surly ict emotor convert
marekhlina   1 µW
Post by marekhlina » Nov 08 2019 4:11am
Hello guys,
is it mission impossible to mount a motor to this beast?!?...surly ICT 132mm BB / 150x15 front axle, 197x12 rear axle..any advice would be very much appreciated!!!
https://photos.google.com/share/AF1QipM ... ZTVmc3MjRB
https://www.tritoncycles.co.uk/frames-f ... set-p17173
https://www.youtube.com/watch?v=mriO7EXHRpM
dogman dan   100 GW
Re: surly ict emotor convert
Post by dogman dan » Nov 09 2019 7:56am
The seller I know of that has mid drives for fat bikes has a 120 mm bottom bracket kit, but not one in 133mm.
So I would start looking for fat tire, rear hub motors with long enough axles for your bike. If that cannot be found,,,
One US seller has a fat wheel kit, but again, not as fat as your bike rear width. You could build a dropout plate ( torque arm plate) to attach to your frame, which would make the width narrower, and the bike a few inches longer. Basically, a piece of metal that bolts to the inside of the rear dropout, creating a new narrower dropout just behind the original one that is narrower. New disc mounts would be part of the plate on the left side.
Another option would be bend the frame back in some, but I would hesitate to do that to a frame that nice.
2old   100 kW
Post by 2old » Nov 09 2019 9:29am
Doug at CA bike used to machine BB parts to extend a 68 - 73 BBS BB ot "fat bike" width. Maybe he can machine something to take a 120 to 132.
marekhlina   1 µW
Post by marekhlina » Nov 09 2019 1:02pm
talked to Doug / US guy/yesterday...min. production is 100pcs....in general it is doable...obviously can't pay for 100pcs...
Balmorhea   100 W
Post by Balmorhea » Nov 09 2019 1:36pm
If your bike has MDS dropouts with replaceable plates (newer ICTs do not), it should be relatively easy to modify a pair of those, adding material to the inside surface, for somewhat narrower hub spacing. You could integrate a nice torque arm in the process.
By "relatively easy", I mean it would be a machining and welding project with demanding precision requirements. But gratifying if you can make it happen.
marekhlina   1 µW
Post by marekhlina » Nov 09 2019 2:01pm
would like to keep 2xl snowshoe tires...so don't want to change MDS dropout ...https://photos.google.com/share/AF1QipM ... ZTVmc3MjRB
[youtube]https://www.youtube.com/watch?v=x7btX4_ ... e=emb_logo[/youtube]
