Cortina Hard Tail Build
Postby RWP » Wed May 20, 2009 4:27 pm
Cortina Triton DS - My first electric bicycle.
Cortina Triton DS
I am in awe over all the fine work that is coming out of ES.
All this is soooooooo inspirational for me. In a way it has changed my life and changed my direction.
So my hat’s off to Matt and all of you creative hard working pioneers!!!
About a year ago I saw Matt’s build site for the recumbent and flipped out - it was so very cool. I wanted one. Many years ago I worked on cars but somehow never got into making custom stuff, but it was always on my mind. Since then I had a number of professional type design oriented and Internet based carriers. Recently I longed to work with my hands again, sitting in front of a computer day in and day out was getting really old. Seeing all this creativity blasted me into action.
My goals are many and I have a number of reasons for wanting to make electric bicycles:
One is simply to make an attractive, powerful, and practical electric bike and in the future three-wheeled, two seat, full suspension electric vehicles.
I want to provide a real alternative to fossil fuel vehicles.
I want to demonstrate and encourage others that with relatively simple tools and some dedicated time and energy and a bit of ingenuity one can make an electric bike in a garage.
I want to re-skill myself to work with more advanced tools and processes like bench top milling machines and engine lathes.
I started making sketches of drive units similar to Matt’s that became known as Phase 1. Then I got a bike to power up. It’s a hard tail Cortina and my first build is with what I call the Phase 2 guts enclosed motor drive unit.
A little back story: About a year ago I met a friend who also was interested in electric vehicles. We both wanted to do a car conversion but held back because of the cost of batteries and the shear size of the project. We started talking and decided to do an electric motorcycle conversion project - a 250 Ninja.
So many words so little time…one thing led to another and in January in earnest we started on the Ninja and two other projects. My friends project was to put e-power to a BOB bicycle trailer and mine was to power the Cortina. In order to keep us on track we set a goal to have all three projects in running presentable form to show at Earth Day here in Santa Barbara. We did it!!!
The deadline kept us focused and on track. All the projects work but as can be expected with prototypes and home builds they need further development and fine-tuning. It was a great high to get all this together in 4 months; we started in earnest in January. Earth Day was April 19th.
OK, on to the Cortina
It’s a Cortina Triton DS (http://en.wikipedia.org/wiki/Cortina_Cycles) with a Towerpro motor, HV110 controller and Lipo’s. Elsewhere in ES several people mentioned that it would be cool to have the drive reduction components inside and not exposed. This got me thinking about how I might enclose the pulleys and belts. The solution I chose was to put the drive unit reduction parts inside 2”x4”x1/8” alu tubes. I went with these tubes because I could buy them off the shelf and modify them as needed. There were issues with this choice but to get going it was the decision I made. The Phase 3 drive will be much easier to work with.
Belt drive unit looking at the first jack shaft.
Another view of the drive unit. With the vertical element flipped 180 in the vertical axes this element can then be radially rotated to fit other possible locations. It's similar to but not as flexible as Matt's drive. The slots in the bottom element are how I adjust the motor to crank chain.
Enclosed 5mm GT2 x 15mm drive unit ratios:
15 – 56 primary belt drive – Motor to Jackshaft - enclosed
20 (was 15) – 56 secondary belt drive – Jackshaft to Output shaft – enclosed
Exposed BMX Chain ratios:
16 – 48 primary BMX chain – Output shaft freewheel to Crank Chainring
30 – 18 secondary BMX chain - Crank to Nexus Inter3 w/disk brake hub
…then the ratios in the hub…still trying to find out what they are…
I can pedal to about 20mph and then the motor over runs the cranks. So far I have pushed it to 34mph with more throttle to twist.
The bike weighs about 52 lbs.
