Analysis of regen on an ebike
Archive of useful information. This is not a discussion area.
Re: Analysis of regen on an ebike
Postby solarbbq2003 » Thu Jan 01, 2009 8:05 am
bvillion wrote regard more regen when battery is discharged
2) At a given pulse width, a low voltage battery will take more current than a high voltage one, since the voltage differential will be higher between back EMF and battery.
I think that might be part of it, but battery resistances i'm quite sure decreases as battery is discharged, I guess is possible to put in ( measure) numbers and work out difference in regen current battery can accept as it becomes more discharged.
I guess also justins % graphs are based on current measurements via shunt? Would it be correct to assume the % graphs given will be slightly overestimating the actual % stored in the batts? if yes any ideas on size of adjustment to get actual %
Changing voltage and resistance of the batteries between fully charged to fully discharged are going to be infuencing the rate the current that can go into the batts. I've noticed using an analog meter while riding that as soon as regen is activated ( on a standard regen controller, not proportional type ) that there is a very quite current spike which can be quite high but very quickly drops down to a lower current which remains relatively constant as the bike comes to a stop.
example: 48v 15ahr cobalt pack using gldual motor in low speed winding typically gives a very brief peak of about 10amps ( for a fraction of a second), then drops down to about 2.5amps where it remains constant until bike speed gets quite slow.
This current spike is quite interesting, I'm wondering why it spikes then drops down to a quite low level of current.
solarbbq2003
Postby ZapPat » Fri Jan 02, 2009 8:49 am
Doctorbass wrote:
ZapPat wrote:Of course even better would be having relays that would dynamicaly switch batteries from series to parallel configurations, and even motor windings from delta to wye for a truly efficient system! This is in the dream real for now, but I just added it to my own controller features wish list! :D
ZapPat, i'll get the 3PDT relay soon!! the delta to wye config WILL be on my bike.. and also.. i already have the serie/parallel contactor on my bike for 100V 23Ah or 50V 46Ah... so that setup will be the best to try that!
I should receive a 5306/03 motor with two winding per phase for serie/parallel winding configuration.. all the possible situations on my setup for the begining of spring 2009! :mrgreen:
Oh.. in the last minute i received a PM from John that have a direct contact with Crystalyte manufacture. See what he pm'd me :
I am talking to Crystalyte now. Do you want to try the Delta/Wye or the series/parr windings? either way, they are making the custom axles to get the 2.5mm Teflon wire out the hubs. Just need to know what way you want it. I think the price will be the same either way, around 400usd, but they need a 5 motor min order to make the custom axles so i will take two, we need to sell the other two extra if you want just one. thanks john
So there will be 2 availlable motor to complete the order.. any interested? :mrgreen: I suggested to ask to build custom motor of Delta/Wye instead of serie/parallel cause the ratio difference is just 2 for s/p config or 1.73 for the Delta/Wye config.. thatDelta/Wye seems more interesting cause it only require one 3PDT relay and 6 phase wire out of the hub instead of two relay and 12 or 10 phases wires...
Justin, i wonder what would be the best to allow live change on the relay while riding without blowing the mosfet of the controller caused bt spikes when switching between Delta or Wye ?
Doc
Well, Doc, you sound like the perfect tester for a special edition controller! You were already on my list of potential beta testers, so I would just have to make a special one for you to test out on your electronic four speed bike setup. It will beat doing the "shifting" manually, and you won't have to worry about the relays switching at the wrong time. If you do decide to test your delta/wye switch manually though, just be sure your controller is outputing nothing at the time (no throttle).
This type of setup will get you more efficiency for sure, but I wonder how it compares with mecanical shifters (using both together would make a monster though!). Your motor poles won't be moving any faster, but you will have better matching between the battery voltage and the motor's BEMF. I think this will help regen efficiency quite a bit, since the current spikes in the motor will be reduced in amplitude, thus reducing R * I^2 losses both in the motor windings and the controller. It will also give you four possible full throttle speeds, which will also help because switching losses are almost eliminated at full throttle (if not in current limiting that is). Regen efficiency at low speeds will be much improved, which will also help reduce motor heating that happens when doing regen at very low duty cycles.
