Golden Motor Build 48v and Beyond!
Re: Golden Motor Build 48v and Beyond!
Postby icecube57 » Fri Feb 27, 2009 6:44 pm
Here is a fuzzy pic of the drop outs. The other pic is the bike upside down calipers installed. Took like 5 minutes to install. The back V- Brakes were &^%#@$ up. Took like 30 min to adjust them properly now they stop like a champ. I think i need to get new bearings in my crank. There is a little play. Ill ride these out until they die and get a new crank arm with larger rings. Other than that I lubed and tweak my shifters they shift perfectly. Back wheel has a hop in it... Its not the rim its the tire. It needs to be reseated or when I get some street slicks that should fix that. But I kinda like the tires that are almost hybrid tires. The tread is not as agressive as full mountain bike tires but they arent street either. Ill have to check them out. I removed the disk brake calipers from the fork but i could get all the screws out of the rotor on the rim. I used the right size torx bit but it stripped all but two screws... I trashed the rim kept the washers that fit into the bowl on the drop outs to make for an even flush mount. Im just cleaning up the bike and waiting for my motor to get here. I didnt want to get a traditional rack that mounted down to the axel on the rear wheel. I think Im just going to find a sturdy seatpost rack and a mtx trunk bag. They should hold 20-30lbs
(88.97 KiB) Downloaded 199 times
(75.87 KiB) Downloaded 189 times
icecube57
1 GW
1 GW
Postby Russell » Fri Feb 27, 2009 7:21 pm
Icecube57,
Just so you are aware V-brakes and mechanical disk brakes use LONG PULL brake levers and caliper and cantilever brakes use SHORT PULL brake levers. Many brake levers have anchor points for either so check if you haven't done so yet. I haven't tried long pull levers with short pull caliper brakes but from what I've read the brakes don't quite feel right or perform as they should if you mix them.
FWIW
-R
Jeep Comanche 29er w/Bafang QSWXH, 41 lbs + 9 to 14 lb rear trunk bag w/tools+battery, 29 mph w/12S LiPo.
Mongoose Hatchet dual suspension w/Bafang BPM
Past Bikes: Raleigh 700C, Kona Smoke 2-9
Russell
Postby icecube57 » Sat Feb 28, 2009 1:16 am
They are working quite fine. Good even and firm against the rim. No slipping or spongy feel.
icecube57
1 GW
1 GW
Postby biohazardman » Sat Feb 28, 2009 4:09 am
icecube57 wrote:Here is a fuzzy pic of the drop outs. The other pic is the bike upside down calipers installed. Took like 5 minutes to install. The back V- Brakes were &^%#@$ up. Took like 30 min to adjust them properly now they stop like a champ. I think i need to get new bearings in my crank. There is a little play. Ill ride these out until they die and get a new crank arm with larger rings. Other than that I lubed and tweak my shifters they shift perfectly. Back wheel has a hop in it... Its not the rim its the tire. It needs to be reseated or when I get some street slicks that should fix that. But I kinda like the tires that are almost hybrid tires. The tread is not as agressive as full mountain bike tires but they arent street either. Ill have to check them out. I removed the disk brake calipers from the fork but i could get all the screws out of the rotor on the rim. I used the right size torx bit but it stripped all but two screws... I trashed the rim kept the washers that fit into the bowl on the drop outs to make for an even flush mount. Im just cleaning up the bike and waiting for my motor to get here. I didnt want to get a traditional rack that mounted down to the axel on the rear wheel. I think Im just going to find a sturdy seatpost rack and a mtx trunk bag. They should hold 20-30lbs
I like them better although a torque bar is still a good idea as I have seen way to many pics of tweaked out and broken forks. One faceplate in a lifetime is enough. Great deal on the bike. Somewhere around here someone did an excellent job on putting a rotor on the side of GM a motor. He had some miles on it and no problem although some did not like the idea. Brakes are good and one of the few things that I have found that are not highly overrated. I upgraded to the 8" rotor on my newest project. Keep us up on the project. Going to start build 2 soon myself.
Just pretend that everything is OK maybe no one will notice.