One of the ideas kicked around in ES was to enclose the drive system. Seems I remember a few posts about this. I went with 2”x4”x1/8” aluminum tubing. One for the primary drive and another for the secondary drive. The bearings have split rings in the outer races and are installed from the inside. I think they look cool in contrast to the anodized aluminum tubing. The 2x4 tubing restricted the reduction ratio because the largest pulley/belt I could get into the 4” dim was 56 teeth. Mostly it’s been successful but it’s a bear to work on because everything seems to be connected to everything else. Pulleys and spacers hold the bearings in place and it’s all very cramped – it goes together a bit like a puzzle. In this way Matt’s drives are the ultimate in simplicity. Phase 2 is OK for a prototype but the Phase 3 drive will be much more user friendly. The only reason I did not go with Matt's drive was that all the spinning stuff is exposed. Again this is not a criticism of this drive which I perceive as very prototype and development friendly. My preference is not to have any spinning stuff exposed including the motor.
The jackshaft and final drive shaft are ½â€ mild steel (if mild steel is not the best material for this use - suggestions are appreciated) from McMaster and now that I have my X3 Small Mill going and machined flats on the shafts they are much easier to work with. Previously I made the flats with a file…
Another thing I did was to use two belts instead of a belt and chain. Time will tell if this will work. So far so good but the Towerpro motor is rated at about 2700 watts (I cannot verify this rating) and if I go to a larger motor the secondary belt may fail.
The original 15x56 secondary drive belt failed. Made awful sounds that I finally traced to the belt jumping cogs. Went to a 20x56 (from 15x56) and still have to test it to be sure it will work in the long run. This gave me 8 instead of 6 teeth engaged on the drive pulley. So far so good, but I have not yet really cranked on the power fully.
I went looking for 8mm pitch pulleys and belts and came up more or less empty. Torquetrans.com http://www.torquetrans.com/pulleys/timing-pulleys/8mm.htm, which seems to have all the right stuff, will not sell individual pieces like Stock Drive. Perhaps I am missing something here but I think the 8mm pitch x 20mm wide belt systems will take all the punishment we can give it. I think the belts are readily available, it’s the pulleys that are hard to find and when they can be found are very dear. Another way must be found to attach the pulleys to the shafts as my grub screws all seem to loosen over time. I also do not think grub screws were designed to handle the torque I will be putting to them.
I read about people using internal geared hubs and wanted to give this a try. Shimano recently came out with a three-speed hub with disk brake and it worked just fine lining up with the existing caliper without any modification. Used a Surly chain tensioner to take up the slack. The rotating shift mechanism is mounted on the left handlebar - so I am free to twist the throttle with my right hand and shift with my left.
It’s a through the crank drive and this was a bit fun to put together. Thanks again to ES and you guys…ES is everywhere in this project – so if I forgot to give credit I give blanket credit here. I got the crank and freewheel stuff from Sick Bike Parts and the offset BB from TartyBikes. I started with a standard Shimano BB but the inner chain ring was too close to the chain stay…then got an Echo offset BB that give me a few extra mm’s for clearance. I think it still rubs a bit when pedaling hard.
Close up of drive system. The anodized cases contain 5mm GT2 belts and pulleys. The Chain is 1/8" Wipperman BMX with a Surly tensioner. This picture does not show the new ENO freewheel or the ENO Sick Bike Parts trials crank adapter. Both are currently installed with no plans to go back to the parts shown. It's a bit of trial and error as I learn about new parts and systems. All the holes around the bearing was to allow the primary and secondary drive systems to rotate around to fit other possible locations.
OK, looks like the Sick Bike Parts trials White Industry freewheel adaptor has a lot of side to side play. Not sure exactly how much but it seems significant – way more than I am comfortable with. It has not failed but then I have not really ridden it enough to tell how it will hold up over time.
I was trashing drive output freewheels until I put an ENO on. Now all is well.
The batts are Lipo’s in 10s2p configuration (four - 5s 5000mAh - Zippy Flightmax 20c) – 36 volts @ 10 amp/hr. They are housed in a sturdy plastic case along with a contactor and main disconnect. The case is mounted on a seat post rack. I hope in the near future to double up the pack to 20 amp/hrs.