I can't join you guys for the special Xlite motor purchase, since this would break the bank right now. I have to put all my ressources into trying to go forward with my controller project, and I'm not sure if I'll be able to convince the local bureaucrats to give me a financial hand with this. They are generally in another world, and mostly have no realistic vision of the future. I guess I'll see, since I have a meeting on the 6th with a couple of them about this. I must say I'm positive about it, since one of the guys has even seen "who killed the electric car", which surprised me a lot!
All my ebikes have gone up in flames (with my whole house) --> Many lessons learned (like that insurance companies can be cold hearted a$$holes; and to read and understand your contract before your house burns down...)
ZapPat
Postby ZapPat » Fri Jan 02, 2009 9:49 am
solarbbq2003 wrote:
bvillion wrote:At a given pulse width, a low voltage battery will take more current than a high voltage one, since the voltage differential will be higher between back EMF and battery.
All these statements are true, but not complete, since for one battery behavior really varies a lot depending on what you are using (chemistry, quality, temp,...). Many other factors will also influence your maximal regen current, including controller resistance and motor resistance. I personnaly would not use just any old battery with a regen setup, but would choose a lithium with fairly low internal resistance (good C rate). These usually have a fairly good charge rate acceptance over most of the charge range (like 10-90% of the state of charge). Most importantly, make sure you choose your battery so your maximum regen current does not exceed the batterie's maximum charge current. Even my 20Ah Ping battery will accept 20 amps of regen current, which would probably be quite suitable for many people. Headways would be better yet of course.
Lead and NiMH don't have very good charge efficiencies, so yes, there would be a fair difference in this case. However, if fairly good lithium cells are used then the real recaptured energy vs the displayed recaptured energy would be much closer together, since lithium has very high charge efficiency. You would also have to count in your batterie's internal resistance as a loss for this case, so better batteries (lower internal R) and lower charge currents would help here.
Any links to technical details about the controller you are using? The split second current spike you describe sounds like an artifact of the way your controller does it's regen, and I don't think this is "standard" regen behavior.
ZapPat
Postby Doctorbass » Fri Jan 02, 2009 12:52 pm
ZapPat I would be glad to test your controller.
Since i appear to become a new stuff tester and i like that. If my lab can help someone for getting data or stat on any ev stuff l'll be glad to help for that!
About the battery resistance and SOC, after many charge and discharge test i've done, i would say that the lowest resistance a lithium battery can have is in the 10-90% SOC range.
In other words, that happen when the curve is pretty flat and not when the slope is changing..
PM me ZapPat :wink:
Doc
________________
-Fastest speed record from now: 113 km/h measured on GPS
-Fastest ebike 106km/h on flat and managed to enter in the 19.875 sec on the 1/4 mile drag racing !
-0-70km/h in 5sec X5 5303 on 24"
TORQUE SETUP:
-Team Konion Member
113kmh Giant___http://www.evalbum.com/3406
Mongoose____http://www.evalbum.com/1947
E-trike_______ http://www.evalbum.com/3776
I speak FRENCH and english
Doctorbass
Postby Doctorbass » Fri Jan 02, 2009 1:00 pm
Hey, Justin! :wink:
I would thanks you for the gift i just received yesterday, that will help me alot with some experiments on regen when i'll work on my 4 electrical speed setup!
That was a very nice moment for my wife and me to receive you at our home in Quebec during your trip.
Your new posted data about regen are very instructive tpo me and i can match that to the paper at the Shwan restaurant your wrote about that for me when you was here! :wink:
thanks!
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby JCG » Sat Jan 03, 2009 9:48 am
justin_le wrote:
paultrafalgar wrote:
Justin, could you improve the regen capture by using an ultracapacitor as intermediary, with an ultracapacitor such as JCG uses here:
viewtopic.php?f=6&t=7511&start=0&st=0&sk=t&sd=a&hilit=JCG
So even if an ultracap would allow me to do a maximum regen current of say 20 amps. Yes, I would be able to do more regen and come to a faster stop, but no, I would not get any more energy back. In fact, I would recover quite a bit less energy than had I come to a more gradual stop at 6 amps regen using just a battery to absorb the energy. So the idea that an ultracap could help 'improve' the percentage of recaptured energy is quite false in this case.
