Time for yet another motor change for my Raleigh test mule. First there was the 36V Bafang QSWXB which migrated to my Kona Smoke, then came a Nine Continent 9x7 motor, a real hoot at 48V but too big, and now a 24V Golden Motor mini-motor…well, just because.
I ordered the mini-motor from Golden Motor for $139 and 9 days later it was delivered but was damaged and unusable. I contacted the folks at Golden Motor and was promised a replacement. Two weeks later and I found out they never shipped it but promised to do so right away and true to their word less than a week later (yesterday) the new motor arrived. (
Thank you Mr. Yao Yuan and 'Tom' .
This “mini-motor†truly is small measuring about 1cm smaller in diameter than my Bafang and weighing in at
5 lb 12 oz (2.6 Kg) compared to my Bafang at 7 lb 2 oz (3.2 Kg). The motor is also disc capable. Dimensionally and appearance-wise it sure looks like a Bafang QSWXH, and that’s not a bad thing.
I removed the 9C motor from the Sun CR18 rim and laced up the Mini using 258mm Wheelsmith DH-13 spokes with 16mm nipples in a 2X configuration.
- GM Motor 021.jpg (86.74 KiB) Viewed 1513 times
I ran into just one problem; the Mini was too narrow for the forks which is odd since the Bafang and 9C fit snugly into the same opening. I moved one of the thick anti-spin washers to the inside and that fixed that.
- GM Motor 024.jpg (86.41 KiB) Viewed 1515 times
I used two of the 9C’s mini torque arms to help secure the mini-motor.
- GM Motor 025.jpg (89.34 KiB) Viewed 1517 times
After that I lopped off the phase wire bullet connectors and installed Andersons to mate with the little 36V/15A 6 FET controller that originally came with my Bafang motor (that motor now runs on an E-BikeKit 9 FET controller at 48V). The little motor spun up right away with a promising no-load speed of 30.1 mph at 41.0V powered by my 36V/6Ah Bosch Fatpack 3-pack.
Today I took out the GM mini-motor for the first time. The low end grunt is meager, far less than the 36V Bafang at 48V and perhaps even less than the Bafang at a stock 36V, it’s hard to remember now how it felt. Acceleration on the motor alone is weak at any time making this a true “assist only†set-up. The trade off for this weak low end performance is speed and in that department this 24V Mini is much faster at 36V than the 36V Bafang on a 36V pack. On this bike with 700x35 tires the Bafang topped out in the low 17’s while the top speed of the 24V Mini at 36V is in the vicinity of 22-24 mph. After one ride I can’t pinpoint the top speed any closer since level ground and no wind conditions are hard to come by plus I believe the 15A controller is a limitation here. At top speed the controller is pretty much maxed out so any undulation or wind impacts the speed more than usual. I have another 22A controller I can use in the future to check this out. The last 4 miles of the ride today I held full throttle much of the time and the motor barely got warm...promising.
-R
