Adding pictures?
This section will contain posting guidelines for the forum along with any other information that is relevant to this forum.
Adding pictures?
Postby deronmoped » Fri Dec 11, 2009 12:59 pm
How do you add pictures to a post?
Thanks, Deron.
deronmoped
Re: Adding pictures?
Postby AussieJester » Fri Dec 11, 2009 1:10 pm
deronmoped wrote:How do you add pictures to a post?
Thanks, Deron.
Quickest way is to upload images to the ES server, to do this use the 'browse'
button below the text editor (the box you tye your message in) this will open up a window viewing files on YOUR pc, navigate to the pic you wont to display, click 'Ok' the name of your pic will appear next to the 'browse' button...simple click the 'add file' button and your done, the pic will show in your post...
KiM
AussieJester
Postby torker » Fri Dec 11, 2009 1:12 pm
The only way I know how is to put them on something like photobucket. Then when you scroll over your pic in PB it gives you an option to copy as a direct link. Then when you are posting you click the Img link above, then put your cursor where the blinking line is between where it says [Img Img] right click and paste. Then you can hit preview instead of submit to see if it worked..
Dave When I die I want to slide in sideways yelling WooHoo what a ride !
Giant Rincon w rear 9C 6*10 10s Lipo 30+ amps
Specialized FSR Comp 9C 6*10 15s x 50A 3300 W :)
torker
Postby torker » Fri Dec 11, 2009 1:19 pm
Aussie you are the man. much simpler than my method.. I might add that the img. has to be less than 512 kb At least that is what it told me when I tried. I use Irfanview to resize mine. It lets you reduce an image by half without losing much quality. You can reduce by half over and over till you end up with avatar size pic if you want..
torker
Postby Lock » Fri Dec 11, 2009 11:19 pm
ES admins will hate me for saying this but of the two approaches - linking to an image hosted elsewhere versus uploading the image itself to ES as msg attachment - when uploaded to ES the image is never "lost" from the thread. Plenty of old threads here that display only broken links `cause the source image was moved or deleted from the other site (sigh)
Tks
Lloc
If you like this message feel free to donate BeerCoins (BTC) to:
1LxAXWmbjY6SeMf8r9HHhSKt6pWyPvWg6L
Toronto Electric Riders Association:
http://www.ebikeriders.com/
Canada, eh?
Lock
10 GW
10 GW
Postby dogman » Sat Dec 12, 2009 8:04 am
Yeah, when I wore out my laptop, I lost all my resized versions of pics, but viola there they are archived at ES. Sweet. When I need to post yet another pic of how I did my battery rack, there it is. I know it's lame, but I just use the windows paint to make my pics small before posting. Shooting small helps too, so I set the camera on 2 megapixel. Then I reduce to 45% and they usually fit.
Using the ES browse method allows easy placement of the pics wherever you want on the thread, and previewing just in case it's the wrong pic, or placed wrong.
Other methods may allow a better look at tiny details, like the writing on controller components, etc. It would be nice if high res pics could be posted right on ES, by permission, for a good reason.
dogman
Postby AussieJester » Sat Dec 12, 2009 8:46 am
I rarely use the ES pic hosting i have my own server access so dont use up the ES storage space, that said, Big Kudos to ES powers that be for allowing image hosting on the site, it must be taking up some space on the servers HDD hence the lower image size allowed i guess? If every member started uping 2-3mb HiDef images it would fill a drive up pretty quick...keep in mind folks, its a feature not alot of forums allow for, it makes it extremely easier for the not so computer literate members of a site able to display their images with ease...Top job ES .....
KiM
AussieJester
Postby torker » Sat Dec 12, 2009 9:23 am
Not so computer literate.. That's me. Thanks for showing this old newbe a new trick ..
torker
Postby Lock » Sat Dec 12, 2009 11:02 am
AussieJester wrote:Top job ES .....
Second that of course... This phpBB forums software is some of the nicest I've seen as a user... My only wish would be that it had a separate images library area as seen with vBulletin3 software, like here:
http://www.boatdesign.net/gallery/
The distinction with vBulletin is that the images are uploaded to the users own pictures area then linked to in messages, but more importantly the images are tagged and tags are searchable... With this phpBB software, images in threads can sorta get "lost" after a while...
tks
Lock
Canada, eh?
