Golden Motor Build 48v and Beyond!
Re: Golden Motor Build 48v and Beyond!
Postby biohazardman » Thu Aug 13, 2009 5:24 am
I gave up on the regen, after toasting my controllers a 36v and a48v, although I really liked it. Regen will give you a 12-18% return depending on riding style and environment. Still it makes more heat and my motor older 36v 500w got plenty hot on my one slow ride through the downtown area. Expect it added a bit to what would have happened at the slow speed anyway. Actually had to stop and let it cool. You have a thermometer so you could always try it and see.
Just pretend that everything is OK maybe no one will notice.
Golden Motor Schwinn first build http://goldenmotor.com/SMF/index.php?topic=279.0
Giant BMC build viewtopic.php?f=6&t=235&start=390
Short ride vids viewtopic.php?f=3&t=20346&start=60#p321703
biohazardman
Postby icecube57 » Thu Aug 13, 2009 4:18 pm
I had something weird happened today. I was going to demo my bike to a friend and let him ride it. I plugged everything up. But the wheel was locked and it was twitching/rocking back and forth pulling like 1500-2000w in the process. I cycled the controller a few times. Still twitching. I went from 96v charged down to 84. Still twitching. Then it just stopped working. I put it back on my car and did my delivery route and went home. I took the bike off my rack when I got home and rolled it around. It had some serious cogging going on. Im like sheit. How in the hell did the fets short. Sure enough I took the controller apart and the two fets(on the left end if you are looking at the fet) were shorted out according to my volt meter. Also Im like wtf is all this condensation doing in the case. Im thinking damn was it that humid and cool in my garage for condensation to form. Or did water get in the controller when I transported my bike on my car briefly when it rained. No way its 80 degrees in there. Then I look and saw that the Capacitor that in the middle of the controller along the fets was buldged the top. Then im like how and why did that cap vent. I had some 4310s that were still good from my other dead controller. I desoldered the bad ones and and desoldered good ones and did a transplant. I desoldered the cap. It was a 100v 470uf cap. I replaced it with a 100v 1000uf cap. I tested it and it works fine. I went for a ride it was working fine then i had sudden loss of power. Not completely but more like a speed reduction but when you rengage the throttle it would jerk fast slow fast slow erratically Im like furk.. I turned the controller off and headed home. I made it home an turned the controller back on. I engaged the throttle and it sounded like the phase or hall wires were out of order but i knew they were in the right order. I cut it off unplugged the batts for a few min and reassembled and tried it again and it worked fine driving the motor up to 4000w. I rode a round a few miles putting it through its worse case senario paces. Im assuming that when the caps vented the electrolyte collected on the pcb (looks like sweat or condensation on a glass) and is shorting things out? I would also assume i need to disassemble the controller again and clean the controller pcb with 100% rubbing alcohol and everything should ok right?
icecube57
1 GW
1 GW
Postby icecube57 » Sun Aug 23, 2009 8:32 pm
Just posting some ride results from my Exercise/Joyride
Starting voltage 97.6
Ending Voltage (resting) 79.2)
Max speed 46.2mph
Avg speed 24.7mph
43 Minute Ride Time
Max Amps 49.92
Min voltage 71.4v ???
AH Consumed 5.335AH
17.95 miles Total
25Wh/m
449.59 Total WH Consumed
icecube57
1 GW
1 GW
Postby Hyena » Sun Aug 23, 2009 10:41 pm
How did you do that amount of miles at that speed and only use 5ah ??
My GM eats up double that at a slower speed.
www.HyenaElectricBikes.com
Aussie high powered and custom e-bike kits
My build and HD video thread__. My youtube channel
Hyena
10 GW
10 GW
Postby icecube57 » Sun Aug 23, 2009 10:49 pm
I have a magical throttle. But really I bumped up my SL speed limit to 25mph so i can cruise at 25mph @ WOT and pedal along with the motor to keep the watts down to around 2-300w. The trail was like freaking level. You could have rolled a ball and it probably never would have stopped rolling.
But youd be surprise what you can do by feathering the throttle. I wish i had a CA visor so dont have to look down so much. If you look at the videos i have on youtube you will see that the trail I ride on is like paved and level all the way through barely a 1% grade. Agressive riding will eat 5AH in 8-12 miles. And going 40mph would go through the whole pack like it was nothing. I have killed a pack in 15 minutes and gone absolutely no where fast. I just thought i should post my results because it was a pretty impressive ride.
