Nut Torque Axle Spinout Torque
hand tight 38.7 N-m
30 N-m 78.3 N-m
60 N-m 83.9 N-m
90 N-m 96.6 N-m
hand tight 49.5 N-m
60 N-m 79.9 N-m
justin_le wrote:The 12mm axle was able to smear the metal around in the 1/8" torque plate without too much difficulty.
swbluto wrote:Thanks for the tests and the equivalent data. Do you have any information on what the axle-spinout torque might be on a rear axle with aluminum dropouts? Even a minimum bound as suggested by extreme cases would be informative.
dogman wrote:I've got a few forks in the junkyard, from roadmaster junk, to decent forks, but ones I'd consider too lightly constructed to use. Mostly fairly old bikes, maybe 10 years old or so. None identical though. I'll line em up and snap a pic so you can see what I have.
Right away I see one thing about your excellent tests. Torque arms are no substitute for tight nuts and perfectly fitting washers. Dang those QR hubs, and the forks designed for them. In the long run, the motors will need to be made with a bigger shoulder on the inside of the dropout. That would eliminate one source of the axle spreading forces. Heinzmann got it right with thier motors, they have a huge shoulder that allows an integrated tourque arm. This allows a regular size round axle, and no way to spinout, no way to lever open the dropouts. That kind of design is what front hubs need.
johnb wrote:justin_le wrote:The 12mm axle was able to smear the metal around in the 1/8" torque plate without too much difficulty.
Justin, your post was just a few hours late for me. This is exactly what happened to my torque plate yesterday (one I got from you).
I am still puzzled at how the torque plate should fail so "easily". Perhaps it could be made from harder metal. Perhaps a spanner (tool steel) would resist more torque.
317537 wrote:
I noticed a little time ago that the torque arms that the have the converter on them turning the rotation into push pull could push the wheel out of the dropout, and could be very bad when a wheel nut comes lose, where as the plain jane torque arms look to be a better option.
Now is sudden braking while the motor is still engaged doing some serious damage too? What is the differnece between acceleration, regen braking, and braking with the motor engaged.
dogman wrote:That crankshaft effect could be eliminated by having a steel plate welded to the fork, and bolting the arm to it in two places.
For sure for sure here. The idea with the torque arm design was that second arm with the hose clamp goes behind on the rear of the fork, so that the axle torque is converted into a thrust that pushes the wheel further into the dropouts. This is a pretty important point that I never got around to emphasizing. Some people installed with the torque arm facing forwards, and in this case the reaction torque on the axle would tend to pull the wheel out of the dropouts.
The actual pulling force in any case is a less than the frictional forces holding the axle in place, but with loose nuts it could be a problem. Say a powerful 80 N-m torque, and assuming a distance between the torque plate axle slot and pivoting point of 2.5cm, then that can translate into some 700 pounds prying the axle out or in to the dropout.
I should make a diagram here to explain it so people can see more clearly what we're talking about. Tomorrow maybe.Now is sudden braking while the motor is still engaged doing some serious damage too? What is the differnece between acceleration, regen braking, and braking with the motor engaged.
With regen it is a totally different game. The assumption in the design is that there is only a significant drive torque on the axle, not a braking torque. The subject of regen torque arms is something that I'll address in a separate thread here sometime next week.
-Justin
Users browsing this forum: Bill Nye the science guy, chrashing, dnmun, launchpad, mark5, tony67, zappy and 15 guests