Lock
10 GW
10 GW
Postby PeteCress » Thu Jan 21, 2010 4:38 pm
If I wanted to insert a photo called "WhyCyclistsWearBlackShorts.jpg", I would
  • Select the "Upload attachment" tab
  • Once "Filename" is populated with the URL of the .JPG, click "Add the file"
  • Add a reference to the file thusly: [img]WhyCyclistsWearBlackShorts.jpg[/img]
For some weeks I was doing this, but it was not working.
But I just tried it on a test thread and it worked.
So maybe there's some variable that I do not know about.
PeteCresswell
FWD 400w eZee Kit, 2 Dewalt 36v batteries, Surly 1x1 full-rigid frame. Weight as ridden = 37#
PeteCress
Postby AussieJester » Thu Jan 21, 2010 6:50 pm
Try not adding the reference and also hit the "place in line" button
KiM
AussieJester
Postby TylerDurden » Thu Jan 21, 2010 10:58 pm
Want to add pictures? It is better to upload directly to ES, IMO.
Start with great freeware:
Modify, annotate, composite with GIMP.... cross-platform, better than Photo$hop.
Batch convert many images easily with Irfanview... fast, good compression algorithm.
Regarding display in posts:
This image is small enough (<800px wide) to display without an IMG tag. It is an attachment, placed 'inline'.
The next image is bigger than 800px wide, so it needs to be added as an attachment (below) and displayed using the IMG tag, but the IMG tag needs the attachment location (not the original filename):
Code: Select all
[img]http://endless-sphere.com/forums/download/file.php?id=57072[/img]
Also, big and wide images can push out the right side of the table and make visitors scroll to see paragraphs that extend as far as the picture, which can be annoying.
The next image is very large, and should be simply left as an attachment, since display will be much bigger than most screens. Its file size has been reduced in GIMP to the allowable attachment size, (<512kb). The forum's PHPbb software generates the thumbnail (small image) if the filesize is over 250kb. The thumbnail can be clicked for full resolution.
Edit: repaired broken images.
You do not have the required permissions to view the files attached to this post.
Have a Nice Day,
TD
FYI: Adding pictures?
TylerDurden
Postby PeteCress » Fri Jan 22, 2010 10:39 am
TylerDurden wrote:.. but the IMG tag needs the attachment location, not the original filename.)
Code: Select all
[img]http://endless-sphere.com/forums/download/file.php?id=32653[/img]
That's what I was missing: the proper citation of where the image is.
Why I got it to work on that test post escapes me.... but now I know the right way.
Thanks for the clear and complete instructions.
PeteCresswell
PeteCress
Having to scroll posted images is way annoying
Postby v_tach » Tue Mar 23, 2010 5:24 pm
Maybe its been covered but is it new within the last few weeks that we must scroll to view many of the images posted? Is there a way to make the window a little larger at least so reasonably sized images can be viewed without having to scroll, say maybe 800x600?
v_tach
Re: Having to scroll posted images is way annoying
Postby StudEbiker » Tue Mar 23, 2010 5:25 pm
Don't scoll then. If you click on the image it pops up to full size...click again to return to the scroll window.
TidalForce S-750-(build #2) w/9C rear w/EV Components Headway 36v 10ah LiFePo4 pack: http://endless-sphere.com/forums/viewtopic.php?f=6&t=15443&hilit=+headway+rack+pack
Bike-E (Build #3, mostly done)- 400W Kollmorgen mid-drive: http://endless-sphere.com/forums/viewtopic.php?f=28&t=25980#p375646
My Bike E Facebook group: http://www.facebook.com/groups/165756106813440/
"Facts do not cease to exist because they are ignored" - Aldous Huxley
StudEbiker
Postby v_tach » Tue Mar 23, 2010 5:28 pm
Sure enough. I didn't realize the images were click-able. Thank you.
v_tach
Postby StudEbiker » Tue Mar 23, 2010 5:41 pm
No problem, I didn't realize it for awhile either. :)
StudEbiker
Postby nomad85 » Tue May 04, 2010 9:46 am
I use photobucket.com, I can upload all the images at once and the [img] tags are ready to be pasted into a post. set the size to 800 pixels wide so they fit the forum correctly and every picture you upload will be converted automatically. Takes about 5 seconds to post an image(assuming you have already uploaded it and are logged into the photobucket account).