With respect, I couldn't disagree more. When you plug that battery pack in at night (regardless of its type), you won't be using a constant current of 20 A to charge it, and there are lots of reasons why you wouldn't. I think that people are forgetting that the battery is an electrochemical device, the emphasis being on chemical. Don't forget that when you charge or discharge a galvanic cell, there are chemical processes being carried out in several places within the cell, each of them occuring at a finite rate and according to a specific set of electrochemical kinetic rules which are extremely complicated and difficult to describe in equation form without making several assumptions. I'm not going to preach equations here, but all of us knows that the actual energy put back into the cell is quite dependant on charging current (among other things) for a reason.
ZapPat brings up an important point that rings true.
ZapPat wrote:battery behavior really varies a lot depending on what you are using (chemistry, quality, temp,...).
The chemical reactions at the electrode surfaces can’t happen instantly and there will be a chemical concentration gradient between the electrode surfaces and the bulk electrolyte established involving things like boundary diffusion layers and natural convection (even in “gel” electrolytes). The chemical conversion boils down to two main steps.
1) Charge transfer. This is the faster of the two processes, involving very short transport distances at the electrode/electrolyte surface and surface electron transfer.
2) Mass transfer. This is the diffusion of ionic and molecular species to or away from the electrode surface (either the supply of material for the electrode or the exhausting of reacted chemical species). This is a much slower process than bulk diffusion, and mass transport in an electrolyte is often more than one order of magnitude slower than charge transfer on the surface.
There are a whole host of effects to consider alongside the (dis)charging process depending on the cell chemistry. Intercallation in Lithium cells, electrode crystallization or filming, gas production, etc. Even the often quoted “charging efficiency” can be a tough number to rely on. Personally, I consider the concept of charging efficiency itself to be weak, I’ll refer you to the following discussion:
http://www.smartgauge.co.uk/chg_eff.html
There are efficiencies associated with cell charging under specific conditions (trickle, constant current, constant voltage, pulse, float, and burp charging, and so on), each with their assumed or calculated time constants. Typical charge transfer time constants might be less than a minute, and a mass transport time constant could be several hours for a cell with plenty of Ah. Certainly, this is the case with the large capacity batteries in ebikes discussed here.
All of these things lead to the real reason people talk about damaging batteries with regen. Using regen from your ebike is best described as “random charging.” Constantly varying potential and concentration fields within the battery, and variable electrode process environments. But it’s not all about damage. It's not even all about "internal resistance." Simply put, the electrode and electrolyte processes will be continually varying in efficiency.
solarbbq2003 hits the nail on the head here:
solarbbq2003 wrote:I guess also justins % graphs are based on current measurements via shunt? Would it be correct to assume the % graphs given will be slightly overestimating the actual % stored in the batts?
For the reasons I mentioned above, the Cycle Analyst will not by itself give an accurate accounting of the real, (re)usable energy put back into a galvanic battery by regenerative braking. It's not enough to measure the current and multiply by the individual slices of time. And forget about motor winding losses for the moment. Your battery, which even has charging losses when plugged into the wall on a 0.1C slow charge, will have a higher charging loss if you quick charge at 0.3C. Things will get worse with a fast charge at 1C. If you really want to kill the charging effectiveness, ride around with it and subject it to constantly varying charging and discharging loads!
I'll close with this - an ultracapacitor, while containing chemicals for things such as the dielectric layer, does not involve a chemical reaction at the electrode surface. No reaction diffusion time constant, nor is charge transfer between surface species is required. If I send 10 A for 14 s to my 140 F capacitor, I will expect (neglecting the very low resistances involved) an increase of one volt in the capacitor, with the associated energy storage that depends on the squares of the initial and final voltages. Send in 20 A for the same time, and it's two volts. 40? Give me four. The best news is that I can expect the Cycle Analyst to accurately track power and energy coming and going, nearly regardless of the rate of electron supply or withdrawal.