Doing 20mph I can do 4 miles per AH so its no to unrealistic. Remember higher voltages also means you have more WH at your disposal. So at 48v=48wh per AH... I was barely getting 3 miles per ah that is like 16wh a mile. 80-90v= 80-90wh per AH depending how agressive Im riding. Im using almost double that at 25-30wh a mile. But with throtle regulation I can vary that all the way down to 10 or 15wh doing 20-25mph pedaling along.
icecube57
1 GW
1 GW
Postby Russell » Sun Aug 23, 2009 10:57 pm
Hyena wrote:How did you do that amount of miles at that speed and only use 5ah ??
Are you running the same voltage as he is? If not then you can't compare Amp-hours but instead should look at Watt-hours. I use less Ah since I went to 48V compared to 36V but I ride a little faster and consume a bit more Wh/mi.
-R
Jeep Comanche 29er w/Bafang QSWXH, 41 lbs + 9 to 14 lb rear trunk bag w/tools+battery, 29 mph w/12S LiPo.
Mongoose Hatchet dual suspension w/Bafang BPM
Past Bikes: Raleigh 700C, Kona Smoke 2-9
Russell
Re: Icecube57 New 60v-72v Build 2.0
Postby docnjoj » Mon Aug 24, 2009 12:49 pm
icecube57 wrote:Also if this peanut butter gear thing is making me doubt the decision to use bafang in this build. How hard is it to replace one gear in the bafang. Ive taken my old BD36 apart dozens of times. Is it a simple... pop off one cover and replace one gear or is full disassembly required. I might possibly just do a 48v 20AH lipo battery and consider it the peak for a stock setup. It should do 25mph easy
I considiering th $98 dollar GM special as an alternative. It will certainly be better than a BL36 for the same buiid.
To go back a ways replacing gears in a Bafang is quite easy. The side covers come off and the carrier can easily get the gears changed (circlips). I have 1 steel and 2 nylon in my old one with very little noise. My new one is all nylon but I have replacements ready if necessary. Easy peasy!
otherDoc
E-bike stable at our house
Bike-e electric front brushed C/L
Steintrike Mad Max full suspension trike rear 9C
Sun USX delta trike 9C front wheel sort of front suspension
Frame of homebuilt trike in shed with Bafang still on it
New Agniusm/A123 on the Steini and old 10ah Ping paralleled with 12 ah Fatpacks on USX
My wife and I ride the trikes
docnjoj
10 GW
10 GW
Postby icecube57 » Mon Aug 24, 2009 4:07 pm
Posting some updated bike pictures.
icecube57
1 GW
1 GW
Ride Video @ 96v
Postby icecube57 » Wed Aug 26, 2009 9:28 pm
I have two videos. They have totally been demolished by youtube converting. But should be in HQ in a while. It has some shots of me accelerating a few times. A little neighborhood cruising. Demostrating when and where I might use my speed switches. At the end on the second video is an end of ride result of my CA and Watts Up. I left the original audio in. There is a bit if wind noise. But you can still hear the motor and how it changes its tone under various loads. The camera is a bit shaky not to much. I have a rigid fork. It flexes but it doesnt dampen everything. Especially at 40mph.
icecube57
1 GW
1 GW
Postby icecube57 » Fri Aug 28, 2009 7:47 pm
Controller forgot to wipe.
PIC_0096 (Large).jpg (105.33 KiB) Viewed 857 times
icecube57
1 GW
1 GW
Postby icecube57 » Thu Sep 03, 2009 8:57 pm
I just bought some more candy.
I just bough 6 more Bosch Fat packs. This will be a total of 12 fat packs. They will be used to create an 74v 13.2AH pack.
I also ordered a new rack and panniers to hold my cache of batteries. I had to change racks because I didnt want the center of gravity to be super high. I also figured panniers would be the perfect solution. My seatpost rack woud have allowed the panniers to sway hitting the tire. So Im switching to a rear rack that installs on the QR skewers and frame. Supposedly able to hold 110lbs.
Rack for full suspension bikes.
http://www.amazon.com/Axiom-Odyssee-Ful ... 435&sr=8-1
Pannier Bags. I should be able to fit 6 on each side with room to spar.
http://www.amazon.com/Axiom-27-85-Litre ... 497&sr=1-3
I also bought 2 3A 10s 26v chargers. This will give me 3 chargers total I will be charging at close to 9A charging current. I should be able to recharge a 26.4AH pack in about 3-4 hours.
Im also put in a request to ping to make me a 12.8v 15AH booster pack. With a BMS that should be able to peak at 45A. I think hes selling it for 140.
This will give me a total pack voltage of 86.8v nominal with 1140 wh. This will give me a pedaling range of 95 miles @ 20mph @ 12wh a mile. 57 miles no pedaling @ 20mph @ 20wh a mile. 32 miles at 30mph @ 35wh a mile.
