end of the part. That way you can test fit the 6mm end in your motor without removing the part and everything will stay centered and circular. Start with a good piece of known steel or you may just waste your time. 1/2 inch drill rod would be perfect as you would have just enough to true the rod up in the chuck before you got to 12 mm and it is easily hardened after you get the dimensions correct.
buzzfirst
Postby erth64net » Fri Dec 19, 2008 12:59 am
Miles wrote:Gregg,
Maybe, but it's not keyed, so I worry about slippage; this particular design is hopefully where I can say "done", and finally give the whole setup a few months of solid "reliable" usage...
Miles wrote:What kind of clutch-bearing is it?
This one: http://www.vxb.com/page/bearings/PROD/O ... gs/Kit8177
My bikes:
erth64net
Postby erth64net » Fri Dec 19, 2008 1:10 am
buzzfirst wrote:Hello, If you have centers for the headstock and tailstock it should be doable to turn a shaft that length on your 4x machine. Center drill each end of a piece of stock, mount the stock between centers, and turn the 12mm part then turn the 6mm part. When turning between centers you can remove and remount the part without losing your center. You could get the 6mm part close (but big) and test fit it, put it back on the lathe and take another small amount either with a tool bit, file, or emery paper, repeat until done. Do you have an outside micrometer or at least a caliper for outside measurement? Option 2... If you only have a 3 jaw chuck mount a piece of oversize stock, turn the entire needed length to 12mm then turn the 6mm end on the tailstock end of the part. That way you can test fit the 6mm end in your motor without removing the part and everything will stay centered and circular. Start with a good piece of known steel or you may just waste your time. 1/2 inch drill rod would be perfect as you would have just enough to true the rod up in the chuck before you got to 12 mm and it is easily hardened after you get the dimensions correct.
Well, it's a 3 jaw self-centering chuck...and from your description, it sounds like drill rod would work fine. I suspected drill rod would be alright, so thank you for taking the time to explain.
Further, I've got a caliper (micrometer is on the xmas wishlist :-) )...but didn't really count on using it for close measurements; just eyeballing things, and then test fitting as I neared completion...sounds like I'm on the right track.
My bikes:
erth64net
Postby Miles » Fri Dec 19, 2008 3:31 am
erth64net wrote:Maybe, but it's not keyed, so I worry about slippage; this particular design is hopefully where I can say "done", and finally give the whole setup a few months of solid "reliable" usage...
You'll get the sprag clutch with a keyway, then?
Miles
Postby erth64net » Fri Dec 19, 2008 10:05 am
Sure, I guess I can buy another sprag clutch... :oops:
Seriously though - while there's a few places with related spec sheets online, I can't find anyone who'd actually sell small quantities (ie: 1 or 2) of the keyed option.
My bikes:
erth64net
Postby buzzfirst » Fri Dec 19, 2008 10:43 am
Hey Erth, one more thing about that shaft. It would probably be a good idea to leave a rounded transition between the 12mm portion and the 6mm part of the shaft. I guess a fillet would be more descriptive, anyway just try not to leave a 90 degree sharp inside corner between the two sections of shaft. There is only 6mm of steel and if it breaks it will break at the transition if it is sharp. I hope that made sense.
buzzfirst
Postby Miles » Fri Dec 19, 2008 12:46 pm
Making a new shaft for the motor would be a nice turning exercise but the easiest solution would be to make a sleeve and bond it on with anaerobic adhesive and then bond the clutch to the sleeve.
I don't know about sources in the States but I was able to get one with an internal keyway, easily enough, in the UK. Cost will probably be 4 or 5 times that of the Chinese one, though..... Have you tried this company: http://www.marland.com/index.html ?
Miles
Postby erth64net » Sun Dec 28, 2008 6:45 pm
Thanks for all the pointers and tips!
I do want to turn a shaft, but am inclined towards using a sleeve and anaerobic adhesive for the short-term...can't make up my mind at this moment :-)
Just to better "illustrate" what I'm attempting to mount:
HTD pulley mated with sprag clutch
HTD pulley mated with sprag clutch mounted on motor shaft
My bikes:
erth64net
Postby Miles » Sun Dec 28, 2008 6:54 pm
erth64net wrote:can't make up my mind at this moment :-)
See how you feel in the New Year? :)
Miles
Postby buzzfirst » Mon Dec 29, 2008 10:59 am
Turned shaft = easy repair or replacement ,, Adhesive = not so much... Good luck with it whichever way you go!
buzzfirst
Postby Miles » Mon Dec 29, 2008 11:11 am
buzzfirst wrote:Turned shaft = easy repair or replacement ,, Adhesive = not so much...
How so?
Miles
Postby GGoodrum » Mon Dec 29, 2008 1:00 pm
Wouldn't it be easier to drill/tap a couple of set screw holes, and the use a 12mm-to-6mm bore reducer from SDP-SI?
-- Gary
GGoodrum
Postby buzzfirst » Mon Dec 29, 2008 8:03 pm
With a turned shaft you would simply loosen the set screws and disassemble. With adhesive you would either have to press it apart, pound it apart or heat enough to soften the adhesive(which would wreak havoc on the bearing seals). Even though the hammer method is more fun you would still have to hold the bearing while hitting the shaft. Once apart it would have to be cleaned of all the old adhesive and reset in adhesive.
buzzfirst
Postby Miles » Tue Dec 30, 2008 5:16 am
buzzfirst wrote:With a turned shaft you would simply loosen the set screws and disassemble. With adhesive you would either have to press it apart, pound it apart or heat enough to soften the adhesive(which would wreak havoc on the bearing seals). Even though the hammer method is more fun you would still have to hold the bearing while hitting the shaft. Once apart it would have to be cleaned of all the old adhesive and reset in adhesive.
I've heated using a controlled soldering iron on the shaft, with the joint under pressure.
I agree a new shaft would be the way to go if you were going to do a keyway fixing for the sprag clutch. You can't fix the sprag clutch to a new shaft with set screws.
Miles
Postby Miles » Tue Dec 30, 2008 9:22 pm
Gregg,
Looking at your photo it seems to me that keeping the existing shaft makes more sense.
You could make an adapter for the sprag clutch which fixes onto the original shaft with set screws - the sprag clutch pulley assembly would be bonded to the adapter. You'll need to bore out the pulley and put a needle roller bearing inside it, though, I think.
Miles
Users browsing this forum: mechanix, The Riddler and 11 guests
