fechter wrote:Since the best you can get out of regen is way less than 50%, unless you live at the top of a hill, it would be nearly impossible to get a situation where the batteries couldn't absorb the regen charge. To make things idiot proof, you would still need to manage this possibility. You can either stop regen if the batteries get too high, or use some kind of dump load resistor to dissipate the excess. Either of these could be triggered by a BMS circuit if one was present.
solarbbq2003 wrote:nice one justin!
another interesting thing is you can capture more regen when the batteries are more discharged, its quite noticeable, I guess the batts have lower resistance the more discharged they get and hence can capture more regen current
snowcrow wrote:Would a lower system voltage (36v or 48v), be more effective % wise, when using regen?
Blessings, Snow Crow
another interesting thing is you can capture more regen when the batteries are more discharged, its quite noticeable, I guess the batts have lower resistance the more discharged they get and hence can capture more regen current,
paultrafalgar wrote:
Justin, could you improve the regen capture by using an ultracapacitor as intermediary, with an ultracapacitor such as JCG uses here:
viewtopic.php?f=6&t=7511&start=0&st=0&sk=t&sd=a&hilit=JCG
justin_le wrote:But what I was showing with parabolic regen battery current curves is that for high rates of regen braking, the amount of regen current that actually flows back into the battery starts to decrease with higher braking forces.
Toorbough ULL-Zeveigh wrote:justin_le wrote:But what I was showing with parabolic regen battery current curves is that for high rates of regen braking, the amount of regen current that actually flows back into the battery starts to decrease with higher braking forces.
When seeing those current curves I was thinking of another kind of generator, a PV solar cell which will also will give you max current at short circuit but zero power out.
You want to pick an operating point at the I/V knee maximum power point.
As with any generator, an audio amp being another example, max power transmission occurs when the load impedance is matched.
It seems like an ultracap would be much lower impedance & relatively speaking, like dumping the power into a short.
ZapPat wrote:
As for the ultracap vs motor impedance issue, I don't think it's really like dumping into a short. The controller is actually doing the impedance matching between the motor and the battery / capacitors (by using PWM with motor inductance and battery capacitance). This is what the MPPT controllers used for solar are actually doing already. As a side note, the few ultracaps for which I've read the datasheets seem to have not-so great ESR, not really any better than LiFePO4 batteries it seemed to me at the time. Please correct me on this if I'm out of date with the cap situation!
For clarity, was the force constant or the rate of deceleration? (less force being needed as the vehicle slows)fechter wrote: On my Zappy (synchronous switching), the braking force would remain constant until the speed was almost zero.
TylerDurden wrote:For clarity, was the force constant or the rate of deceleration? (less force being needed as the vehicle slows)
fechter wrote:You can't argue with Justin's curves. At one end of the spectrum, the duty cycle of the braking switch gets high enough for the inductors to reach steady state. Whatever the opposite of discontinuous is? If you restrict yourself to the efficient range, the braking force will drop off as you slow down and may result in too much charge current under fast braking.
A MPPT-like scheme could work and would maximize energy recovery under some conditons, but I think it would result in less than ideal driveability characteristics. I would rather sacrafice some efficiency to get optimum driveability. Improved, safer braking takes priority over energy recovery. The overall energy recovery is so low that even if it was optimized it would still be pretty low.
I found constant motor current braking to be nearly ideal in terms of driveability and it limits the drivetrain torque to prevent damage. On my Zappy (synchronous switching), the braking force would remain constant until the speed was almost zero.
ZapPat wrote:You're probably right about the driveability being under par for this type of controlled regen... but I'll have to try it out anyways! Justin did observe that by using a combination of regen and regular breaks together, we could actually get more energy back than with regen alone. I guess an MPPT-like regen used along with the regular breaks would illustrate exactly this situation! Anyways, maybe some type of compromise could be found, and if I do decide to keep an MPPT-like regen mode it would definitely be optional only via user-interface software, with constant motor side current regen being the standard mode. And of course it would be city users (stop and go) and hilly area users that would benefit from this mostly, making efficient regen a no-brainer when this mode of regen would be selected.
ZapPat wrote:[...]Justin did observe that by using a combination of regen and regular breaks together, we could actually get more energy back than with regen alone. I guess an MPPT-like regen used along with the regular breaks would illustrate exactly this situation! Anyways, maybe some type of compromise could be found, and if I do decide to keep an MPPT-like regen mode it would definitely be optional only via user-interface software, with constant motor side current regen being the standard mode. And of course it would be city users (stop and go) and hilly area users that would benefit from this mostly, making efficient regen a no-brainer when this mode of regen would be selected.
justin_le wrote:Don't forget ZapPat that maximum power-point regen is almost by definition only 50% efficient on the electrical side, it's not really where you want to be. A controller that defaults to this state wouldn't deliver as much back to the battery as a proportional regen system that is generally well to the right of the max power point where the regen efficiency is much higher (even if the braking force is somewhat less). Ideally the rider anticipates stopping far enough in advance that they can come to a stop on regen alone, while keeping the duty cycle somewhere between 75-85% of what it would be to match the back-emf voltage.