The throttle control is via Magura wired into the servo tester replacing the pot. There is a kill switch as well. I start by switching on the disconnect and when I hit the kill switch the contactor closes and the controller fires up. I also have an eLogger in the system. For now the HV110, servo tester, BEC and logger sit on a Lexan board in front of the battery case. I am planning to make a box for this stuff something like oofnik did for his Mongoose DX build. So far I have not pulled more than about 60 amps, but I am being gentle because of the belt situation.
Battery box with contactor and disconnect. Lexan plate with controller, EagleTree, servo tester and bec.
I have been thinking about going to a larger motor because the Towerpro runs hot. Not sure what the actual temp is but at times it’s too hot to keep my hand on. Now that the drive unit issues seem to be resolved I will run it for a while and see what happens with the temp and power. I am concerned that if I go to a larger motor the belt slipping issue will return. So for now I will wait and see how it goes.
Not sure just where and how to add caps to the controller. I got 2 - 50v 1000mf caps and wired them onto a Dean connector (the polarity is correct). I made a Dean connector adaptor to allow an inline installation but this puts the caps about 4 or 5 inches from the HV110 and the caps are soldered to the adaptor with 2 to 3 inch leads. I am a little gun shy because when I first tried to add the caps I fried a BEC. Truth is I may have had the BEC installed with the polarity reversed.
I will soon have more info from the logger and will post that here.
Mounting…seems like tremendous energy is going towards developing a clamping system that does not alter the bike (an observation not a criticism)…I decided to alter the frame to mount the drive unit. I drilled two holes in the seat tube and brazed threaded sleeves into these holes. A U shaped alu mount screws into the 2x4 secondary drive tube and is slotted to fit the sleeves brazed onto the frame. The slots allow the motor unit to slide up and down to tension the drive to BB chain.
I put Bontrager Hank 2.2 slick tires front and back for a cool look and fine ride. I wanted to get another pair but seems I got the last ones available in Santa Barbara!
Speaking of riding…this thing flies…still working out some driveline/freewheel issues (seems going from 15 to 20 tooth pulley and the ENO has made a big difference) so I have not twisted to full power. But it pulls strong in second and third gear and it feels like it may wheelie in first. It will start from a stop in third gear just fine but I have been pedaling in first and then screwing on the throttle then easing off the throttle to up shift. I can pedal normally in all three gears and when the electric kicks in it just pulls away overrunning the pedals. So far CatEye tells me the Cortina goes 34mph with more left in the throttle.
My main problem areas have been the slipping secondary belt and going through freewheels. I think the freewheel issue is solved and, unless I can find some 8mm pulleys and belts, I will most likely to go to a chain for anything over the first reduction in the future.
I do not know if the secondary belt drive unit, motor or internal 3-speed hub will hold up over time. This is still to be determined.
I want to revisit my original goals and see if I have achieved what I wanted in my first electric bike project.
Failures:
Hard to access the drive unit internals for easy repair
5mm timing belts do not seem up to the torque after the first drive reduction (I know – I know – this was made very clear)
Motor runs hot (is probably too small for my design goals
Up for Grabs:
Through the crank drive – seems fussy to gear the drive down and then back up again at the crank
Fixed center design for the secondary belt (no tensioning system)
3-speed hub –do not know if it will handle the power but so far so good
Every time I take the drive unit apart I check for, and find, loose grub screws. Perhaps another way can be found to secure the pulleys and sprockets to the shafts?
Lipo battery
Successes:
Building this bike has been great fun and a personally rewarding experience
I built my first running eBike with relatively simple tools and some outside machine shop work
It’s an attractive machine that goes faster than I am comfortable riding
It’s a great test bed for future projects
Easy to remove drive unit from bike
Wishes for the future:
Enclosed transmission of some type (CV would be great) – maybe with a 90-degree drive system
Purpose made controllers
Better range of quality motors
Battery – love to find a non volatile battery with equal or greater energy density
Again much appreciation to all the great folks and projects here on Endless-Sphere.
