ES DIY Motor Challenge
Re: ES DIY Motor Challenge (was "competition")
Postby Thud » Tue Dec 29, 2009 9:07 am
On Topic:
Laser tach finally arived! (slow boat from China has graphic meaning to me now!)
The Dyno patterns are in proccess & I am looking foward to showing it off. :P
off topic:
Previously, my favorite word to say aloud was: "phenominal" (with the tricky p-h on the front, it just feels good to say it!) but lately I have been evaluating a new word.
The new word on the top of the list is "Dynomometer"
It has an additional sylible & a hard consanent on the end that gives it "phenominal" closure.
Try it, I think you will enjoy it far more than the previous thread drift.... :mrgreen:
Dynomometer, Dynomometer, Dynomometer,
(20 bucks will get a lot of kudos!!! too generous bigmoose, Thank you Very much)
get some......
Thud
Postby bigmoose » Tue Dec 29, 2009 9:19 am
Thanks Thud!
I'll think with you on the dyno if that is OK? What max torque & max RPM are you going to design to?
bigMoose's electronic pieces & parts (GENUINE IRFB4110Pbf's, Nomex 410, AntiCorrosion Grease, Current Sensors) available HERE.
Thanks to Justin ebikes.ca for securing the board then setting us FREE! Tech Tips in the WiKi: http://endless-sphere.com/w
"Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God..." all the best, Dave
bigmoose
Postby Toorbough ULL-Zeveigh » Tue Dec 29, 2009 9:27 am
Dy-No-Mo-MOMETER!!
Last edited by Toorbough ULL-Zeveigh on Thu Dec 31, 2009 1:56 am, edited 1 time in total.
the pessimist engineer sees a glass that’s twice as big as it needs to be.
the optimist engineer sees that the glass has a 100% safety tolerance.
http://what-if.xkcd.com/6/
there is zero consequence to ignoring ayn rand
Postby jscoot » Tue Dec 29, 2009 4:05 pm
Miles wrote:John,
Like I said, larger motors do have an advantage. That's the reason for the 3kg limit. This is the non-hub motor forum :wink:
0.5kg to 3kg should be the range that most people want to work within?
A important aspect of having a 5 kg limit would be to enable people to take advantage of reasonable priced high quality magnets, rotors, stators, and housing with a rather large selection to configure a optimal kv and efficiency for a project that most anyone can get involved with to make a powerful bike motor that will progress to the most economical and easiest way to get there high performance ebike on the road. This type of building block system can be tweaked in many ways including stamped silicon laminations and custom thin multi wire stator windings to reduce end turns and have more copper on the stator. Several rotor and magnet arrangements are available for less than it would cost to just to purchase the magnets on your own. If you are thinking of how to get the most efficient bang for the buck the easiest way with tested reliability, this is defiantly it.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&Item=300381762269&Category=121837&_trkparms=algo%3DLVI%26its%3DI%26otn%3D2
jscoot
Postby amberwolf » Tue Dec 29, 2009 4:26 pm
At 5Kg I could just use my brushed PMDC 4-pole wheelchair motor, which thru the gearbox (an additional 3 or 4 kg) has enough torque to rip itself off my bike, destroy chains, and yank wheels out of dropouts. ;)
3Kg makes that kind of challenge a lot tougher, *and* it gives back 4.4 pounds that one can use for batteries, cargo, or stronger bike frames. :P
FWIW, I could probably lighten up an F&P BLDC motor to fit in 5KG, but I don't know what kind of torque it would have. 3Kg is more interesting--there's no way I could cut that much weight off of it so it means trying to think of something even more efficient.
More efficient means better use of the very limited power we can carry, and can mean having to carry less of it to do the same work. So I'm all for a lower limit to this challenge, as it makes for more usable results. :)
House Fire Updates Thread
DayGlo Avenger, MkII
amberwolf
Postby jscoot » Tue Dec 29, 2009 4:37 pm
liveforphysics wrote:For specific power, even some dirt cheap RC motors are in the 4.6kw/Kg range. This is with a KV of 130, which easily enables the reduction to be accomplished in a single stage reduction. My own bike is an example of this.
Your motor isn't made to direct drive a rear wheel, you must also incur the losses from power transmission to the rear wheel. The drive train loss between a single stage of 4:1 or a single stage of 10:1 is in the fractional percent area. This is way more than compensated by the broad range of >90% efficiency from the RC motor vs the much heavier and lower efficiency alternator motors.
Including the higher RPM spinning losses of a higher kv motor and the difference of a 4 to 1 vrs a 20 to 1 reduction what is your estimate of total losses % wise between the two if the slower higher torque motor has the same efficiency but over a broader range?
jscoot
Postby Thud » Tue Dec 29, 2009 4:53 pm
Hello,
Jscoot, just so we are on the same page here, this is the critera the participants of this DIY motor challange are subordinating to:
Miles wrote:
Over 4Nm continuous torque per kg of motor weight.
Less than 3kg in weight.
No energy input other than that to the motor itself.
Capable of practical use on an electric bike.
go ahead & ask clarifying questions if you are participating.
By my count you have linked that e-Bay seller 3 times now.