A 19mile range WOT using 60wh a mile @ 40+. If the motor could take the heat... which it cant... lol
icecube57
1 GW
1 GW
Postby docnjoj » Thu Sep 03, 2009 9:46 pm
IC57, you are crazy! But I like it! That's a lot of Fatpacks!
otherDoc
docnjoj
10 GW
10 GW
My Panniers Came In Today!
Postby icecube57 » Wed Sep 09, 2009 9:03 pm
I just got my panniers in today. I must say Im impressed. They have lots of room. You could easily fit 12-15 bosch packs in one pannier. I think if there was a metal back plate and metal support shelf for the buttom I could pull it off. It easily holds 6 packs unsupported without any deformation in the bag. Ive included some pictures.
http://www.axiomgear.com/products/gear/ ... s/seymour/
Packs Loaded Example
STA70006 (Medium).JPG (80.23 KiB) Viewed 1101 times
STA70007 (Medium).JPG (81.64 KiB) Viewed 1100 times
Draw String Top
STA70008 (Medium).JPG (78.95 KiB) Viewed 1096 times
Loaded Profile Front 16lbs Of Battery Inside
STA70009 (Medium).JPG (99.47 KiB) Viewed 1099 times
Loaded Profile Side 16lbs Of Battery Inside
STA70011 (Medium).JPG (76.39 KiB) Viewed 1097 times
Back Of Pannier. Hooks And Bungie Strap To Attack To Rack.
STA70013 (Medium).JPG (125.12 KiB) Viewed 1097 times
icecube57
1 GW
1 GW
Postby biohazardman » Thu Sep 10, 2009 3:36 am
Carefull with the way you put the batts in the panniers and how you mount them to the bike. I found the stock mounting system on my bags to be weak. The top brackets had a nasty habit of bending and in a very short time the bags would bounce and try to fall off. They weighed in at eight pounds. I ended up securing a heavy ABS battery backplate to the rack and the problem ended but they were not as easily removed after that.
Also think about what happens if you drop the bike. Your battery container needs to be able to handle the impact or you may trash some spendy batts.
viewtopic.php?f=3&t=12847&p=191134#p191134
Scroll down to the pics
biohazardman
V1 Fatpack... Meet V2.
Postby icecube57 » Thu Sep 10, 2009 7:17 pm
I got three of my fatpacks in today. The other three will be in tommorrow. Then I will have 12 fat packs. I was debating if i should make them like my first pack and remove all the endcaps and everything... mod the plastic so they stack closer together. Solder bus bars and insulate the sides and wrap them in Alabama chrome but I decided not to. I just took the bms off..drilled a hole in the end of the Bosch Pack covers so the wire could come out. Used the crappy insulated spade connectors to connect them together. They stack nicely. I ran a beat of Liquid Nails along the center of the packs to bond them together and stacked them neatly on top of each other. Its not that much taller than the other pack. Less than an inch. I really wish i would have done this the first go round.
Side Shot
STA70015 (Medium).JPG (63.97 KiB) Viewed 1048 times
SV1 Pack Left V2 Pack Right
STA70017 (Medium).JPG (71.72 KiB) Viewed 1050 times
icecube57
1 GW
1 GW
Postby docnjoj » Thu Sep 10, 2009 9:11 pm
I really like the drilled hole idea, IC57! Another 2-3 months and I will be pretty sure these Fatpacks are gonna be OK! then I may follow in your footsteps and get 2-4 more to run 72 volts @6-8 Ah! Bye Bye Bafang!
otherdoc
docnjoj
10 GW
10 GW
Postby icecube57 » Sat Sep 12, 2009 7:55 am
My 3 other Bosch Packs came in. My rack came in. My chargers came in.
My charger ganged together charge at 8.9A at 36v. Then it ramps down at the end of charge. Most quick rides should charge in less than an hour. Full discharge will take 3.5hrs.
I assembled my Bosch packs. The glue is setting. It takes a week to fully set but im going to put a round of tape on them just so i can get a test ride at 74v nominal @ 13.2AH. All 4 packs are ready to go. Ping booster pack will be shipped out Monday. I just have to make a wiring harnsess to connect the batts to the controller and charger.
I like how the rack has my panniers very low and to the back. I cant wait to see how it handles. No more trying to hike my leg over the back of the bike trying to clear my trunk bag on my seatpost rack.
Rack and Panniers.
PIC_0107 (Medium).jpg (52.28 KiB) Viewed 1011 times
Check Out My Rack!