I know this is a monster post...I shall try to restrain myself in the future. If you have gotten this far - THANK YOU!
Roy
Cortina Triton DS
Cortina Triton DS
My electric vehicle projects Home of the eTownie & eCortina
Cortina V3 Turnigy 80x - HV 160 - 48v 15Ah
Cortina Revisited Turnigy 80x - HV 160 - 48v 15Ah
Cortina Hard Tail Build Cortina Triton DS - eFlite 160 - 36v 10Ah LiPo - TURNIGY K-Force 120A-HV - Nexus 3 speed internal hub
RWP
Re: Cortina Hard Tail Build
Postby Miles » Wed May 20, 2009 4:39 pm
Nice work, Roy. I like your style :D
Shouldn't be too difficult to get 8mm pitch pulleys. HTD and PowerGrip GT are the same profile for 8M.
Did you see this thread? http://www.endless-sphere.com/forums/viewtopic.php?f=28&t=8491
Fixed centers for belts is problematic, if you're pushing things to the limits...
Looks like you've got plenty of room for an even wider 5M belt for the second stage, so that's another possibility.
Miles
Postby deecanio » Wed May 20, 2009 4:56 pm
very, very nice 8)
Cheers,
D
Kona Stinky 2004
Marzocchi JNR T's 2004
72V 10ah lipo
Xlyte HS3540
Lyen 12 FET Jozz mod
deecanio
Postby Miles » Wed May 20, 2009 5:18 pm
Re. problems fixing to shaft with grub screws - I think you need more than a single flat. Two grub screws @ 90 deg., into grooves on the shaft, works well or, if possible, keyways.
Miles
Postby RWP » Wed May 20, 2009 5:39 pm
Hey - Thanks so much Miles and D!
Miles,
And thanks for the 8mm link - I will spend some time there.
Did not know I could get wider belts. So I can get pulley stock and make my own pulleys? That's a cool idea. Is this what you are suggesting?
Will this significantly reduce efficiency? If I double the belt width will I double the torque capacity? My guess is I will get more, perhaps 1.5, but not double...what's your take on this?
Yeah, I probably will not do another fixed center design. Have you ever used mounted or flanged bearings to solve the belt adjustment problem. I would like to avoid idlers if possible, but idlers might be the way to go. Idlers for a say 30mm wide belt would be quite something...not sure how I would do this...maybe a 30mm wide needle bearing on a hardened shaft?
I am using two flats on each shaft with 90 deg screws. I could get shafts with a 1/8" key way and machine another flat at 90 deg. This would probably work better. Maybe I am just not tightening them enough...
Roy
RWP
Postby Miles » Wed May 20, 2009 6:13 pm
You could buy pulley stock and do it yourself or get someone to make you a custom one from their pulley stock.
If you go to a transmission specialist, they will have wide belt stock that they can split off to any width you require. I think the torque capacity goes up almost in proportion to the width but I'll check on that.
Some sort of eccentric bearing holder, for the centre adjustment, you mean?
I think V grooves or round grooves are better than flats. If they are really working loose, rather than wearing the shaft, you could use Loctite.
Miles
Postby recumpence » Wed May 20, 2009 9:05 pm
Ahh, big smile! :mrgreen:
Love it!
Matt
1% of the world's population can think "Outside the box". The rest are firmly stuck within the box. Where are you?
recumpence
10 GW
10 GW
Location: On Earth right now. That can change at any time, though..........
Postby EVTodd » Wed May 20, 2009 10:12 pm
Very, very nice build. Very clean.
I like that bike a lot too. My next big purchase is going to be something similar... I've been looking for a nice steel frame. I'll have to check out Cortina's products.
I'm curious to find out why your TowerPro motor is heating up that much. Oofnik is using the same one and said his was only getting warm to the touch. I think he said his was pulling quite a few more amps than yours too.
Anyway... Again. Good stuff. You just made me want to do some more cad work for my project before I go to bed :D .
