Speed controller and motor wattage
Ramsart
10 µW
Hi,
Can anyone help my question i have 500 watt 36 volt motor can i use a 36 volt 350 watts speed controller
What are the disadvantage and will the speed controller have a shorter life span?
Is it better to use 500 watts controller instead?
Additional question whats the difference between sine wave and square wave which is better to use.
the 500 watt of the motor is the max, so driving it with a 350 watt controller is on problem.
the sine controller make less noise and can be smoother.
Motor ratings you can thing of as understated, most motors will handle way more and be happy doing so. People here run 14-15kw into a 3 kw motor. And have for years.
But to get motor to output more then rated power you need a bigger controller. If you use 350 watt controller, you will underpower your motor. Bigger is better for controller.
Hi
To many degrees you can forget about the wattage rating of the motor a lot of my motors are only rated at 250w but I can pull 1.5kw out of them.
As for controllers there is a general rule of thumb whatever the wattage rating of the controller you can pull twice that, so a 500w controller will draw a max of 1kw when under maximum load, a side note if there are bridges or hills where you are you will need at least 500w to get over without peddling 750w would be better.
Geoff
Ramsart said:
Hi,
350w controller should work with no "problems".
Performance on acceleration and hills will suffer!
But, top speed on level travel should be just as good.
Economy should improve, partly due to more efficient amp throughput, mostly due to encouraged pedal assist getting up to speed and on hills.
Go with a sine wave, as is more silent and efficient.
I suggest you to use this controllers that are sinewave: https://opensourceebikefirmware.bitbucket.io/