PIC_0109 (Medium).jpg (37.84 KiB) Viewed 1011 times
Nice Rack!
PIC_0111 (Medium).jpg (57.8 KiB) Viewed 1011 times
icecube57
1 GW
1 GW
Doc Inspired GM Air Cooling.
Postby icecube57 » Tue Sep 15, 2009 12:12 am
Here is my DOX inspired Air Cooling mod for GM. I would also like to thank Karma for his picture post. I dont have any results yet on how this performs. From test spins in the garage it doesnt cool if the motor temp is 10-20F above ambient but anything above that it either maintains the temp or slowly creep up. I think the mod delays the inevitable overheating but doesnt solve it. I will pound on it tommorrow and then do some light low amp cruising runs to see how it cools the motor during coasting and cruising. If all I have to do is back off the throttle for 2-3 minutes and let the air flow do its job and drop the temp by 10-15 5degrees.. I will be happy.
Ping has shipped my booster pack so I should get it by the end of the week.
Tommorrow will be the test voyage on the new Bosch Packs, Rack, and Panniers.. I got 975wh wh to burn at 74v & 13.2AH. I think i will do a 40-50 mile trip on the paved trail at 20mph just to see if its solid. I may exercise the packs and let er rip. Once it feel good about the build I will do one more test run with the booster pack... Then a extreme range test. Once all of that looks good its then time to take this to the streets to see how it handles in traffic. I should have a solid 88v under load with the new packs and booster pack. Acceleration is good. I can quickly get into the mid to high 30s at 74v so the extra 12v should seal the deal.
PIC_0112 (Medium).jpg (50.28 KiB) Viewed 992 times
PIC_0113 (Medium).jpg (54.75 KiB) Viewed 993 times
PIC_0114 (Medium).jpg (57.71 KiB) Viewed 991 times
icecube57
1 GW
1 GW
Postby icecube57 » Tue Sep 15, 2009 1:45 pm
I honestly though that the drilled side cover mod was BS. I thought i may be a placebo affect. To see it in action blew my mind.
The ambient temp was 75.
When the motor is working it pulls the air in and cools the motor. The motor ran 10-15 degrees cooler. When I stop the motor temp rose 10-15 degrees thus showing me the actual static motor temp. Once i started back doing low cruising again the temp dropped 10-15 degrees in minutes. The good thing about this air cooling is i was giving this motor hell. I was pulling so much constant current I made one of my cheap Radio Shack molex connectors melt. The static motor temp never got above 135F when I stopped. Normally before the mod it would have been super hot and toasty on the side covers and my temp probe would read high. It was luke warm at best. I would say its a success. The motor can sustain 3500w for atleast 5 minutes and not reach anywhere near critical temp.
icecube57
1 GW
1 GW
Postby icecube57 » Tue Sep 15, 2009 2:03 pm
So I did a performance ride today... 22miles before empty. It was raining not fun.
My CA said I did 38 wh/mi
I consumed 13.17AH.
I peaked at 51A.
My lowest voltage was 58v. The lvc of my controller did kick in at that point. Atleast its good to know the regen mod and my lvc selection in the parameter program was dead on.
I was able to hit 42 mph without being tucked in and was able to hold it for about 2 miles before i backed off. After the surface charge is gone the battery the battery has a solid flat discharge curve. No real performance hit until it drops below 66v. The packs are no where near being stressed. If there are 3 packs in my 37v sub pack and the total pack sees 21-22A under load that means each pack is seeing 7.5A which is half of what they can do constant. Doc mentioned that they can do 15A continuous without heat issues. I had my watts up meter monitoring a 37v 6.6AH pack. It gave me these results.
237wh consumed 948wh total out of all of the 4 sub packs
6.558AH consumed. I guess the low C discharge is allowing for deeper discharge
802 peak watts This would make 3200w for all 4 packs.
29.25v lowest voltage
21.89A peak
You like I like
icecube57
1 GW
1 GW
Postby icecube57 » Sat Sep 19, 2009 7:38 pm
I got my 12.8v ping pack today. It was cute. it was 14.4v off the charger.... NICE!!!!! Paired with two Bosch packs in series i got 98.4v.Its a Signalab 4ch BMS. The booster pack looks cute. It fits in my trunk back with my Two Ductaped Bosch 3 packs. I cant give a total pack nominal voltage under load because I wasnt running all 12 packs. The ping BMS works perfect it was able to handle 40-45A. I wired the provided diode across the positive and bms negative. I pounded around the block a few times and goosed the throttle a little to much... I got the motor warm enough to where the air cooling didnt mean tihs! The streets were wet. I was having problems getting the wheel to stick.