New Tidalforce friction drive build: viewtopic.php?f=28&t=28029
My Friction Drive Outrunner Setup: viewtopic.php?f=28&t=9652&start=330
EVTodd
Postby Grinhill » Wed May 20, 2009 10:20 pm
Great work Roy!
Could you provide some parts details about your power disconnect/contactor circuit, please.
BTW, I would call that battery configuration 10S 2P.
cheers
1995 Giant Hybrid - Zeta2 with 12V 7AH SLA - removed after one year.
2006 Converted Giant to Geared Brushless Rear Hub with 24V 17AH SLA - bike stolen 2007.
2008 Hardtail MTB Disc Brake - lightweight RC/LiPo system.
Grinhill's Medium-power RC-Motor Hardtail build
The Grinhill Mk2 RC-motor drive
Grinhill III - "Supercommuter" featuring Recumpence RC drive
Grinhill
Postby RWP » Wed May 20, 2009 11:15 pm
Hey thanks you guys - means a lot to me. :D :D :D
Miles...an eccentric bearing mount to adjust centers -- wahoooo - love that idea.
EVTodd...it's all so inspiring - I love it. The Cortina frame is easy to work with. Not sure where to get 'um though (I found this one in a used sports equipment shop and another on CraigsList) - I understand that the Cortina brothers live and race here in Santa Barbara and that a lot of their frames, especially the hard tail types, are made in Mexico.
Grinhill...Thanks for the heads up on the correct description for the battery configuration. I have the contactor and disconnect info at the shop and will post it along with a simple hand drawn schematic in the next day or so.
Roy
RWP
Postby disndat » Wed May 20, 2009 11:52 pm
Hey Roy nice work and welcome to the forum.Question for you-do you know what the final gear ratio is to the cranks?
1000w BMC with 72v and HS3540 at 99v
disndat
Location: California in the winter Toronto Canada in the summer
Postby RWP » Thu May 21, 2009 12:34 am
Thanks disndat!
15x56 = 3.73
20x56 = 2.80
3.73 * 2.80 = 10.45 at the freewheel
then 16x48 = 3.00
10.45 * 3 = 31.36 at the crank
The Towerpro is rated at 235 rpm/volt
235 * 36 (volts) * .85 (efficiency factor) = 7191
7191 / 31.36 = 229.30 rpm @ crank
With my original 15 tooth pulley and 44 tooth chainring it was 188 rpm @ crank
Maybe this is why the motor is running so hot...it's geared so high.
I have a 200 rpm/volt motor - and with the current configuration would result in 195 rpm @ crank
Roy
RWP
Postby flyinmonkie » Thu May 21, 2009 1:28 am
Nice work Roy,
I really like the look of the closed in gearing. It is very clean and goes really nicely with the bike. Those tires are fantastic on the bike as well. It is a very nice looking build and sounds like overall it run well too. I'm sure you'll sort out the issues, they don't sound to big to deal with.
FM
flyinmonkie
Postby deecanio » Thu May 21, 2009 5:03 am
covers over the high rpm spinning parts 8) who'd have thought of that eh ? :wink:
Thats the part i love best about Roy's bike, super cool, i'm going for something similair myself but just to cover the moving parts not encase the drive as sweetly as Roy has done.
I've mentioned this before but not had much response but considering oofniks freind had a jeans and drive experience all the rc users WILL need to address this issue imo, kudos Roy you have done beauts of covers 8)
Cheers,
D
Kona Stinky 2004
72V 10ah lipo
Xlyte HS3540
deecanio
Postby RWP » Thu May 21, 2009 11:34 am
Thanks FM.
Looks like you cover as much of the drive bits as you can with your projects. Looking forward to seeing more of your work.
Hey D...
Thanks again. I really have to acknowledge my working partner, Sri, We have done three projects together now the eNinja, his electric BOB bike trailer and my Cortina. We work back and fourth on the machines and when something is up on one of them we both contribute ideas and labor to move us forward. I hope he will post his BOB trailer project soon as it's really pretty cool.