An ultracapacitor would absolutely help improve the percentage of recaptured energy when compared to a galvanic battery.
JCG
Postby ZapPat » Sun Jan 04, 2009 12:15 pm
JCG wrote:
justin_le wrote:
paultrafalgar wrote:Justin, could you improve the regen capture by using an ultracapacitor as intermediary, with an ultracapacitor such as JCG uses here:
[... more interesting discussion of a cell's electrochemical functions ...]
This page refers to lead-acid cells, typicaly being very pathetic in their chemical charge/discharge characteristics. This is why no one with any sense would ever use lead in a modern EV that makes heavy use of regen (or pretty much any EV in my opinion). Someone switching to lithium from lead-acid (even without using regen) realises the huge difference between the two chemisties. I would like to see this kind of analysis applied to modern LiFePO4 though, that would be great!
I think Justin's point about the overall regen efficiency actually being better at 6 Amps when compared to a more intense regen of 20Amps for the same situation is quite valid. The point that using ultra caps would not really change much in this scenario is true, since much of the loss of energy happens elsewhere than in the battery anyways. Your extra 10% or so loss during charge/discharge of a lithium battery is not really much compared to motor and controller losses.
Of course the fact that ultra-caps are electro-static devices would give them significant advantages for high-power stops and starts. The real problem is that they are not yet suited to real transportation needs because of their energy density (until we have high-Voltage EESTORs or the high-Capacity MIT nanocarbon tube ultracaps at least). The real problem with using them coupled to a battery pack is that a bi-directionnal DC-DC converter has to be used, because straight paralleling of these two devices would leave the electrochemical device bearing almost all the current anyways. To partially get around this, you could have a contactor to switch between battery pack and ultracap pack when going from acceleration/breaking to regular cruise speeds. Either way, you would need some method to adapt the much different voltage vs charge curves of the two devices for the caps to do any real work.
But with appropriate lithium cells, this "varying efficiency" will still be quite high, as long as you are staying inside the cell's charge and discharge specifications. Same goes for your "random charging" comment - just keep the cell voltages, currents and temperatures at what the cells like and there should be no reason that "random charging" will have any negative effect on them (other than regular ware).
I understand what you're getting at here, but I think the wording at the end is kind of misleading. You start by talking about the error between current put into the battery vs the actual current that is stored and can be re-used, which could be called "charging effectiveness" . However, you then state that subjecting the battery to constantly varying charging and discharging loads will "kill" the charging effectiveness - what?? Your accumulated in-out error % will get bigger, but the battery is just as happy with small charge/discharge cycles, and likely even happier according to most of what I've read about LiFePO4. People here already have enough false negetive bias towards regen as it is, so my point is to watch the way we term things relating to it!
Yes, the caps are more predictable since they are simpler devices and their SOC is so easy to know. BTW, what kind of internal resistance does that capacitor bank you use have, JCG?
True for an added reduction of maybe 10-15% in battery-related losses, but not without some additionnal circuitry to make it practical. However, controller and motor losses are still the same for identical currents, and these losses can be quite a bit bigger than charge efficiency (battery) losses especially when using higher currents.
JCG - I read all through both your supercap bike threads and wish you luck with your cool project. You like these caps so much, you must dream of the new developments going on in this field! Hey, if I thought that these newer high density super caps would be becoming available to the public in the next few years, I would be adding a nice bi-directionnal DC-DC converter to my controller project fo sure! But as it's going now, I don't think we'll be able to get our hands on any for a while yet... :roll:
Ciao!
Pat
ZapPat
Postby JCG » Sun Jan 04, 2009 4:22 pm
Sorry that original post was so long, Pat. I found this (very interesting) thread pretty late in the game.
ZapPat wrote:This page refers to lead-acid cells, typicaly being very pathetic in their chemical charge/discharge characteristics. This is why no one with any sense would ever use lead in a modern EV that makes heavy use of regen (or pretty much any EV in my opinion).
