Jozzer wrote:Your already the guy to go to for the guys that other guys go to..
methods wrote:I can do a little happy dance when they get here and you go to get yours but they are all sold out![]()
methods wrote:I ordered mine first![]()
Only problem is that I ordered 8 6S 5000mah packs and that put me over the limit for EMS Express so I had to ship via the slow boat.
I HATE THE SLOW BOAT !![]()
-methods
-methods
methods wrote:sure it will work.. but it will take forever![]()
I am working on the dual supply monster
24S 100.8V 20Ah pack -> 30A 1.5C 3KW charger.
Will require the special 40A outlets I installed when I built my house![]()
methods wrote:The beauty of lipo is that you can charge it with anything so long as it is equal to or less than HVC.
Please be very careful to make sure that the open circuit (floating) voltage of that charger is <=21V.
If so, sure it will work.. but it will take forever![]()
Hyena wrote:Why 5 x 4S ? Assuming you want to run them all in series for a high speed short range 20S 5ah pack, 4x 5S would be slightly easier to wire up for parallel charging and balancing. If you can afford to drop a few volts easier still would be to run 3 x 6S packs as 18S
If your power supply is adjustable you could use it.
For charging 4S you'll want it set to 16.8v, 5S 21v and 6S 25.2v
You'll need a balancer too, I use this one and I think methods does too.
You can charge through that balancer up to 10 amps but if you're current charger puts out double that you'll have to just connect it to the balance taps of the batteries.
Users browsing this forum: Bing [Bot], cal3thousand, sabongi and 7 guests