It is starting to look like an agenda.
(if I want comercials I will sign off the computer & turn the tellevision on.)
If you feel that stongly about PMG/motor conversions, please start a thread & call it "The Worlds greatest e-bike motor for the money!"(or something to that effect.)
At the very least, a builder/experimentor (DIY guy) would build a nicer looking case for the off the shelf parts to add individualality to them, Then submit them to this thread & see how they compair.
Thank you. Todd
get some......
Thud
Postby jscoot » Tue Dec 29, 2009 4:58 pm
amberwolf wrote:At 5Kg I could just use my brushed PMDC 4-pole wheelchair motor, which thru the gearbox (an additional 3 or 4 kg) has enough torque to rip itself off my bike, destroy chains, and yank wheels out of dropouts. ;)
I suspose so but it also limits a cost effective easy way to get more efficient drive system motors on the road fast! OK I'm done here. Good luck to the few that will be involved in this project.
jscoot
Postby amberwolf » Tue Dec 29, 2009 5:15 pm
jscoot wrote: I suspose so but it also limits a cost effective easy way to get more efficient drive system motors on the road fast!
No, it doesn't. It only limits this particular challenge to a more efficiently powerful lighter motor. ;)
There's nothing wrong with spreading the news about PMA motors anywhere you like that's appropriate, and if you have a design that fits within the limits of this challenge, you can show how to build one here in this challenge thread, too.
So I'd say start a thread (or continue one if you already have one) and show how to build them all the way from several ways to acquire a core unit, to how to take several different kinds apart, to how to modify them as needed, rewinding them where needed, etc., all the way up to how to mount them to the bike and build a drivetrain for them for most efficient use.
Then *that* will get more of them on the road fast. ;)
If you sell them premade, then make a thread for them on the for sale section and that will get them on the road even faster if they're cheap enough.
amberwolf
Postby enoob » Tue Dec 29, 2009 5:21 pm
) i like that ignore option aka: foe list
gives me time to stay cool .
This is how you do it Jcoot. may want to cruise this thread randy as it will either excite you or threaten you depending on your real motivation here viewtopic.php?f=28&t=14264
at this point im all in for less $ than what it would cost me to assemble a motor from your links. INCLUDING the gear reduction . making my version easier to bolt on to just about any bike out there. in my humble opinion.
after weigh in this morning INCLUDING my completely untested 4:1gear reduction unit , that is now built into the motor i am at 6.8 pounds . this includes the stock steel stator yet to be replaced if possible with a coreless version . im just gonna pretty it up this afternoon , add some more speed holes :wink: and it should lose a little weight still . so ill spend a little time seeing what would be involved in stacking another rotor and stator , see how much that will weigh in at.
Thud the version ill send you will not include the gear reduction ill just include a shaft collar to slip a sprocket onto.
which brings me to the pertinent point for the thread . how or what should i do to the output shaft to best facilitate testing on your end thud ?
M.E.N.S ex pres and charter member.
enoob
Postby jscoot » Tue Dec 29, 2009 6:57 pm
More than likely Miles motor will still be more efficient and reliable for overall use than what motor builds end up being made for this challange.
jscoot
Postby TylerDurden » Tue Dec 29, 2009 7:06 pm
Draper:
The parameters for the challenge are set.
Get in the game, or get lost.
Have a Nice Day,
TD
FYI: Adding pictures?
TylerDurden
Postby Thud » Tue Dec 29, 2009 7:27 pm
enoob said,
Just make it round & I will adapt it to the input shaft of the...... DYNOMOMETER.......
(god I love saying that!) :lol:
I will figure out some way to mount it solid & get the readings on it.
No reductions will be tested unless they are integral to the design. (we will leave reductions to another challange thread of someones creation) :mrgreen:
get some......
Thud
Postby liveforphysics » Tue Dec 29, 2009 7:39 pm
Jscoot- I really don't see how you think those converted alternators can compare. You've got thick lams with poor copper fill and big flux gaps, stator teeth done in a grouped series arrangement that gives loads of end losses and weird flux patterns, and it's all put together in a package designed around being bolted to a 400lbs engine where adding weight doesn't make much of a difference.
My motor will be matching the KV of these motors, likely around 1/5th the weight, and easily half the inefficiency of these alternator/motor conversions.
It's like if were all working on building fighter jets, and you keep bringing up an E-bay link to a semi-truck you're selling. Semi-trucks are neat I guess, and even poor efficiency heavy motors have a place in the world somewhere, but I don't see how it applies to this thread.
If you can put something together under 3Kg, it would be great to have another entry in the competition. :)
liveforphysics
Postby Miles » Wed Dec 30, 2009 5:44 am
Thud wrote:No reductions will be tested unless they are integral to the design. (we will leave reductions to another challange thread of someones creation) :mrgreen:
It certainly wouldn't be fair to allow any type of torque multiplication to be included in the testing, integral or not.....
If it's not possible to easily disconnect a reduction we could just divide the output torque by the reduction ratio....