If you are operating anywhere to the left of the MPPoint on that curve, then you are better off reducing the regen so it moves right to the MPPT point and making up for the difference in stopping power with mechanical brakes. This way you would come to stop just as fast but you would get more amp-hours back into the battery.
-Justin
ZapPat wrote:dennis wrote:ZapPat wrote:- Smoother braking action (when using current based regen with space-vector modulation)
All of the above is true, except for the smooth part. With my Bionx system, I found that when braking the whole back wheel vibrates during regen and the back and forth torque placed on the rear axel will cause the nut to loosen over time. I always check my nuts now before each rideA good solution maybe a custom rear axel for electric hub motors...larger locking nut with a cotter pin with more surface area, similar to an off road motorcycle.... and if you like to track stand http://en.wikipedia.org/wiki/Track_stand, the way the hub sticks when regen kicks in, makes track standing much harder but is possible.
I would agree with you on this point for regular regen, but as you see I did specify using SVM which reduces torque ripple both during drive and regen. This happens because a SVM capable controller will output a waveform that matches the motor's own back EMF, thus avoiding the uneven current flows that regular trapezoidal commutation produces. This of course does require more complexity mostly in firmware, more processing power, faster ADCs and phase current sensing. I must admit I have no idea what biox uses as a regen technique, but from what you say they must be using regular old commutation techniques.
Of course even with SVM we still have the bidirectionnal torque issue (although probably lessened with the smoother SVM) caused by regen. This will just be a matter of having good torque arms, along with some setup that will effectively lock your nuts to prevent them from loosening. I'm not a hardcore bike guy, so I'll leave this part for other great brains here to solve. Note that Justin just tighted the hell out of his nuts and that was already enough for his setup to not come loose, so I don't think that the solutions will be that complex.dennis wrote:Regen, imo also reduces the useful life of the battery, in my case is LiMn which has a useful life of about 500 full cycle charges. With heavy use, my 9ah battery was only able to hold less than half a charge after 1.5 year. That is why I'm so interested in super capacitors. If someone can put it in a kit without adding too much weight. my 1/100 cent....
Read Justin's posts, along with mine, then explain why you claim that regen inherantly reduces battery life when current limits and such are well thought out? In other words, explain what is the difference between regenerated current and regular charging current going into the battery? Also, what makes you sure that something else was not the cause of your packs premature demise? I know I might sound rash a bit here, but I strongly dislike unsubstantiated claims being posted by a few people and then repeated by many others...![]()
Cheers!
Pat
fechter wrote:TylerDurden wrote:For clarity, was the force constant or the rate of deceleration? (less force being needed as the vehicle slows)
The force was constant.
Braking force is directly proportional to motor current. By keeping the motor current constant, the braking force remains constant. If the braking force was too high on my setup, it would cause the belt to skip teeth. I normally adjusted the limit to just below where the teeth would start skipping. If I adjusted the limit to zero, it would behave like very low resistance free wheeling.
justin_le wrote:If you are operating anywhere to the left of the MPPoint on that curve, then you are better off reducing the regen so it moves right to the MPPT point and making up for the difference in stopping power with mechanical brakes. This way you would come to stop just as fast but you would get more amp-hours back into the battery.
Affliction wrote:And we all know that reverse rotation of a powered hub motor has resistance to turning. In reverse, this is the switching required for regen.
Alot of the immediate start chrystalite controllers that Justin sells have reverse with a key switch. I disconnected this on mine because the keyswitch was shorting out in the wet and going into reverse.
If the reverse pulse pattern is what regen is, then why not hook up a brake switch to the reverse input for braking? Anyone try this?
However, the #1 reason for me wanting regen, is simply because I like the braking idea. I like the idea of braking from high speed without eating up my brake pads. With a long commute to work, with alot of flats and hills, I can concievably use my regen up to 80% of the time for my braking, and save my brake pads and subsequently the rims from heavy wear over years of use.
justin_le wrote:Affliction wrote:And we all know that reverse rotation of a powered hub motor has resistance to turning. In reverse, this is the switching required for regen.
This isn't quite correct. The analog Crystalyte start immediate controllers are wired in such a way that one low side mosfet is always engaged and shorted to ground. When the motor is spun forwards this has really no consequence, since the grounded motor phase is the one at the lowest voltage. However, if you attempt to spin the motor backwards, the grounded phase is actually the motor phase that has the highest voltage relative to the other two, but it is still being forced to ground, and as a result you end up with circulating currents that flow through the clamping diodes of these other phases and ground. This has pretty much the same consequence as shorting all the phases together. It does slow you down electronically, but it's not exactly regen since there is nothing flowing back into the battery pack when you do this.
Justin
ZapPat wrote:
Of course even better would be having relays that would dynamicaly switch batteries from series to parallel configurations, and even motor windings from delta to wye for a truly efficient system! This is in the dream real for now, but I just added it to my own controller features wish list!
I am talking to Crystalyte now. Do you want to try the Delta/Wye or the series/parr windings? either way, they are making the custom axles to get the 2.5mm Teflon wire out the hubs. Just need to know what way you want it. I think the price will be the same either way, around 400usd, but they need a 5 motor min order to make the custom axles so i will take two, we need to sell the other two extra if you want just one. thanks john
Return to Technical Reference Area
