eTrike said:Skunkworks project?liveforphysics said:Something around that scale but designed for minimum mass will be what obsoletes top fuel dragsters, and they will be reliable and cost $1-2 in electricity rather than costing $50,000usd per pass for a full engine rebuild.
I'm inliveforphysics said:eTrike said:Skunkworks project?liveforphysics said:Something around that scale but designed for minimum mass will be what obsoletes top fuel dragsters, and they will be reliable and cost $1-2 in electricity rather than costing $50,000usd per pass for a full engine rebuild.
Not on my personal budget (saving for P100D), but if someone with the right funding wanted to make it happen, I'm sure we could work something out. 8)
Wheazel said:What power would be needed to achieve top fuel performance? How much margin does todays tech have to a "lift myself in my own hair" equation? Are the batteries needed to deliver the burst light enough? I remember Doctorbass using those special drag racing lipos for the 2wd nyx. Overall I have little clue about what forces we talk about with topfuel. I want to remember I have heard 8000hp somewhere sometime. Accurate? How heavy is a top fuel drive line?
I think its a very interesting concept, and I would be surprised no one has pursued it if the technology infact is easily available.
Hillhater said:Asuming you could find a motor, controller, transmission,etc to suit the 8000 hp needed, i suspect it will condown ro battery as the critical factor.
A little number crunching indicates that a pack would need to be capable of 6000A at 1000v for 8000 hp.
That would imply a 30Ahr pack of 200C cells, which at 150Whr/kg would mean 200 kg weight of cells !
Doctorbass said:John Metric is already using 8000 Amp of Zilla controller.. but guess what?!!.. he is now working on Brushless motor project!!
Doc
Arlo1 said:Doctorbass said:John Metric is already using 8000 Amp of Zilla controller.. but guess what?!!.. he is now working on Brushless motor project!!
Doc
Any more info? All I have seen him post is more brushes....
jmetric said:Guess what I just weighed my new car Extinction Level Event with the new BLDC and the new 200C Sleeper Cells.
Total weight loss for identical power output=1100lbs.
Car dropped from 2650lbs to 1550lbs.
Very happy but now have to regear for the new weight.
