knoxie wrote:Hello
PLEASE READ THE PHOTO THREADS FROM THE BOTTOM UP!
Sorry about that the board formatted them that way.
patrick_mahoney wrote:Thanks for the post. Very nicely and cleanly repaired. I have a dead controller that I haven't looked at. This thread is inspiration.
Mathurin wrote:Dude, nice writeup.
From what I take of it, too small a cap will tend to heat up.
What's this you say about using some silicon sleeving to insulate the
tab of the fet from the heatsink instead of the stock liner?
Lessss wrote:Bob over in PA????? Power assist? Pensylvania?
knightmb wrote:knoxie wrote:Hello
I changed around the order for you so that it reads top to bottom![]()
I've also fixed up the comment field in the database to allow longer comments. It was originally set for only 255 characters, should be able to do about 25,000 characters now (hopefully you won't need more than that)
You should be able to edit your post and update the comment fields so they have everything you wanted to put in there now.
As for picture order, it got me to the first time, especially attaching multiple pictures. Basically, think of it like Tetris, those attachments that go first land at the bottom and everything else stacks on top. I do wish for a nice "move attachment order" button, but for now this is what we have.
it would be nice if the 4110 would work, as it is the 100v fet with the lowest Rds-on, but the gate charge is pretty high, and i am not sure the ir2101 driver could handle it.
'm learning tons here (thanks Knoxie, Rich and all), and I don't mean to derail this discussion, but I have a quick question. Has anyone here experimented with getting brake regeneration from these controllers?
Users browsing this forum: agniusm, cal3thousand, Stumbc and 10 guests
