No warranty / liability by the use of the Xtra-, Terminator- and Predator-motors on devices for the transportation of persons.
After getting a first hand look at a 72v Blade in action, I've decided my bike needs more power.
Malcolm wrote:Nice! You'll need to maintain a speed of 100 kph just to keep that little powerhouse cool!
Miles wrote:Over 1000eu - the Predator 30 is 875eu.............
I wonder how much you could force air cool it?
Lowell wrote:A small motor like this could package nicely the same way as the various 600W kits. With suitably strong mounts of course.
http://www.electric-bikes.com/currie10.htm#currie12
Miles wrote:Lowell wrote:A small motor like this could package nicely the same way as the various 600W kits. With suitably strong mounts of course.
Not sure I'd call hanging off the side of the bike nice packaging
Lowell wrote:Having the motor unsprung would be nice, but adds complexity. If you look at the Blade, they use a belt drive to a jack shaft, and then chain drive off that so the rear suspension will pivot properly.
Lowell wrote:With a target wheel RPM of 1000-1100 (20-21" tire OD) 9:72 go kart sprockets will work nicely with that motor.
I still need to keep a functioning bottom bracket and pedals as well.
Lowell wrote:To go 60mph up a 10% grade with my bike would take around 7500W to the rear wheel or about 800-900W waste heat. In reality 45mph would be plenty up that hill, so more like 4500W at the tire.
patrick_mahoney wrote:Ok, it's a silly idea.
safe wrote:6000 * 11 / 114 = 579 rpms which is somewhere near 45 mph or so. (which means you could use an even larger front sprocket or have three or four gears to experiment with... 11, 12, 13, 14)
Users browsing this forum: No registered users and 15 guests