While primarily the Cortina is for me I generally think about the larger picture and usability for a larger group of people. Enclosing the drive bits seems a natural extension of thinking of these projects as being more in the mainstream. I hope that the ideas work towards more people riding bikes and when needed or wanted electric bikes.
In my mind the Cortina is a bit of a hot rod, you know a bike that goes 40mph (yet to be realized but a design goal) - way cool. Now I see Luke and Matt (and perhaps others) making bikes that - REALLY FLY - now those machines are HOT RODS.
Really the enclosed drive system ideas came from previous discussions on ES and working with Sri to get a practical yet fast and good looking bike. Amazing what a little black anodize will do!!! I still have all the typical bike chain stuff exposed including the drive to crank chain which is where I see some potential for problems. Anyway I am glad to contribute to furthering this work in any way I can.
Looking forward to seeing your build evolve! Word is that we should see something soon. 8)
Roy
RWP
Postby recumpence » Thu May 21, 2009 11:53 am
I am very impressed by your build. You should have enough power for 40mph. But, I would say that is about the max without burning up your motor. Also, your second stage belt drive is probably good for about 3kw (judging by your ratio and power system). Beyond that, it will skip or shred. Other than that, this is the finest home brew RC setup I have seen in a long time that is finished and running. :D
As for top speed, I have the power for 80mph or more. The issue is useability and safety at that speed. I currently have it geared for a touch under 40mph. I may gear it up for 55mph to see if the accelleration suffers much. But, honestly, how often would a bike be ridden that fast? I typically ride 30mph or so with the occasional 35mph run and once in a while I will wind out at 40.
I think your bike would be perfect geared a touch lower to max out at 35mph. That would reduce motor heat. Also, if you do the reduction at the wheel, you will reduce the load on the belts, thereby giving an added safety margin on them.
Matt
recumpence
10 GW
10 GW
Postby 12p3phPMDC » Thu May 21, 2009 4:39 pm
beautiful job on the bike....
excellent work...
I'm planning on the nexus 3sp as an intermediate drive before I go to the left side final drive at the rear.
I thought I had the ratios....but I don't. I think is pretty close to the sturmeys
Edit:
Sturmey AW or similar
0.75
1.00
1.33
Nexus Inter3 (sheldon brown)
0.733
1.00
1.36
186% range Shimano vs. 177% for Sturmey
They are much quieter than the sturmeys when freewheeling.
I wonder if you went a carbon drive belt for the second stage if you'd have problems.
Gates makes a carbon belt for the GT2 5mm...hopefully in the size you need.
I think I got mine from royal products??? can't remember.
edit: royal supply.
"If you don't follow your dreams, you might as well be a vegetable." Burt Munro
The reasonable man adapts himself to the world;
the unreasonable one persists in trying to adapt the world to himself.
Therefore all progress depends on the unreasonable man.
-- George Bernard Shaw
12p3phPMDC
Postby Miles » Thu May 21, 2009 5:01 pm
12p3phPMDC wrote:Gates makes a carbon belt for the GT2 5mm...hopefully in the size you need.
Only PolyChain GT (not carbon), worth investigating though.
http://www.royalsupply.com/store/pc/Poly-Chain-GT-Belts-5M-c1032.htm
Miles
Postby 12p3phPMDC » Thu May 21, 2009 6:02 pm
re: polychain gt vs. carbon
same technology, different naming (yes it is carbon)
12p3phPMDC
Postby Miles » Thu May 21, 2009 6:08 pm
Show us it in the Gates catalogue, then :wink:
In my Oct. 2008 catalogue, it's Aramid reinforced (probably better for us, anyway).
Miles
Postby 12p3phPMDC » Thu May 21, 2009 7:39 pm
I got it from a Gates Applications engineer over the phone......so...?
Right now, all I have is my word...
I can send you his email/number when I get to work....? 8)
Anyway, they run a belt drive selection software call Design Flex Pro...or
something like that. ...search...
I downloaded that one at work, and it's limited to 8mm...
The apps engineer has another piece of software that I haven't tried
it's a got a more comprehensive list including 5mm drives.