Golden Motor Schwinn first build http://goldenmotor.com/SMF/index.php?topic=279.0
Giant BMC build viewtopic.php?f=6&t=235&start=390
Short ride vids viewtopic.php?f=3&t=20346&start=60#p321703
biohazardman
Postby Hyena » Sat Feb 28, 2009 4:27 am
The Stig wrote:No torque arms???? :o
I very promptly fitted them afterwards :P
You wont fit a disc brake to that front hub with those forks. I looked at mine for ages trying to work out a way to get clearance but the forks are just too narrow to fit the large golden hub + disc + room for the caliper to fit between the disc and the hub.
www.HyenaElectricBikes.com
Aussie high powered and custom e-bike kits
My build and HD video thread__. My youtube channel
Hyena
10 GW
10 GW
Postby dogman » Sat Feb 28, 2009 6:57 am
Yup a regular rack will greatly interfere with the action of rear suspension, so you need the seatpost kind. I have seen two of em used to hold more weight. If it looks like too much for the seatpost itself, a stout hickory or oak dowel inside would stiffen it.
On the spinout, torque arms are important, but not nearly as important as a proper fit, with nice flat contact on the dropouts. It's one of the reasons I like the simple pinched tube kind. You simply put em on a vise and press em flat to make em perfect. There is no cup to deal with. Justin at ebikes-ca just added a c washer to his product line to fill the lawyer lips on dropouts. The washers you saved will work only if you drill em out to a larger hole. Not real easy to do. A larger split lock washer can work. In any case, the perfect fit is the thing. A bad fit will actually start spreading the forks as you tighten down, and will let go on you later for sure when it spreads some more.
On brakes, just get some pinched tube forks with v brake posts on em. Ebay ususally has em from out of date bikes dissasembled. You can pinch that tube a lot for the clearance. there is nothing but a threaded rod in the bottom 4 inches of the cheap forks, so go ahead and pinch em all you need.
dogman
Postby The Stig » Sun Mar 01, 2009 2:09 am
Good:) so you can use regen braking. I like the idea of hardly ever having to change brake pads.
The Stig
Postby icecube57 » Sun Mar 01, 2009 12:50 pm
Yeah I would probably get one of knuckles controllers. Atleast his doesnt have a high failure rate like the Golden Motor Controllers does with regen. I read somewhere that someone tried to use regen on the GM controller and the motor ripped out of the forks. Not a nice thing to do. The funny thing i see about their new controller is i think it has antitheft device where if it feels vibrations it will use current to lock the rotor to prevent someone from riding away. It think its a cool but funny feature. Imma have to get a new controller anyway i think i see a hole in my budget where i can make 11.1v LIPO 8AH-16AH Booster pack out of some RC packs. lol it would be kinda sick for me to go to 96v.... but im not that stupid. I think ill save the extra juice for the last leg of the ride when the voltage drops off and speed disappears. Even tho lip isnt supposed to sag like SLA does. I got a quick question Is it safe to parallel a pack of different voltages. If i take these rc packs and make a 44.4 volt battery and my main pack sits at a way high voltage is it or is it not possible to parallel them with a schottys. Or should i stick to the idea of just making a booster. I wonder also If i could use the stock 48v controller with the booster pack. Wont know until I open it up.
I bought my Watts up meter... well i paid for it today on Ebay. http://cgi.ebay.com:80/ws/eBayISAPI.dll ... 0032518289
Im also about to get these torque arms on ebay. http://cgi.ebay.com/E-Bike-Torque-Arm-E ... .m20.l1116
Anyone ever use them?
Well guys its snowing here. This is a rare occasion... For Georgia that is... Snow on the grass and black ice every where. I gotta go get me some of this action. lol
PEACE
icecube57
1 GW
1 GW
Postby Hyena » Sun Mar 01, 2009 7:35 pm
icecube57 wrote:I read somewhere that someone tried to use regen on the GM controller and the motor ripped out of the forks. Not a nice thing to do.
Yeah that was me. I don't recommend adding the experience to the list of things to do before you die. If you do, best put it last on the list... :lol:
Mine was non-regen braking - same deal as regen but was dissipating the energy into a coil of wire rather than back into the batteries. I was using it in the absence of front brakes because I couldnt fit discs to the GM and my forks had no v brake mounts. Seeing as you've already sorted front brakes I'd highly recommend against it - not worth the risk on front hub motors for such minimal regen gains.