Miles
Postby jscoot » Wed Dec 30, 2009 6:12 am
liveforphysics wrote:Jscoot- I really don't see how you think those converted alternators can compare. You've got thick lams with poor copper fill and big flux gaps, stator teeth done in a grouped series arrangement that gives loads of end losses and weird flux patterns, and it's all put together in a package designed around being bolted to a 400lbs engine where adding weight doesn't make much of a difference.
I guess I could enter this motor after putting two of these Ceramic bearings in at a Low Price: $129.00 each. This motor produces over 4 nm of torque startong with a 7 watt 10 rpm spin that you can not stall using thick lether gloves and your hands at 50 watts with the most hand load you can put on the 5/8 shaft. It runs nice and smooth for ebike use up to 60 volts, beyond that you will go too fast. Right now it freespins at 37-39 watts on 52 volts at 3300 rpm. Another motor I have with a kv of 40 will be better for a higher torque test.
It will be interesting to see what difference new bearings will make.
jscoot
Postby jscoot » Wed Dec 30, 2009 6:21 am
Unless you did a dyno test for the gearbox for all rpms and loads and added the weight together then deducted the inefficiencies for each rpm and load that the motor was dyno tested at then what you said would be fair. I thought the rules only included the motor ? Why not 5 Kg motors if you allow gearboxes/motors? are the rules changing already? :D
jscoot
Postby Miles » Wed Dec 30, 2009 6:30 am
jscoot wrote:I thought the rules only included the motor ? Why not 5 Kg motors if you allow gearboxes/motors? are the rules changing already? :D
Randy, try to understand what I've written before you reply.
Miles
Postby Thud » Wed Dec 30, 2009 6:41 am
I will clarify:
NO reductions will be tested.
I thought someone may get cute & incorperate a planitary mainshaft reduction, totaly intergrated into the "motor"
Definitaly NOT in the spirit of the Challange. (no Kudos for you)
Anyhing submited with a reduction on it, will be subjected to the furnace, poured into ingots & used as the trophy to the leader of the challange.
:mrgreen:
get some......
Thud
Postby Miles » Wed Dec 30, 2009 6:42 am
:mrgreen:
Miles
Postby jscoot » Wed Dec 30, 2009 7:06 am
Nice to know the rules are set. Now what is the voltage range .... 24 - 100 volts ? :?:
jscoot
Postby Thud » Wed Dec 30, 2009 7:13 am
Lets start a discusion regarding the actual test procedure.
I am thinking 36 or 48 volts (I have 56ah of SLA at 48v for testing)
1) start the test at no load & measure rpms & amp draw.
2) apply load to 90% of no load rpm & measure amp draw & foot pounds of tourque.
3+)progress down to 50% of no load rpm & see what tha amp & tourque are at.
X) final is to measure max tourque (up to controller amp ratings at least)
Q- is The max the max tourque measurment pertinant to this challenge?
Or- should we just load the motors to the tourqe level determined via weight of the unit & see if it:
A) achieves the goal & is inside the amp limitations of my test equipment
B) is capable of maintaining that level of output.
This is assuming that we are still inside amper ratings of my sisy speed controllers
I have the CC ICE100(30v max), the new turnigy 200 amp unit(50v max) both sensorless & I plan on ordering a 36 volt infineon & going all "methods" on it to get the voltage/amperage where I feel I need it.(sensored)
Input please.
get some......
Thud
Postby jscoot » Wed Dec 30, 2009 7:28 am
Thud wrote:Lets start a discusion regarding the actual test procedure.
Input please.
I imagine some small motors will start to smoke soon after the 12 mn of torque (limit to the rules ? ) is applied for a few minutes. Do you let them fry or will there be a heat measuring device the tester will use to save anyones motor/controller ? Even though Ebike motors are always getting a breeze while in use on a ebike, will all the testing be done in still air or with a small fan a few feet away ? what will the room tempture be ? another question: What is the watt limt ? and will the tester use the motor throttle to try to keep the motor watt limited to the builders wattage specs just incase some motors are rated of a lower wattage ?
jscoot
Postby Thud » Wed Dec 30, 2009 7:44 am
Good catch,
I forgot the temp monitering in that post.
I originaly thought measuring at set times of duration will be nessisary also.
I am more concerned with the durability of the drive components than smoking a test motor.
I suppose if a motor is clearly under stress attempting to make the touque ratings of the challange, it will be considerd a "fail"
then any measurments performed using what ever standards we determine (I perfer a standardize procedure to elliminate as much speculation as possible) will allow us to gage the motors against each other.
jscoot wrote:
Do you let them fry (thud-why not?) or will there be a heat measuring device the tester will use to save anyones motor/controller ? (thud-I will let the builders determine if they want their motors tested to failure ie "smoked" trying to meet the challenge)
Even though Ebike motors are always getting a breeze while in use on a ebike(thud-speculitive),
will all the testing be done in still air or with a small fan a few feet away ?( I will have a small fan to create air movement. not nesisarily directed air over the motor, more to keep the eddy brake dyno in check) what will the room tempture be ?( ambient basment temp here in MI. :) between 50-70f)
get some......
Thud
Postby Miles » Wed Dec 30, 2009 8:04 am
Yes, we need to set a time period for continuous output. 30 minutes?
Miles
PreviousNext
Return to Motor Technology
