The Grinhill Mk2 RC-motor drive
Re: The Grinhill Mk2 RC-motor drive
Postby BenMoore » Sat Aug 08, 2009 4:31 am
Go Grinhill!
Your original RC motor drive had already inspired me to start procuring parts for a 'Moore Mk I'. I love the ultra-light, inexpensive and innovation of your system designs :D
Its great to see continuing development here.
I hope to join in with a build thread of my own efforts and collected ideas from all the good Forum folk soon as I think the RC motor route has a lot to offer.
Coming from the virtual silence of my Crystalyte hub motor to fully opening the throttle of my 'cute' new RC motor at 48V on the bench :shock:, my main design concern is now noise reduction. I'm looking at reconfiguring the motor's wiring from Delta to Wye to lower its kV and increase torque so that lower motor speeds can be used. Also, with access to a lathe the bell (and axle) could be rebuilt/replaced so as to create a mini hub style motor - the rotor becoming supported on both sides. If its worth the effort, I expect it whould minimise the screeching resonances of the original bell rotor and perhaps achieve better conductive cooling through a thicker and stationary axle as well... anyone game to try?!
BTW, speaking of noise, don't you get sick of the same, bolted-on album on your integrated stereo? :lol:
eBike 1: Crystalyte 408/4012 in 20" rear, 72V LiPo, 20A controller on Trek Y dual suspension
eBike 2: Avanti Electra (axial flux motor) overvolted - very noisy!
eBike 3: Bafang BPM, Modded ecrazyman controller 50A, LiFePO4 batt
eBike 4: 2kW RC motor with wye/delta switching (Turnigy SK6374-170,12S LiPo) - under construction...
BenMoore
Postby liveforphysics » Sat Aug 08, 2009 5:48 am
BenMoore wrote:BTW, speaking of noise, don't you get sick of the same, bolted-on album on your integrated stereo? :lol:
LOL! :P :D :)
I also love your work Grinhill. Your designs are very clever in the simplicity of them. I also respect that you have the ability to make rational choices about how much power is enough, and escape the perpetual need to push everything to the point of breaking in the endless quest for more power.
Very clever stuff! I love it all!
Keep up the good work!
Best Wishes,
-Luke
liveforphysics
Postby recumpence » Sat Aug 08, 2009 6:33 am
LOL! :P :D :)
Best Wishes,
-Luke
Luke, say it aint so! You cannot give in to this. More power I tell you! :mrgreen:
I wholeheartedly agree. I still love my recumbent. That bike rarely pulls huge current. I love seeing how mauch range I can pull from each charge. I am also building two trikes right now. One is crazy powerful, and the other is much more modest. Moderate power is sooooo much easier to build and contend with. I bet my smaller trike will see more use than the crazy one. But, heck, a good blast of adrenalin is needed every once in a while!
Matt
1% of the world's population can think "Outside the box". The rest are firmly stuck within the box. Where are you?
recumpence
10 GW
10 GW
Location: On Earth right now. That can change at any time, though..........
Postby liveforphysics » Sat Aug 08, 2009 6:42 am
LOL! :P :D :)
Best Wishes,
-Luke
Matt
Don't get me wrong Matt, I personally MUST always push things as hard as possible, which ensures continously breaking everything. But I do often think about how nice life must be for the folks who don't have that need constantly pushing them. :)
liveforphysics
Postby Grinhill » Sat Aug 08, 2009 7:30 pm
liveforphysics wrote:I also respect that you have the ability to make rational choices about how much power is enough, and escape the perpetual need to push everything to the point of breaking in the endless quest for more power.
Thanks, Luke!
I have to admit my last ride was using an 8S pack instead of the 6S. It allowed my uphill speed to increase from about 35 km/h to about 38 km/h. The peak power is still around the 1200W mark. :D
BTW, which controllers are you running on your beast at the moment, Luke? Have you found one that works for you?
1995 Giant Hybrid - Zeta2 with 12V 7AH SLA - removed after one year.
2006 Converted Giant to Geared Brushless Rear Hub with 24V 17AH SLA - bike stolen 2007.
2008 Hardtail MTB Disc Brake - lightweight RC/LiPo system.
Grinhill's Medium-power RC-Motor Hardtail build
Grinhill III - "Supercommuter" featuring Recumpence RC drive
Grinhill
Postby Grinhill » Sun Aug 09, 2009 1:37 am
Here's my most recent refinement, a wiring tidy-up. It was prompted by the need to increase battery capacity, so I will be going to two water bottles in parallel. :D
So if I need to use both bottle cage mounts, the power switch and other bits will need to move. The top tube would be ideal, except for the gear cables being in the way. Maybe a long channel for the wiring to sit in, hanging from the tube. What can I find in the garage...