Re: the watts up meter, remember they're only rated to 60v and you'll promptly kill it if you try and put higher voltage into it.
Hyena
10 GW
10 GW
Postby icecube57 » Sun Mar 01, 2009 10:11 pm
Its not limited to just 60v. But limited to voltage of a 60v pack. I think i recalled that it showed all the information on my 60v pack on my last 60v build. It peaked at 68v and some change. I even went to 72... with a half dead SLA pack. But once i put a fully charged pack on it popped. I know the 48v ductape pack will be 54+ off the charger. I should be able to run the booste pack too. and stay under 68v limit. The meter says its limited to 100A i think i pulled 138A through it on a crazy stout scooter controller.
icecube57
1 GW
1 GW
Postby The Stig » Sun Mar 01, 2009 10:23 pm
Regen in the front without torque arms is a very bad idea.
Regen in the front with dual torque arms properly install, I would say, is a good idea.
The Stig
Postby icecube57 » Wed Mar 04, 2009 6:07 pm
My battery and motor kit both came in today. 2 Days from china for my battery isnt bad. Didnt realize how heavy that 48v 20AH battery really was... about the size of a car battery too. Battery was in good shape... the box it came in was kinda furked up. The motor kit had many faults. When I removed the rim out the box it was rattling... I thought something went fubar in the motor. I deflated the tire. Unmounted it removed the inner tube and tire.... One there was no rim tape. Two there were burrs all around the rim where the rim had been drilled for the spoke nuts. Three there was a freakin spoke nut just rattling around in the double walled rim. I removed the nut. Got rid of the burrs. Installed some rim tape. Installed a new inner tube. Mounted the original tire that came with the bike. I went to install the wheel to the fork. One side had the nut on backwards. I had to kut my sensor wires/connector on the motor to put the nut back on correctly .... the torque washers were a joke... they didnt fit even after bending the tab They got omitted. I mounted the motor... no torque arms yet. I resolder the sensors and ran the wiring along the bike. Temporarily mounted the controller. Went out to a local shop. I bought seatpost rack and bag. Went to wally world and bought a pump. The pump didnt work. Had to rig it to work. The bag wouldnt fit the battery no mattery how hard i tried i ended up slitting one corner of the bag. It didnt compromise the bag to much. but it fits in there and the opening lets me run my wires out. Its a temporary bag i suppose. The rack fits fine but its hard to get it tight. Even then it still swivel a little bit but not by much. The battery came charged... I topped it off in like 20 minutes. Loaded my bike up and took her for a spin. I finally realize my gears need some tuning but it didnt matter its not like i can use them anyway. The start off torque on this motor is fierce. Im 315lbs and it took off. And fast even when you pedal up to speed and hit the throttle it jolts off like your input was in vain. I dont have my watts up meter yet so i can tell the actual amp draw or how my pack is behaving. But i rode around the block a few times up some hill... pulls like a pack mule. I dont see any reason for me to go higher than 48v on this bike im satisfied with what i got now. Other that so minor bugs tweaks to my drive train and some rewiring to do... this bike kicks ass. Ill probably get out the next day or two and get some gps speed results. Dont have a bike computer yet either... Funds spreading thin. Here are some picks of where the build is now.
icecube57
1 GW
1 GW
Postby icecube57 » Thu Mar 05, 2009 9:53 pm
Yesterday was a fun day.. Today just had a host of problems. I had some serious wiring issues. The connectors I were temporarily using kept burning up. They were fine under light load but when I went for more than 20 secs WOT the power would cut out... Not completely. The pack voltage lights still worked but there was such a volt drop at the connectors the controller LVC kicked in under load. I was going to try for a long distance drive but with those problems I didnt even make it out my apartment complex. I worked the past hour re doing all the wiring. Seems to be working fine now. Even under stall. I also took the time to tune my gears. They were way out of check. The gear number shown wasnt the actual gear that it was in. I finally got everything lined up correctly. Everything shifting correctly according to the numbers on the shifter. The front derailer alignment was way off. It kept causing the chain to pop off. I keep seeing why this bike was discounted. I did a bike only ride just now. Shifting smoothly. Got a new pump. Pumped my tires up to 60psi. Ride wasnt harsh. The suspension took alot out of stiffness you get in hard tail bikes with that high psi setups. I tweaked my seatpost rack. It kept swiveling even when tighen down all the way. I ended up taking my old handlebar grip and putting around the seat post and then put the seat post rack on top of that and tightened it down. No more swivel. Moved the controller from the along the top tube and attached it with heavy duty zip ties to the seatpost rack. It doesnt interefer with the mounting of my battery bag on the rack. My battery is sitting at 60v floating charge on the charger. 58v after 1hr sitting off charger. After applying a load it drops to 54 v. I havent even been able to do a 5% discharge yet. With all the work Ive done today tommorrow is defintely a good test day. I feel it. Im still waiting on my Watts Up meter.... Still trying to figure out how to mount it too.