E-bike#2- Trek Xtracycle 45 mph top speed(@74v)
Trek 850/9C 9x7 rear motor / 74v 10Ah Lipo
Mileage since 10/20/08: 9500 miles as of 8/10
nomad85
Postby nomad85 » Tue May 04, 2010 9:51 am
here is how it looks in the post
Code: Select all
[IMG]http://i2.photobucket.com/albums/y2/nomad85/FILE0084.jpg[/IMG]
[IMG]http://i2.photobucket.com/albums/y2/nomad85/FILE0088.jpg[/IMG]
[IMG]http://i2.photobucket.com/albums/y2/nomad85/FILE0089.jpg[/IMG]
[IMG]http://i2.photobucket.com/albums/y2/nomad85/FILE0091.jpg[/IMG]
[IMG]http://i2.photobucket.com/albums/y2/nomad85/FILE0090.jpg[/IMG]
nomad85
Postby madact » Mon Jul 12, 2010 1:13 am
With exceeding annoyance, I find that I can't add an 800x600 picture without having scroll bars or duplication:
- If I add it as an inline attachment, it gets scrollbars.
- If I add it as an attachment with [img] tags, it displays nicely, but I get a duplicate at the bottom of the post.
One workaround would be to post the photos as attachments in a dummy thread somewhere no-one reads, then use [img] tags where I want them, but that's dodgy as...
Anyone have a (proper) way around this?
madact
Postby TylerDurden » Mon Jul 12, 2010 2:52 am
madact wrote:With exceeding annoyance, I find that I can't add an 800x600 picture without having scroll bars or duplication:
Switcitching to "subsilver2" style in the User Control Panel>Board Preferences will eliminate the scrollbars, but it has a different panel layout (better IMO).
Have a Nice Day,
TD
TylerDurden
Posting Pictures
Postby Evoforce » Mon Jul 12, 2010 2:55 am
I can't understand why it is so hard for me to post pictures. :evil: Dogman gave me some direction but I am still epic fail! It is taking me so freeking loooooooooooonnnnggg. Still don't know what I am doing. :oops: Maybe its going to take all night. Maybe all week... Grrrrr. :twisted: I can put a computer together blindfolded but operating software programs are hit and miss. :roll:
"Energy is all consuming and it is never ending. It just changes form as it morphs through time and space... " Evoforce
        Several 5403 motors,  no time to build projects! Phoenix Racer(5303) crystalyte suspension mtn bike LiFepo4 72/20.  (409) crystalyte 48 volt hardtail.  In process... Phoenix Cruiser(5304)  LiFePo4 48/20.  First electric bike a 2009 XB 502-700 style, 36/20 sla scooter bike.  All charged by solar!
Evoforce
Re: Posting Pictures
Postby Evoforce » Mon Jul 12, 2010 3:10 am
Im just not being able to convert the pictures to small enough size to post. Grrrr still trying...
Evoforce
Postby AussieJester » Mon Jul 12, 2010 3:48 am
Download pix resizer its free and rezsizes bulk pics in one hit for you.
http://download.cnet.com/PIXresizer/300 ... 07499.html
For posting simple click the browse button underneath the text editor (where you type your posts) Find the pic on your pc click on it, then click 'open' then click the add file button couldnt be simpler...
KiM
p.s when resizing pics make them no larger than 600x600 and they will display as an image in your post not a link to the image.
AussieJester
Postby AussieJester » Mon Jul 12, 2010 3:55 am
^^^ +1 for subsilver layout..
KiM
AussieJester
Next
Return to Forum Rules and Features
Users browsing this forum: No registered users and 0 guests
cron
