liteCycles wrote:So would we be looking at double the power out of this motor? Has this ever been done and what are the odds it could run at a continuous load of around 6000 watts?![]()
I'm pretty green on this, but does that controller have a electrical rpm limit that could come into play? - http://endless-sphere.com/forums/viewto ... ming+speed
Burtie wrote:While waiting for Astro Bob to weave his magic on our group buy, I felt the need to make some stuff
Burtie.
Burtie wrote:
Jozzer wrote:Your already the guy to go to for the guys that other guys go to..
gwhy! wrote:There is no reason that this method could not be used for out runners also but mounted to the front of the motor but will also need a different number of mags in the rotor.
Burtie wrote:gwhy! wrote:There is no reason that this method could not be used for out runners also but mounted to the front of the motor but will also need a different number of mags in the rotor.
I think positioning the sensors in a small arc around the edge of the can (as you have already done) would be an easier solution for the HXT style outrunners.
Given that these outrunners are usually 14 pole motors? the sensor spacing could be as little as 120/7 = 17.14 degrees.
I think i will start a new thread to discuss adding sensors to these motors![]()
Burtie
GGoodrum wrote:There's about 1/2" of space at the end of the inside of the rear of the motor. I think your nifty little widget will fit inside there.
Users browsing this forum: salty and 4 guests