icecube57
1 GW
1 GW
Postby biohazardman » Thu Mar 05, 2009 11:59 pm
icecube57 wrote:Yesterday was a fun day.. Today just had a host of problems. I had some serious wiring issues. The connectors I were temporarily using kept burning up. They were fine under light load but when I went for more than 20 secs WOT the power would cut out... Not completely. The pack voltage lights still worked but there was such a volt drop at the connectors the controller LVC kicked in under load. I was going to try for a long distance drive but with those problems I didnt even make it out my apartment complex. I worked the past hour re doing all the wiring. Seems to be working fine now. Even under stall. I also took the time to tune my gears. They were way out of check. The gear number shown wasnt the actual gear that it was in. I finally got everything lined up correctly. Everything shifting correctly according to the numbers on the shifter. The front derailer alignment was way off. It kept causing the chain to pop off. I keep seeing why this bike was discounted. I did a bike only ride just now. Shifting smoothly. Got a new pump. Pumped my tires up to 60psi. Ride wasnt harsh. The suspension took alot out of stiffness you get in hard tail bikes with that high psi setups. I tweaked my seatpost rack. It kept swiveling even when tighen down all the way. I ended up taking my old handlebar grip and putting around the seat post and then put the seat post rack on top of that and tightened it down. No more swivel. Moved the controller from the along the top tube and attached it with heavy duty zip ties to the seatpost rack. It doesnt interefer with the mounting of my battery bag on the rack. My battery is sitting at 60v floating charge on the charger. 58v after 1hr sitting off charger. After applying a load it drops to 54 v. I havent even been able to do a 5% discharge yet. With all the work Ive done today tommorrow is defintely a good test day. I feel it. Im still waiting on my Watts Up meter.... Still trying to figure out how to mount it too.
I had 12lbs of lithium on my rear rack and thought it was OK. I tried a bit more and did not like the balance at all so went with some panniers and put the weight low. Rear racks for more weight that install on the triangle are available and would make things a bit steadier although they are not cheap. I would expect you could modify one of the better regular bike racks to fit. A bracket that fits on the axle can easily be made to bolt the rack on and hold the majority of the weight. Smallish U-bolt clamps will fit on the triangle to hold the front of the rack. Oh, and the torque bar looks allot like what I have on my avatar works well it does. Good luck and be safe.
biohazardman
Postby morph999 » Fri Mar 06, 2009 3:37 am
PEACE
Those torque arms don't look good. They don't look adjustable. The good ones have a thing that pops out so it can be rotated around but I don't see it on those.
Here is what the good ones look like:
http://ampedbikes.com/buynow.html
scroll down and you can see how the middle part pops out so it can be adjusted
morph999
Postby dogman » Fri Mar 06, 2009 6:47 am
It generally takes me a 100 miles of riding to finally get all the tweaks out of a new bike. Sounds like you know how to do it. It's worth it to save hundreds of dollars compared to a similar cheap bike bought at a high dollar bikeshop. If you aren't able to dial in a bike, then the bikeshop may be worth the price for the service. Once I got mine all set, I haven't had to touch anything for thousands of miles exept for the brake adjusters on the handles and a wheel trueing at about 1500. Back when I rode hard on pedal bikes, I trued the wheel weekly, so even cheapo suspension has a big effect.