The principles are the same for any secondary galvanic cell. I should have focused on a line in the middle of that page to be more clear. Here it is:
"The problem is the 'Charge Efficiency.' It is something that can only be measured for a certain discharge and recharge cycle. It cannot be calculated. It cannot predict anything. The effect of it can be measured. But change the discharge loads, or their duty cycles, or the charge rate, and the "charge efficiency" will come out different every time. "
That point is true for batteries, not caps. We need to make sure that we're comparing apples to apples. Take two otherwise identical bikes with either a 48V UCap module or a 48V Li-ion pack, and the caps will capture any braking current with equal or greater efficiency vs. the galvanic battery. I wanted to show the chemical reasons for that. Batteries should capture small currents more efficiently than large ones. My goal was to say that the caps are OK with either high or low regen currents (and all in between), and should be able to efficiently store any current that is provided. Batteries and caps may indeed capture small currents equally efficiently - but the caps will cover the whole current spectrum more efficiently.
There has been some promising work on this; a while back NREL did a study just connecting the batteries and ultracaps in parallel, to "share the load" as their impedances would allow them to. No DC-DC converters, no switching. It's old, but I think you'll really enjoy this presentation:
http://www.nrel.gov/vehiclesandfuels/energystorage/pdfs/2002fl.pdf
In summary, the caps were able to protect the batteries from the worst surge currents. The same should go for sending current the other way.
Not quite - see the next comment below.
There is a price to pay with variable current to or from a galvanic cell. It unfortunately takes energy and time for the electrode-electrolyte concentration fields to set up to any given charging or discharging current. A lot of current variation from one to another will cause the need for those chemical changes to occur and will waste energy in your bottom line.
Maxwell quotes the ESR (Equivalent Series Resistance) of the individual cells (which are in series to make the module) as less than 0.3 mOhm. They call it "ultra-low..." but you make the call. I guess it doesn't sound like much, but I don't know how much progress a number like that represents vs. the rest of the field.
I apologize if my previous post sounded edgy or combative - not my intent. I just didn't like hearing that the caps "wouldn't do squat" and thought I could provide a second opinion... NREL and Maxwell are banking a lot on the fact that they'll do far more than squat. I have a bunch of resources available on the cap-battery tandem in hybrids - anyone can send me a PM and I'll send them along.
Thanks for the kind wishes - luck is actually pretty useful to this kind of work. I've had so much fun doing this project I've kind of forgotten about the work that comes later with a full size car. My ultimate hopes for the caps lay in the talk of their "projected low cost," abuse tolerance, and lifetime. I am really excited by what I've seen so far with the bike, and I know we'll get a paper out of it. It's nice when you can really get excited about work (no matter what you do). All I know is I'd be stuck in the mud without these forums.
JCG
Postby solarbbq2003 » Wed Jan 07, 2009 6:39 am
One time i was doing a long ride ( 60km, well its a long way for me! ) and had two cobalt 48v 15ahr packs, one pack had pretty much run out of juice climbing a fairly long hill ( quite a few km and quite steep), instead of changing to the other pack, I decided to use regen on the discharged pack when coming down the mountain ( big hill really) and see how much distance it returned to the pack, results were very poor, amount of regen capture was extremely low I was quite surprised I was expecting that a discharged pack would capture at least enough to continue some distance after the mountain. Sorry no data to go with it was some time back and I had no monitoring equipment apart from analog display of current.
The reason i'm mentioning is that puting regen energy back into a discharged pack is one way of getting some way to measure how much energy has gone back into the pack. I've been using regen braking with cobalt packs for a long time and seem to be little effect on longevity of the packs. Though I'm a bit worried about using regen braking with nimh packs and effect on longevity.
but I am a supporter of regen braking, it makes a hell of a brake ( not having to squeeze a brake on hard to stop is a good thing)
I was of the impression that ultra caps would make a significant difference in energy that can be captured ( but no experience with them unfortunately). Though have been shown a simple ultracap set up used with bike dynos for bike lighting ( done by kerry from ktronik australia : small lithium batt and ultracap used in parallel...I think), and I was surprised at how simple they were to use at least on that type of setup.
solarbbq2003
Postby Knuckles » Mon Jan 19, 2009 5:38 pm
Turns out the Infineon has regen braking.