I had a mishap yesterday. I put my bike on my bike rack and the rack fell off the car as i was backing out. I have a pringles rear wheel. I bought another wheel today with black DW nylon rim with those weird looking flat smokes. It rides so quiet and smooth. Everything seems solid. I gotta wait for the weather to clear up to really see how it performs.
I Also got my helmet gloves and goggles today. The helmet is snug but I feel safe. The gloves are ok. Theyll help in our mild winter climate in the south. The Goggles were nice!. As long as they dont fog up. They prob will. I tend to sweat easily.
Is the ping pack balanced when all the lights come on ...on the bms?
PIC_0124 (Medium).jpg (38.84 KiB) Viewed 872 times
PIC_0126 (Medium).jpg (49.79 KiB) Viewed 868 times
PIC_0127 (Medium).jpg (52.05 KiB) Viewed 868 times
icecube57
1 GW
1 GW
Postby ambroseliao » Sat Sep 19, 2009 11:17 pm
Hi icecube57,
It sounds like your build is really coming together. May I ask how your Axiom rack and panniers are working out? I am thinking of getting this set since it's reasonably priced. Any rattles or looseness when you corner or go over bumps?
Thanks,
Ambrose
http://www.ebikes.ca/ for the best in ebike knowledge and equipment.
Tidalforce S-750, TidalForce iO Cruiser, 2x TidalForce M-750. Crystalyte HS3540 sensorless, 72V 45A Crystalyte SL controller, ebikes.ca DrainBrain & Cycle Analyst meters. GoPro HD Hero2 camera. A123 20Ah batteries. 88.2V 10Ah LiPO. My blog: http://ebikerider.blogspot.com
Remember LiFEPo4 HVC is 3.65V and LVC is 2.7V
ambroseliao
Postby icecube57 » Sun Sep 20, 2009 9:26 am
The rack is solid. Due to the weird geometry of my rear sway arm the rack has a slight forward lean. This can cause problems when using the panniers.they tend to want to jump off the rack because in order for them to really work the rack has to be level. What i did was drill a hole in the metal hooks and run a zip tie through the hook around the rack railing. Now its solid. Its not going anywhere. This also means they are semi permenantly attached to the bike. No noises. It holds all my batteries fine about 30lbs worth. If i grab the rack i could pick up the bike fully loaded and it doesnt budge. The panniers are roomy too. A little too deep in my opinion.
icecube57
1 GW
1 GW
Postby icecube57 » Thu Sep 24, 2009 2:08 am
Tuesday I took the Golden Motor Rig out for a real world test at 98.4v off the charger. I was on side residential streets doing some 20mph cruising. Crusing the Speed limit on main roads connecting to other side street subdivision. I sped up to the 35-40 speed limit when cars were behind me. I was able to hold my own. I didnt have any passers... it was mostly residential with stop signs and such. I think they were more surprised that angry and filled with road rage. I managed to clip 48mph tucked in on a long long stetch. My old buddy heat came back to plauge me seriously. The area didnt have such friendly terrain (rolling hills and stop signs) so after pounding on it i had to cruise slowly for like 10-15 min to get the temps to go down and I pounded on it some more.
My CA was acting nutty so I had to cut the ride short but I did about 10 miles on 8.5 out of 13.2AH (based on what I put back into the pack) and had an ending voltage of 86v.
Ill go down town next time to see how it reacts there. I had my full helmet gear and goggles on. If felt very safe and well prepared. The full face Motorcross helmet was nice. No blind spots or anything. Helmet still snug... Gotta break it in some more.
Im on my 3rd cycle on my ping pack. Charges quickly.. Balances quickly. My deepest discharge was 8 out of 15 AH. The first two were about 5AH. Im raping her slowly and gently... NOT!!! 40-45A solid without any complaints. Well made pack. Tommorrow I want to do a distance test. Or atleast discharge to 10AH.
I need some advise Im noticing phase wire heating.Plastic insulation and some connector deformation. Since I cant replace the stock wires in the axel without making a larger hole. How much would it help if I ran 10G all the way to the motor axel.. terminate it with some andersons and leave the stock wires intact at the axel. Would this reduce heating on the wires or superheat the wires that are inside the axel.
icecube57
1 GW
1 GW
Postby biohazardman » Thu Sep 24, 2009 3:36 am
Yes running most of the way with heavier wire will help. Still keep an eye on it. The wires are not made for high amps and you may have to upgrade the motor wire if you choose to continue riding as you are.
biohazardman
PreviousNext
Users browsing this forum: No registered users and 8 guests