That will tell us what the power handling is. I'll go find link.
It is DOUBLE or more.
12p3phPMDC
Postby 12p3phPMDC » Thu May 21, 2009 8:08 pm
Design IQ is the software.
a google search will take you there.
You have to register to download the software.
Here is a screenshot.
I'll try to run some scenarios on it and see
what the magic belt engineerinig box says...
It says "PolyChain GT carbon
and PolyChain GT2" on the design IQ screenshot...
The cool thing is, is that it fits GT2 sprockets...so no problems there.
The belt I'm holding in my hand looks like a very probable carbon fiber aramid band laminate.
It feels like it came from outerspace. It is wild. It's not your grandpas version of a rubber
belt. It's probably the most advanced material on the bike next to the semiconductors
in the controllers or the magnets..
What have people used besides the PowerGrip and the HTDs?
12p3phPMDC
Postby RWP » Thu May 21, 2009 8:37 pm
Wow, thanks Matt - well, more than made my day! :D
I am thinking one way to reduce my speed (and load on the system) is to go from 10s to 8s. What do you think?
I could add some 3s cells in series with my 5s cells end up with 8s 4p instead of my current 10s 2p setup. It would lower the voltage from about 36 to 30 and up the Ah from 10 to 20.
My bike shop said they can't get a smaller sprocket for the Inter3 - right now I think it's an 18...ah...er...maybe 17. Anyone know of a smaller sprocket? Can't go larger at the crank because the 30 tooth sprocket already is far too close to the chain stay. Maybe I could make one...it's looks like pressed steel to me - probably hardened though...I could get a 16 or 17 tooth steel sprocket and make a new one...
Miles
I thought about making the belt wider and nixed the idea. It's already very narrow inside those tubes and I use the extra space to maneuver the parts to get the puzzle back together. If I went with a wider belt I think it may be all but impossible to get it all back in place. I think my options are 8mm pitch belts, going to chain, or reducing the voltage.
Love the eccentric bearing mount idea...still giving this some thought.
12p3phPMDC
Thank you.
I will take a look at the polychain belts. If I understand correctly the polychain are stronger than the powerGrip...is this correct? And if so - how much stronger? Couldn't find this on the Gates site.
They come in 75 and 85 tooth lengths and as I have a fixed center design I will need to explore what pulley options are available to me for one of these belt tooth lengths. Right now I am set up for 15x56 for a 80 tooth belt or 20x56 for a 82 tooth belt - both of these combinations work with my fixed center spec. I have a simplified formula to find working combinations and I can check out the 75 and 85 tooth length.
Just saw your new posts -- I will check out Design IQ.
Thanks again!
Grinhill
Here are links to the contactor I am using:
http://www.robotmarketplace.com/products/0-SL1120.html
http://www.robotmarketplace.com/product%20...%20oid120.pdf
and one for the disconnect/power switch:
http://www.robotmarketplace.com/product%20...%20ELLA1.html
Still working on the schematic...
RWP
Postby RWP » Thu May 21, 2009 9:04 pm
Hey 12p3phPMDC --- Lets get a motor on the Cat :twisted:
RWP
Postby 12p3phPMDC » Thu May 21, 2009 9:41 pm
I'm working on it.... :D
I'll post pics in my build of all the parts that just arrived. I'm excited!!!
You can get a 13 tooth for the Nexus..!!*****
A cool thing about the Nexus and Sturmey drives is that the
sprockets are interchangable.
http://www.sjscycles.co.uk/product-Sturmey-Archer-Sturmey-Archer-13T-Sprocket--1-8-Flat--HSL854-19322.htm
****Edit: Just because it will fit, doesn't mean it'll work. The 13 tooth is small and may cause chain interference from what it looks like to me.
SJS Cycles UK and Harris Cyclery USA have and excellent selection of sturmey and internal gear sprockets.
12p3phPMDC
Next
Users browsing this forum: Kai, libertyhaze, stEVe and 7 guests