It was there all along. Works great too.
Testing ... Testing ... Testing ...
It has regen (down to dead stop) on the eBrakes.
It also has regen on the throttle control down to about 15% of full speed.
These values are all set by using the software flash to program the MCU.
viewtopic.php?f=2&t=8317
-Knuckles
Now this is not the end.
It is not even the beginning of the end.
But it is, perhaps, the end of the beginning.
Knuckles
Postby ZapPat » Fri Jan 30, 2009 3:29 pm
Knuckles wrote:Turns out the Infineon has regen braking.
Knuckles - I checked out your tech info threads to look at what can be configured on the infinion, but I couldn't find a current limit for the regen. We usually need to keep the max regen current lower than the max drive current for most batteries. This is doubly important since the batterie's BMS can not cutoff regen current itself because of the internal diode in the MOSFET that automaticaly conducts on reverse current.
Thanks,
Pat
ZapPat
Postby Knuckles » Tue Feb 03, 2009 8:29 am
I have not yet measured the Infineon regen current in the 72V range.
It appears to be software regulated and a fraction of the programmed drive current.
(Another reason for a home-made dynamometer perhaps?)
The regen works very well, however, on the flat during road testing.
I like the idea of "braking by wire". Very cool feature.
Knuckles
Postby Roy Von Rogers » Tue Feb 03, 2009 9:59 am
I had wondered if it is possible to engage regen in the same manner as a throttle via hall effect. But since I have never experienced how hard regen kicks in, I'm not sure if such a device is needed. Such a device could be engaged with the brake switch mechanism and the harder you pull the brake lever, the more the regen would operate. I know this would bring about more complexity, but was just an idea I had pondered about.
Roy
Roy Von Rogers
Postby ZapPat » Tue Feb 03, 2009 1:15 pm
Roy Von Rogers wrote:I had wondered if it is possible to engage regen in the same manner as a throttle via hall effect. But since I have never experienced how hard regen kicks in, I'm not sure if such a device is needed. Such a device could be engaged with the brake switch mechanism and the harder you pull the brake lever, the more the regen would operate.
Regen braking could easily controlled like this via a second hall-effect throttle, if a controller would exist that had a second input for this (in fact I'll add this regen control option to my long term controller build wish list!).
Something close to this setup does exist though:
- When your brake lever switch (on/off) is triggered, you controller is now in regen mode and the throttle now acts as a variable brake instead of a regular throttle.
Other ideas for regen input are:
- Dual direction throttle (center return): One way controls drive current and the other way controls regen current.
- Snap/Roll throttle: Uses regular style throttle, but in a different way; Quickly letting go (snaping back) lets you coast, while slowly rolling back the throttle engages regen and adjusts it's strength.
ZapPat
Postby Knuckles » Wed Feb 04, 2009 8:22 am
The Infineon has Throttle regen also.
The throttle regen is an option in the software interface.
I have the throttle regen turned off for now but it works very nicely.
Same amount of regen braking at higher speed.
You can ride (accelerate and decelerate) by throttle alone.
As the bike slows down, however, throttle regen turns -off.
The eBrake regen is continuous to a dead stop.
The throttle regen disengages at maybe 15% of full throttle.
Knuckles
Postby fechter » Wed Feb 04, 2009 9:42 am
That kind of 'throttle regen' is similar to the MCIPC24 controller my Zappy has. I did not like it since it does not allow for coasting unless you hold the throttle just right.
Having the regen activated by the brake lever is much more intuitive.
The old Xooter EX3 had a bi-directional throttle that operated regen in one direction. I don't think it would be easy to implement this kind of feature on the Infineon, but it would be a nice feature.