dogman
Postby icecube57 » Fri Mar 06, 2009 7:10 pm
I got my Watts Up Meter. Here is some bike data. Controller is always on. Standby current is 0.08A and 4w. Standby with thumb throttle lock on is 0.2A and 11w... Big parasitic draw in my opinion. Freewheel draw is 1.5A and 78w. Stall current draw was 33.68 and 1664.1w. Speed measurements with a 315lb rider goes as followed. Garmin GPS verified 22mph unassisted. 26mph pedaling. 32mph downhill. 8-12mph uphill unassited. Never stalled on some decent grades. This bike is probably alot faster with you lighter people on this forum. I had my stock 30A glass fuse holder melt and blow today. It was pretty disfigured. I was riding pretty hard no input but thats no excuse for the cheap workmanship of the components of this kit. I replaced all power wires with 12g wire except for motor phase wires... Thats another project (grins). I realize my suspension is really soft on this bike. The weight with me and the battery causes the rack to bottom out on the tire. I will try to solve this by adjusting the shock adjustmen as far as i can with a wrench... instead of by hand. It should lift the rear end up a bit and sitffen then ride cause its way way to soft. I need brakes. Mines work but it leaves alot to be desired slowing down from high speed. Considering regen braking and possibly a higher amp controller possibly 40A. When torque arms come in and I get the funding. My battery has been fine. No abnormalities... No where near a full discharge either. If my bike is peaking at 30-35A 1.5C its in that safe slightly stressed butter zone. Does anyone bypass the bms for dishcharging and use the bms for charging? My bms is kinda big and takes up alot of room in the bag. Would be nice to do without it. Thats all for now... I also got some video if you dont mind wind and turning your head to the side to look at it sideways. Please turn speakers down.
icecube57
1 GW
1 GW
Postby dogman » Sat Mar 07, 2009 7:40 am
Now that I realize what you weigh, some suspension and brakes upgrades could be good for you, on the cheap stuff that works fine for me. Look for better brakes for cheap on broken bikes at a flea market or gargage sale. I've got some real expensive stuff for $20 that way. On ebay, you should be able to find a stonger spring to put into the rear shock, or for money, get a better shock with more travel.
dogman
Postby icecube57 » Sat Mar 07, 2009 1:01 pm
I work up early this morning to do a test run on our paved bike trail out here. Its pretty level with slight grades. My goal was 20 Miles. On the first 10 Mile stretch I use the WOT pulse and glide method with light pedaling on the acceleration. On the way back I used a constant throttle at about 1/4 the way on. I was consuming 5-10A on the entire way back to my car. My average speed was 18-22 mph pedaling along with the motor at 1/4 throttle. My trip computer is very accurate. I checked it with the trail markers and its dead on the money so I know my speed is good. I tried to establish my top speed in the first leg of the 20 miles since It was slight down hill and I had a freshly charged pack. But funny thing is I ended up breaking the first record on my return trip up hill... go figure lol. I consumed more AH on the way out than on the way in. With the meter I trained myself to use less on the way back in. The low constant throttle used alot less power and I had better time. I had to get rid of that crappy video from before. Im glad I edited it. It came out alot better. At the end of the ride I show my Watts Up Meter results and my trip computer results. 20 Miles and I stayed under 10AH I dont see why with a little more training I couldnt get 35-40 miles on the battery pack as I originally states. The bike is alot lighter than my previous build with the 60v-72v of SLA batteries I was carrying befire. Its atleast 20-30 lbs lighter. And twice as fast and twice as much torque. Holding the throttle at the 1/4 position almost felt like i was riding a pedelec type bike. It still gives you a work out but you its good to know you arent entirely cheating while riding.
icecube57
1 GW
1 GW
Postby icecube57 » Sun Mar 08, 2009 9:44 pm
I did 30 miles today. Maintained and average speed of 16mph consumed 9.8AH. Last mile I blew a tire. There was bulge in the side wall when I replaced the inner tube. I found there were fray marks all in the side wall where the nylon was frayed. I started poking at it and it blew out. I notice a wobble in the back wheel when I was riding and was trying to get back to the car as soon as possible. Gotta get a new set of tires... I swear I can use slicks where I live . I have a lot of spin outs starting up even when I pedal first. Sand and loose gravel in streets and side roads.
