John in CR
100 TW
I'm looking to maximize efficiency of a hub motor that goes too fast at 72V, but it's easier for me if I maintain that voltage. The factory rep of the motor factory suggested limiting the current to limit the speed. The controllers have two bars, so halving the current is easy, and after thinking about it I wonder if there is really any difference between limiting the current in that manner vs changing my packs and changing the controller's voltage regulator section to run on 36V.
Assuming I get the speed I want running WOT using the same controller at 36V or limiting the current to half and running at 72V, how will the motor react in terms of efficiency? At the same speed the motor's BEMF will be identical, so I think an identical amount of power will be drawn by the controller. The brushless commutation should be identical, and at WOT I think the controller in either setup will run at full duty cycle, so identical efficiency, but I'm unsure of that aspect. I'm also unsure if the motor will really see anything different, and if so, run at a different efficiency.
What do you guys think? Am I likely to get identical power in and identical power out?
Happy holidays!
John
Happy holidays!
John