Using the regular throttle as a regen control during braking could be a problem if you were on full and suddenly let off the brake (it would go from full brake to full throttle). It's also a bit akward to operate a throttle and brake lever with the same hand.
fechter
Postby ZapPat » Wed Feb 04, 2009 12:50 pm
fechter wrote:The old Xooter EX3 had a bi-directional throttle that operated regen in one direction. I don't think it would be easy to implement this kind of feature on the Infineon, but it would be a nice feature.
Any idea where we could get such a dual-direction twist-type hall throttle (center return)?
Or maybe a lever-style hall throttle (linear) to be used as a regen brake? This might be easy to make with a couple magnets, a metal strip and a linear hall sensor (as used in the twist throttles - A1302 from Allegro, digikey #620-1022-ND) mounted to an old brake lever. The chip's output changes depending on it's position between the north and south magnetic poles. Might be a fun project if nothing exists out there...
On/off type regen braking (meaning single strength) is probably usefull but also kind of limited, although if "pumping" (ramping up/down of regen power) implemented in the controller's software it would be more acceptable since we could then modulate the regen power this way.
fechter wrote:Using the regular throttle as a regen control during braking could be a problem if you were on full and suddenly let off the brake (it would go from full brake to full throttle).
I was wondering about this myself, and have read that a number of controllers force you to stop moving before changing modes (golden motors), but then force you into the permanent "engine brake" style drive/regen. No coasting. Does the infinion do regen via throttle in this manner? Knuckles showed us where we can activate it in the software interface, but I think there is also an input that can enable/disable all regen on the fly. It seems to me that to make this type of regen control safe, the controller should only do the switch to/from regen mode when the throttle is droped to zero.
I wish I could do more tests outside with both controllers, but it's about -20oC here and there's tons of snow! I'm looking into a front ski conversion and screws in the back tire to take care of this problem soon! :twisted:
ZapPat
Postby StevenR » Thu Feb 12, 2009 7:24 pm
Please excuse the excursion from theoretical to practical.
My motor is a C'lyte 5303 and the battery is a Ping v2 48V20aH with a Crystalyte 4840 controller. I enabled regen and saw 5 to 10% regen on the Cycle Analyst over the course of several hundred miles. I disabled it when I blew up the caps. I am considering upgrading the caps on my backup controller and re-enabling it, given this discussion.
When regen was enabled the phase wires to the motor got warm - perhaps even hot. They never seemed at all warm when regen was not enabled.
My question for this wise group is this: Does the C'lyte regen actually work? Am I pushing juice back into the battery or am I just heating up the wires because the voltage is below battery voltage?
On a related note: Can I enable regen on the ebikes.ca model C7248SI 36-72V 48A Start Immediate Digital Controller withIRFB4110 Mosfets in the same way I do it on the standard C'lyte controller (I would put the ebrakes and cruise control on as well)?
If the C'lyte does not work, what is a good regen controller? Curtis? Kelley? Other?
Bianchi Alante MTB with C'lyte 5303 Front Hub Motor / Motobecane hardtail MTB with C'lyte 5303 Rear Hub Motor
CT48V35A Controller / method monster 100A100V controller
Schwalbe 26"x2.3" Big Apples / 26" Schwalbe Ice Spiker Pros
Ping v3 48V20aH with 60A v2.5 BMS / Headway 48V10aH BMS used to balance, bypassed on discharge
Pick one from each row above
StevenR
Postby Knuckles » Thu Feb 12, 2009 7:57 pm
ZapPat wrote:It seems to me that to make this type of regen control safe, the controller should only do the switch to/from regen mode when the throttle is dropped to zero.
The Infineon regen appears to be "smart". It follows an algorithm of sorts.
So no problem with WOT while braking and then releasing the brake.
Also no heating effect of motor, controller or harness. Just very nice braking with reverse current to the bats.
The regen works great. I just use it.
Very cool also. I tap on my rear brake handle (right side) and my front DD hub slows me down.
(20.87 KiB) Downloaded 383 times
Knuckles
Previous
Return to Technical Reference Area
Users browsing this forum: StyxFly and 1 guest