icecube57
1 GW
1 GW
Postby icecube57 » Thu Mar 12, 2009 3:02 pm
In my last post i said I had tire issues.I had a busted tube and the side wall of one of my tires blew out. I scraped some money and bought some bell wally world kevlar reinforced tires. Im not proud of my purchase but then again i like instant gratification. I gained 3-5 mph on the flats and downhills. Its a slick with slightly agressive tread for city/urban use. They roll very quiet compared to the knobbies I pulled off that sounded like a 4x4 truck going 70 mph with mud boggin tires on. I clocked 33 on the flats and 37 on my down hill. Keep in mind my free wheel speed is 44mph right off the charger. Cant wait until I get my torque arms cause i need some regen braking bad... Im thrilled at the speed increase. Ill post a wheel POV video.... You can hear my motor purr whine and growl as it hauls my fat arse around the park.There is still some wind but its alot better than my other vids. I had every intention of draining my pack today to do a review on my ebay duct tape battery pack. That thing is freaking huge. I spend over 30 minutes doing hard riding and only manage to drain 11AH. It was to cold to continue. I like the flat discharge curve and even performance even tho there is obvious 2-3v voltage drop with the load. Its pretty flat. I feel spoiled compared to my old SLA setup. Im expecting there to be 17-18AH in the pack due to the perkuets but i gotta get to the bottom of the bucket to let you know first... one day guys... one day.
icecube57
1 GW
1 GW
Postby dogman » Thu Mar 12, 2009 8:43 pm
I have 2000 miles on one of those wally world bell tires, and it still has a ton of tread left. Lots of sharp rocks, metal stuff etc, and it is fine.
dogman
Postby docnjoj » Fri Mar 13, 2009 7:34 am
Ditto on the Walmart tires. I need at least 2 at a time (front toe in sucks but is better than toe-out or zero) and they are lasting much better than my Big Apples did, plus they have less grip! That means a slide instead of a flip! Definitely better IMHO!
otherDoc
E-bike stable at our house
Bike-e electric front brushed C/L
Steintrike Mad Max full suspension trike rear 9C
Sun USX delta trike 9C front wheel sort of front suspension
Frame of homebuilt trike in shed with Bafang still on it
New Agniusm/A123 on the Steini and old 10ah Ping paralleled with 12 ah Fatpacks on USX
My wife and I ride the trikes
docnjoj
10 GW
10 GW
Postby icecube57 » Sat Mar 14, 2009 2:14 pm
After reading the recent NDE story I bought some torque arms from Earl at the Powerridestore. They torque arm needed some work but i got it on and i fit it inside the fork. I also got some Andersons but not enough to finish all my connections. I bought two headlights. I plant to buy a DC to DC convertor and tap power from my battery to power the headlights but right now im using ( 4)2600mah AA NIMH batteries in each headlight. I plant to recharge once a week and carry some regular alkaline in my emergency backpack just incase im stranded somewhere. Bought a wider comfort seat. That narrow assed stock seat was doing a number on my chode. I couldnt walk right or sit for atleast 3-4 days after that 30 mile test run. I also raised my handle bars about 1 1/2 inches... Ride feels much better.
icecube57
1 GW
1 GW
Postby icecube57 » Sun Mar 15, 2009 9:02 pm
Today I did a dusk/night ride. I did manage to drain my pack today. I got about 16AH out of a 48v 20AH pack. I did WOT throttle 80% of the time. I pedaled during the start up until I couldnt match the motor speed and let rode the throttle rest of the time. I got about 23 m. The motor was mildly warm. The bms on the battery cut me off.I could technically keep pulling out of the pack at 5-10A but i couldnt stay in the butter zone. Someone please tell me is the 16AH I got out of my pack reasonable or do i need to do some sniffing to find the dead rat. I was drawing 30A most of the time. I wasnt babying the throttle. My light worked but they were lack luster. Im going to find a supplementary LED light system on EBAY I like they way the projected. For them to be so cheap i like that pure white blinding light. They had a wide angle mid throw even light beam The two I have a focused far throwing beam like a flash light. I also had a failed anderson. Bad crimp. I fixed it with my kit bag in the middle of my ride. Thats all i got for now.
icecube57
1 GW
1 GW
PreviousNext
Users browsing this forum: Bing [Bot], CogHog, grindz145, Ian, litespeed, steeeve and 16 guests