rc_proj 079s.jpg (110.24 KiB) Viewed 1272 times
It's a diffuser off an old fluoro lamp. The size and shape seems ideal for the job. Stuff can sit in it and be kept clear of the moving cables. So I relocated the switch box, and added a bit of paint to match the bike.
rc_proj 075s.jpg (71.8 KiB) Viewed 1269 times
rc_proj 076s.jpg (47.86 KiB) Viewed 1273 times
rc_proj 077s.jpg (60.14 KiB) Viewed 1271 times
Now with everything reinstalled, a few dabs of hot-melt glue to keep it in place, a few cable ties, it looks pretty tidy.
rc_proj 078s.jpg (58.54 KiB) Viewed 1284 times
Grinhill
Postby Grinhill » Sun Aug 16, 2009 7:17 pm
Here's some data since I've been using the 8S2P battery pack: (I did post something about this a few weeks back but have since found that I wasn't running at full speed!)
New top speed on the flat (unassisted):
55 km/h (35 mph) at 1300W power cunsumption :D
New top speed up 10% grade (with assist FWIW):
45 km/h (28 mph) at 2000W power consumption :D
For my return commute (12 km) I use around 6Ah of the 10Ah.
I have had some slight movement of the sliding plate mounting arrangement after hitting potholes. Although only a few mm, this has reduced the belt tension sufficiently to allow some belt jumping at high power. I will have to add a couple more bolts to lock it in place.
Grinhill
Postby grwsaltspring » Sun Aug 16, 2009 10:35 pm
I'm following your build with great interest as I'm curious as to how the "simple" build will turn out compared to some of the more exotic ones here.
Cheers Greg
grwsaltspring
Postby Grinhill » Tue Aug 18, 2009 4:57 am
I locked the plates together with two additional screws, just a couple of the self-drilling sort.
Still had belt slippage at the 2000W mark, it's just some very quick skipping, not continuous.
Maybe I'm just reaching the power limit in this configuration. The long belt and small motor pulley are less than ideal for this type of belt. You can see the belt slapping around a bit at high speed.
Grinhill
Postby grwsaltspring » Tue Aug 18, 2009 9:21 am
Any idea on the direction you will take this next in your ongoing refinement?
Greg
grwsaltspring
Postby swbluto » Tue Aug 18, 2009 9:36 am
Grinhill wrote:I locked the plates together with two additional screws, just a couple of the self-drilling sort.
I had continuous belt slipping at 2 kW from a start and ended up busting the belt. I'm thinking that somewhere around 1.5-2kw is the limit for 5mm 15mm HTD belts in conventional direct drive configurations, but I think that my axle oscillations probably contributed to the slipping. It seems that also matt had belt slipping at 3kW, so it's definitely somewhere in the 1.5kW - 3 kW region. I've heard it's actually a torque limit and a belt can transmit more power than this, but it has to be spinning at a high RPM to ensure that it stays below the torque limit (As power = torque * (RPM, or technically, angular velocity)).
swbluto
10 GW
10 GW
Postby Miles » Tue Aug 18, 2009 9:42 am
Ratcheting point (for a given belt) depends on static tension and torque/teeth engagement on the driver pulley.....
Miles
Postby swbluto » Tue Aug 18, 2009 9:45 am
Miles wrote:Ratcheting point (for a given belt) depends on static tension and torque/teeth engagement on driver pulley.....
So true, but generalities are sufficient as guidelines as not everyone has the resources readily available to calculate the ratcheting point for their particular belt. And "conventional direct drive" seems to be narrow enough a category to generalize.
(Although, I'm driving an 8 inch wheel and he's driving a 24+" inch wheel. Maybe not.)
swbluto
10 GW
10 GW
Postby Miles » Tue Aug 18, 2009 9:50 am
The point is though, that it's essential to take into account the number of teeth engaged on the driver pulley.....
Miles
Postby swbluto » Tue Aug 18, 2009 9:56 am
Miles wrote:The point is though, that it's essential to take into account the number of teeth engaged on the driver pulley.....
True, but for conventional direct drives on bikes, the amount of engaged teeth doesn't vary by that much, does it?
I assume that people need to maintain a gear ratio of at least 10 for this configuration and that the "chordal angle"(Just taking a guess here) is usually between 45 and 60 degrees. Since the driving pulley isn't likely to be less than 14, and the wheel pulley isn't likely to be more than 200( :shock: Or would it?), it seems that there's probably a variation of upto 2 or 3 out of a mean of 6 engaged teeth.
So, what's the difference between 5 teeth engaged and 8 teeth engaged?
