Whilst I am still keen on a rear hubmotor (for the sheer simpilicty) I still watch this forum with much interest! I'm wondering if anyone has considered using the existing rear freewheel and cogs with an RC or "normal" style motor? I'm no engineer, but this seems like a really simple solution, I understand that there may need to be an additional gearing down but couldn't that also be part of the engine mount/block?
I'm not too good with drawing so I'll try and explain:
- Motor mounted under/behind the seat
- A guide is put in place to stop the de-railer from accessing the largest diameter cog on the rear wheel
- A chain is then run from the smallest possible toothed cog on the motor down to the largest diameter cog on the rear wheel
Any thoughts on this? It uses the existing freewheel of the rear wheel, so unless the cyclist pedalled backwards the motor wouldn't spin at all?