Ok, so it seems it might matter by a little bit. I guess it's a linear relationship and 8 teeth would have 60% more static loading capability than 5 teeth?
swbluto
10 GW
10 GW
Postby swbluto » Tue Aug 18, 2009 10:09 am
Well, I'll go out and say that I was putting in 1.8 kW into the system while probably engaging 5 or 6 teeth. According to my simulator, it appears the motor was probably putting out 10.5 N.M. when it continuously slipped and broke. It seemed like it didn't continuously slip when it was 4 N.M. and less.
(By the way, before people go "Oh, that's a sucky torque", consider this: It has a gear ratio of 4, that's 42 N.M. at the wheel. Also, the wheel is 8" which about three times less that of a 24" wheel, so the torque that would correspond to a similar force on a 24" inch wheel is about 126 N.M. According to ebikes.ca's simulator, that kicks butt, but it seems the 530x are similarly powerful in the 40-50 volts region at 100 amps. My scooter is consuming 60 amps at 33 volts.)
swbluto
10 GW
10 GW
Postby grwsaltspring » Tue Aug 18, 2009 10:12 am
Are the number of teeth on the drive pulley and ones ability to successfully mate this pulley to the RC motor of choice the limiting factors with a build like this one (IE Grinhills build)? Particularly if we are trying to use off the shelf components for the most part.
grwsaltspring
Postby Grinhill » Tue Aug 18, 2009 10:12 pm
A little more info to add to the debate.
My belt is the 9mm wide one, limited by the large pulley, which has about 12mm between flanges. My estimate of the tooth count on the large pulley is 266 (422mm diameter, 1330mm circumference divided by 5).
An unusual feature of the large pulley is that the teeth aren't full profile, they are fairly shallow ridges at 5mm intervals. Then, the pulley is divided into quadrants around the circumference, and only two of the four quadrants have the ridges, the other two are smooth. :?: Apparently the friction from having such a large contact area reduces the need for having all teeth.
I'm not able to determine whether the slipping is occurring on the small pulley or the large one.
Grinhill
Postby Miles » Wed Aug 19, 2009 12:38 am
Grinhill,
It will almost always slip on the small pulley. What size is yours?
The sections with the missing teeth are probably there because of the need to separate the four mould sections radially in order to be able to mould the double flange.
Miles
Postby Grinhill » Wed Aug 19, 2009 6:58 am
20 teeth. (ratio = 13.3).
Grinhill
Postby Miles » Wed Aug 19, 2009 7:27 am
A 20t pulley should be able to handle at least 5Nm torque (around 4kW at 8000 rpm) with a 9mm wide high-torque belt. How are you setting the tension?
The problem is usually the high torque levels you can get when accelerating at low speeds ......
Miles
Postby Grinhill » Mon Aug 24, 2009 9:50 pm
Miles wrote:A 20t pulley should be able to handle at least 5Nm torque (around 4kW at 8000 rpm) with a 9mm wide high-torque belt. How are you setting the tension?
I have the M6 screws slackened a little, push the motor assembly upward with one hand then drill some smaller holes for the locking pins using the other hand. The belt had about 10mm movement with light finger pressure (in the centre of the chord). I repeated this process yesterday and managed to get some more tension, now only about 5mm deflection.
I don't use WOT from low speeds, I always ease the throttle up gently.
I still had a few slips this morning on the steepest hill section, but this time I noticed it coincided with bumps in the road. I think the whole drive unit is flexing ever so slightly, which is releasing the tension enough to let a few teeth slip. Another factor is this was towards the end of the ride, so the belt would be warmer. Does this make a difference?
This morning was a good test - a headwind of around 40 km/h. :shock:
I was burning 2400W to maintain 50 km/h on a level road! (note no slipping during this section).
Grinhill
Postby heathyoung » Mon Aug 24, 2009 11:02 pm
Yep it was crazy windy this morning! Seen your bike a couple of times around Cardiff, I'm usually in the car otherwise I would say hello.
New evil decided - GNG offroad build on Craftworks DHR with 12S4P lipo. Aim - Light, balanced, powerful, able to climb a tree.
Project Vectrix restarted. Status - BMS + Charge control redesign (read faffing with batteries again)
heathyoung
Postby E-Ride » Tue Aug 25, 2009 10:05 am
Grinhill wrote:...
So how much amps? (2400/22.2 ~ 108?)
E-Ride
Postby Grinhill » Tue Aug 25, 2009 6:15 pm
I have the Cycle Analyst set to Watts, and I wouldn't take a hand off the bars to press the button at that speed. :wink:
This is while running on 8S (29.6V), so say 80 A.
I checked the peak amps recorded on the CA, it was 116A. Probably during acceleration.
Heath, you are welcome to PM me if you would like to take a closer look some time.
Grinhill
PreviousNext
Users browsing this forum: Bing [Bot] and 12 guests
